Old 10-08-2019, 06:13 PM   #1
Dilemmaofny
Cool 1968 c10
Hey everyone one. Looking for some advice. So I have a porterbuilt setup front and rear ( extreme). I also ordered accuair setup from them. When I air up the bags all the way. The truck sits about 3” from the ground. It doesn’t give enough ride height. Is there something I can do to fix this. Maybe Bigger bags? any help would be great.
Dilemmaofny is offline   Reply With Quote
Old 10-09-2019, 10:55 AM   #2
SCOTI
SCOTI's Avatar
Re: 1968 c10
What size wheels/tires?
Drop spindles? If so, what size?
Standard body/cab mounts?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-10-2019, 01:15 AM   #3
Dilemmaofny
Re: 1968 c10
As of now. It has the stock rims and tires. It as 2 1/2 drop spindle and I replaced the mounts with the same type from LMC
Old 10-10-2019, 09:22 AM   #4
SCOTI
SCOTI's Avatar
Re: 1968 c10
So, stock body mounts = not body dropped.
Drop spindles.
What size tires?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-10-2019, 07:48 PM   #5
Woodnears
Re: 1968 c10
Got any pics? It's kinda hard to mess up the extreme kit. I have the same setup and can help you through it? What's your total tire outside diameter? I'm running almost 30" of tire. If you're running a small tire it might be hard to get decent height
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417
Woodnears is offline   Reply With Quote
1968 c10, accuair, c10, porterbuilt
