89 tbi egr/headers?
I have an 89 tbi going in to my 87. I want to add headers in the most cost effective way possible. What do I do about the egr?
89 tbi egr/headers?
Dropping an 89 tbi motor into my 87 and want to add headers int eh most cost effective way I can. What do I do about the egr?
#3 | |
Re: 89 tbi egr/headers?
There may be air injection tubes in the exhaust manifolds. Any chance that's what you see? |
The EGR is part of the ECM loop so you need to keep it or have it deleted by tuning (new chip). Whatever headers fit your chassis will get the job done. You just need an o2 port near the collector.
Possibly. I just keep seeing headers that say for models without egr.
Got it all sorted out. I was thinking about it all wrong.
if full length headers its best to swap to a heated o2 sensor . lots of threads on this for your reading .
i my self dont care for headers . lots of extra heat and noise under the hood .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Heat for sure. Mine are ceramic coated & still put off some serious temps. I haven't had any issues on the noise level though. Are they louder than cast iron manifolds? Yep. But I don't notice any difference w/the hood shut. I also ground the head flanges true & made my own 3/8" thick collector flanges so zero leaks vs. the repeat leaker on my exhaust manifolds (pass side).
Thanks for the help. It is my sons build. We are going mid length headers with a o2 bung in the collector so I think a regular o2 sensor will work. The noise is part of the fun and the heat is not that bad. But that is the beauty of our trucks to each his own. I truly appreciate your assistance!
#11 | |
Thanks for your input! |
good deal, i just sold a set with air tubes ( capped), and bought the non air tube versions.
I had my chip/tune done w/the air pump option deleted since there wasn't one. But mine was/is a 1TON dually & didn't have CATs either.
I. On my 94 I deleted the egr and 02 sensor with out tuching the computer and it never made a difference. I have long tube headers and no cats . Same amount of power. Runs the exact same. And never had a problem. I also got rid of the e vap canister. You can tell where I live there is no inspection
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
