09-03-2019, 09:10 PM | #26 |
Re: Cgt project
Make it real low they said, it will be cool they said....Urg!
Was going to flatten the firewall anyway. |
09-03-2019, 11:51 PM | #27 |
Re: Cgt project
Is the engine being set back more than usual, or is it just a height issue?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
09-04-2019, 11:05 AM | #28 |
Re: Cgt project
The engine may have slighty more setback than stock, but the issue is when you go this low all the suspension goes up in the frame, mounting the engine that much higher. Running 28 and 29 inch diameter tires doesn't help and that 8L90 tranny is huge. The steering rack is determining where the engine will sit. From where the engine sits now I could go forward or back an inch or 2.
10-06-2019, 08:15 PM | #29 |
Re: Cgt project
Turned my big hump into a super hump. Needed the extra room for the 8L90 and driveline angles. Starting to make a firewall.
[ATTACH][/ATTACH] |
10-07-2019, 09:49 AM | #30 |
Re: Cgt project
Its fun to watch your dream ride be built. lol
Awesome build! Love the whole plan, excited to see the updates. |
10-07-2019, 09:59 AM | #31 |
Re: Cgt project
Looks like you had to raise the tunnel about 2"?
10-07-2019, 12:20 PM | #32 |
Re: Cgt project
Close 2.5"
10-20-2019, 08:25 PM | #33 |
Re: Cgt project
Firewall is done. Won't see much of it because of the larger inner fenders.
02-23-2020, 11:18 AM | #34 |
Re: Cgt project
Making some progress
Exhaust Exhaust exit Finally got my wheels. Shown at ride height |
02-23-2020, 11:43 AM | #35 |
Re: Cgt project
Damn, what a work of art that frame is. nice work
03-01-2020, 08:59 PM | #36 |
Re: Cgt project
Wow, that exhaust is killer! Nice work!!
I love the idea, definitely haven't seen that before.. but won't the exhaust heat damage the chrome on the bumper? |
03-02-2020, 01:25 PM | #37 |
Re: Cgt project
It will not damage the chrome. I have done this before on a 57 Chevy where I had the exhaust come out where the optional backup lights are with no issues.
03-02-2020, 01:30 PM | #38 |
Re: Cgt project
Love it when things work out. The A/C evaporator fit with no issues with the fire wall mods
03-02-2020, 01:34 PM | #39 |
Re: Cgt project
I used vintage air's condenser for a C10 as it fits inside the rad support to give more room for the radiator.
03-18-2020, 10:39 PM | #40 |
Re: Cgt project
Intercooler tank fits
03-18-2020, 11:25 PM | #41 |
Re: Cgt project
Awesome!
03-19-2020, 08:42 AM | #42 |
Re: Cgt project
Looks killer!
03-19-2020, 03:31 PM | #43 |
Re: Cgt project
This thing is a beauty, I love all the killer metal work.
Can't wait to see more progress on your build!
Chuck Instagram: c_lo_garage Check out my 1966 C10 project "El Viejito" here: http://67-72chevytrucks.com/vboard/s...d.php?t=674614 |
03-20-2020, 11:41 AM | #44 |
Re: Cgt project
I have my 325/35/22 tires in place. They are pretty big at 31" tall. Pictured is the min clearance I could get away with, about 3/8". Should have a bit more maybe. I don't really like the way they look from the outside. To far in. Thinking I will cut the box side flange back, to bring the tire farther out. Anyone do this? I'm thinking I would cut back to 1/4" and weld some 1/4 x 1/2 FB along the seam to make up for lost strength. I could then move the tire out another 1" or so and end up with 1/2- 5/8" clearance
03-20-2020, 03:48 PM | #45 | |
Re: Cgt project
What wheel widths did you ultimately purchase?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-20-2020 at 03:54 PM. |
03-20-2020, 09:39 PM | #46 | |
Re: Cgt project
03-20-2020, 09:43 PM | #47 |
Re: Cgt project
Put it on the ground today and rolled it out. The rear tire looks better sitting on the ground.
[ATTACH][/ATTACH] |
04-01-2020, 08:14 PM | #48 |
Re: Cgt project
Most of the fab. is done. Starting to take apart to paint. These are the nine pieces that make up my exhaust.
04-02-2020, 07:02 PM | #49 |
Re: Cgt project
Love it. Stance = nailed.
04-04-2020, 02:12 PM | #50 | |
Re: Cgt project
