10-07-2019, 09:57 PM | #1 |
Identifying relay?
While I was replacing the hydro boost unit, I had to remove a couple of the relays to get access to the firewall. Can anyone help identify what these relays are for? Thank you.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
10-07-2019, 11:39 PM | #2 |
Re: Identifying relay?
The round lump is one of the two flasher modules. The other is on the fuse box. One is for the turn signals, and the other is for the hazards. I don't remember which is which.
That rusty metal bracket also holds the buzzer that yells at you for leaving keys in the ignition. That's probably the white squarish thing. I don't know what the shiny metal/plastic thing with the blue and orange wires is.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
10-08-2019, 12:30 AM | #3 |
The second one with the two plugs is the power locks relay. Usually attached above the brake pedal.
Edit: The system grounds through the metal case. So if your locks stopped working, you need to re attach it to something metal or add a ground wire to it. |
10-08-2019, 06:00 AM | #4 | |
10-08-2019, 06:00 AM | #5 |
Thanks toomany2yz. Haha I was wondering why my power locks just stopped working!
10-08-2019, 07:31 AM | #6 |
Moderator
If the big silver can is stamped 14056552 on the tab it's the power lock relay.
25237003 is a horn relay. Google the part #. The round metal cans of that size are usually flasher relays. Either hazard or turnsignal. Which one may be marked on the socket under the edge of the relay itself. The seatbelt, key, headlight buzzer is rectangular. It plugs into the slot marked buzzer and it's completely missing... You have the gray cluster lamp wire in the buzzer socket so... If you get the T63 Light Minder option buzzer it'll buzz when you leave the headlights on. Here's the thread about the T63 Light Minder option. http://67-72chevytrucks.com/vboard/s...d.php?t=763202
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 10-08-2019 at 07:47 AM. |
10-09-2019, 05:53 AM | #7 | |
10-09-2019, 11:01 AM | #8 | |
Moderator
The reason most of them are removed is the seatbelt nag. If you don't want the seatbelt nag enabled just remove the wire at the relay block that comes from the driver side belt.
And please let us know if and how your repairs were successful. |
