![]() Join Date: Sep 2006
Rebuilding Engine
I figured it was time to rebuild the engine in my truck as it was leaking and burning a lot of oil, not to mention some knocking sounds. It is at the machine shop right now. I was trying to get engine color. I thought it was the green color but come to find it is the blue/gray color. Here are some pictures for you enjoyment as I know you guys like pictures. I will have some after pictures when the time comes. There was no bearing material on the rods except for the #4 hole. I could use the lifters at bowls.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Re: Rebuilding Engine
More. If anyone knows where I can get the engine color I would love for you to pass that info along to me. As it is I am going to take the oil pan with me to the paint store and see what they can do.
Consider springing for a retrofit roller cam. Pricey, but you don't need to stress over the level of zinc/zddp in your oil.
I haven't yet found what the proper color is, though I understand many use Ford Gray (which is what I used on the motor in my '61). If you can polish up some of the original color, you can probably have your local paint shop match it.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Who Changed This?
![]() Join Date: Jan 2013
Looks like you got your money's worth out of that bad boy!
Here's what they look like in Ford gray. I also went with a gloss clear over the gray which was also made for engines.
![]() Join Date: Dec 2009
Here is an interesting article about the paint color story.
Looks like they may sell paint that is a close match. Link:https://www.fillingstation.com/articles/grayengine.htm .
I used this paint https://www.hirschauto.com/ENGINE-EN...RT/CHV%20GREY/ for my 283 in my 65' C20, it looks better in person than the picture. It is a close match to the original.
#8 | |
#9 | |
Moderator
![]() Join Date: Dec 2012
Looking at that timing setup... this thing skipped a few oil changes over its life...
#11 | |
Did that speedometer break at 154999 or 254999?
That is more worn out than I have ever seen before. |
I don't really know.
#15 | |
![]() ![]() Join Date: Apr 2012
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#16 |
#17 |
I stopped by an autobody paint store yesterday and found a close match to my oil pan color. I will post pictures after I paint. That would be in about a week or 2.
#18 |
![]() Join Date: Oct 2017
I assume a quart was enough to cover your engine?
#19 |
I just bought one arousal can. Should be enough as long as I don't waste it. If I want to do a separate quart with hardener, it will be $101.
#20 |
Who Changed This?
I think that it will take two cans. In my experience, one won't quite make it. BUT, the gray may be a real high-hide color, and it may only take one can. I know that the Moly Orange usually took a little less than two cans to cover a V-8 engine. Maybe I was just happy with the fumes?
#21 |
I bought one just in case I didn't like the color. I will be using black Epoxy Primer so that will help a lot.
#22 |
Got my short block back. A friend has a set of heads already done but I'm still waiting for them. My other dilemma is whether to put a 700r4 automatic transmission I have or back to the 3 on the tree which is also an overdrive but not original to the truck. With an auto my son could drive it but I do plan on teaching him how to drive a stick.
#23 |
Nice shiny parts!
What heads are you gonna use? What valve sizes? How many CC’s? |
#24 |
stock 283 heads. Not looking for a lot of HP just a nice running truck.
#25 |
All is good!
Just curious! Some people bolt on higher cc heads without a thought and loose a bunch of compression and power. |
