10-30-2019, 09:54 PM | #1 |
Where are the usual rust spots 4 suburbans?
So I scored this awesome suburban the other day and was thinking about flipping it untill I drove it,I simply love it and now I contemplating keeping it. I am well versed in trucks and a little experience with the Blazers but this is my first suburban and the rust is showing up differently than what I'm used to. The rockers seem to be rotting from the outside in rather than the usually door sill area. I also noticed rust starting at the inside roof top where it meets the windshield and behind the rear seat where the front bed wall meets the flooring. Pretty obvious why the rear quarters are starting to rust at the inside floor level. Are there other areas that are typically problem spots for rust that I need to look for on this particular body style?.
10-30-2019, 10:04 PM | #2 |
Re: Where are the usual rust spots 4 suburbans?
Here a few pictures.
10-31-2019, 06:44 AM | #3 |
Like you, I've had several pickups and a Jimmy before buying my Suburban. I regretted selling that one so I bought another. The rust problems are the same as a pickup with the exception of the kickup area behind the middle seat. Looks like your roof seam sealer has broken down.
10-31-2019, 01:21 PM | #4 |
Good morning neighbor. All of the above items and the rear hatch and gate are problematic if you have them, more so than barn doors which would be similar to the pickup doors as far as rust. Oh and the taillight housings are in a box that can fill up with dirt and rust out.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-01-2019, 03:09 PM | #5 |
The spot for the spare tire was rusted through on mine. Low to the ground and accumulates water when the hatch had a leak. Then i had the normal stuff, rockers and floor near it, windshield, around the tire wells on the outside. Drip rails too, I think My body guy said the a pillar support under the fender/door was bad too.
11-03-2019, 03:51 PM | #6 |
Rust through in the vertical floor portion under the rear seat was the bigest issue for me (as shown It was an indicator of issues with the large crossmember and crossmember to inner sill fastening points. I think many suburbans suffer from this since moisture gets trapped between crossmember and the spot welded floor vertical piece . I fixed mine but it was a huge job. Check the condition of body at ends of crossmember.
11-17-2019, 12:06 PM | #7 |
I've got parts for this
Floor pan section Firewall Left and right wheel wells Roof skin The barn Doors We could meet half-way!
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
11-17-2019, 12:07 PM | #8 |
I also have the whole left section from drivers door back back, also some other misc parts suburban-only
