11-04-2019, 03:45 PM | #101 |
Re: Son's 68 c10 Short Bed
Got the frame all buttoned up and exhaust done. Still need to re-install the tank but you get the idea.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 |
11-05-2019, 11:25 AM | #102 |
A couple weeks ago, I spent the afternoon polishing the gas tank. Yesterday, my dad decided to redo it. I have to say, his work is obviously much better than mine.
11-05-2019, 11:33 AM | #103 |
Well now he's just showing off...
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
11-05-2019, 11:48 AM | #104 |
Isn't that what dads do naturally though lol
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10” |
11-05-2019, 11:55 AM | #105 |
...just lovin' this build
11-05-2019, 12:24 PM | #106 |
Yeah, at first I thought maybe he was punking me. Then after about 6 reflection pictures, I was positive he was punking me.
Funny.
11-05-2019, 12:24 PM | #107 |
11-07-2019, 11:07 AM | #108 |
One more picture.....
11-11-2019, 10:59 AM | #109 |
I didn't take any pictures but we spent a few hours working on Saturday. We put a new diff cover on the rear end because the old one was bent on the bottom and the fluid needed to be changed anyway. Also, I finally flipped the shroud on the radiator so it isn't upside down anymore, and had to clearance a boss on the block on the driver's side to stop it from contacting the header.
So, little steps but still making progress.
11-25-2019, 03:47 PM | #110 |
Finally making some progress on the bed floor. Two weekends ago we started grinding and splitting spot welds. Saturday, we got the floor out completely and the rear section inserted and spot welded back into place. Today, they got the front section cut to length and inserted. Still need to get the middle cross braces put back in and weld the seam.
11-25-2019, 04:05 PM | #111 |
How did you end up with two sections of floor? I forgot that there was a flat section on the front portion but it looks like you have two new sections now?
11-25-2019, 04:50 PM | #112 | |
I'm actually pretty impressed with how it all is coming together. They come longer than an actual full floor and both front and rear are stepped to mate with an original floor. We cut about 5" off the front. Will have to weld the seam and body work it but it wont be bad. Now all the sheet metal on the bed will be new except the bed sides.
11-25-2019, 04:55 PM | #113 |
Here are some pictures of the whole floor laid out on the ground. Also, a picture of how they are stepped and approximately how much we had to cut.
11-25-2019, 05:47 PM | #114 |
Interesting, I had no idea! I'm interested to see what type of coatings you put on which parts of the bed. I was planning on 4 coats of epoxy primer to the underside of the floor, raptorliner to the top side of the floor, epoxy to the underside of the wheel tubs, then paint both sides of the sides, front panel, tailgate, and top side of wheel tubs.
11-25-2019, 06:06 PM | #115 | |
11-25-2019, 06:09 PM | #116 | |
11-25-2019, 07:32 PM | #117 | |
11-26-2019, 12:06 PM | #118 |
Yeah, I might end up adding some material so a cap will sit flat. Trying to come up with something a little different though.
11-26-2019, 12:43 PM | #119 |
The boy is working today and I just got these pics from my dad.
11-27-2019, 11:00 AM | #120 | |
I've also seen where they have 'bridged' the ribs so the center 3 are tied together in that area & have the same shape in between the ribs so it all looks consistent.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-27-2019 at 11:06 AM. |
11-27-2019, 12:53 PM | #121 |
I like that third picture.
Tanks Inc has a fuel door kit but it's kind of pricey. You can always cut out a door assembly at the junkyard and weld it in too.
12-09-2019, 02:06 PM | #122 |
Thanks for the ideas. I was planning to get all creative but think I will end up ordering a Hagan door. Haven't decided if I am going to go with a square or round one yet, but will post pics once I do.
The motor harness should be here in the next week or two. In the meantime, I have ordered a fan relay and am just waiting for the parts to get here to fire this thing.
12-19-2019, 04:33 PM | #123 |
No real updates. The harness came in but we haven't had a chance to work on the truck.
I picked up this steering wheel as a Christmas present. Also, the Hagan fuel door came in.
12-19-2019, 05:38 PM | #124 |
I like my Forever Sharp wheel too!
Did you get the American Autowire Classic Update or are you talking about the LS harness?
12-19-2019, 07:28 PM | #125 |
Just the ls harness. I did the Autowire kit on the last one of these we did. Good stuff.
