Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-19-2019, 08:39 PM   #601
pitterpat
Re: 73-87 cab corner 6X9 speaker brackets - 2nd series
Got mine a couple of weeks ago. Great fast shipping. Just got them painted yesterday, letting them cure for a couple of days. Painted blue, Dupli color Dark Blue Met (28 WA8264)
1984 Chevy Custom 20
$2500 work done on engine and transmission 2010/ less than 1000 miles on it since.
Here's my mild build thread,
http://67-72chevytrucks.com/vboard/s...d.php?t=783971
pitterpat is offline   Reply With Quote
Old 08-20-2019, 08:41 AM   #602
bigblock73
yeller
bigblock73's Avatar
I love that blue! Thanks for the feedback, please post pics when you have them installed.
bigblock73 is offline   Reply With Quote
Old 08-25-2019, 10:13 PM   #603
sprayed99
Originally Posted by bigblock73 View Post
Hi Dan, they are not on my site, I only offer them in limited quantities. Same exact bracket as the 6x9, just with a round opening. Same price, $65 shipped. If you want a set, you can just send the funds via PayPal to jdrew@73-87.com
I offer them with two different opening sizes, 6" and 6.5", as the "6.5" speakers on the market have a wide range of opening sizes.
I will be using the focal 165AS in the rear.Their spec sheet says 140mm which roughly translates to 5.6". Which, if either would work for me?
sprayed99 is offline   Reply With Quote
Old 08-26-2019, 11:02 AM   #604
bigblock73
yeller
bigblock73's Avatar
The two sizes I have are 5-7/8” and 6.5”. I’d buy the smaller ones, you should be fine. If that works, just send the funds to www.73-87.com
Old 08-27-2019, 11:16 PM   #605
sprayed99
Payment sent for 5.875" pair
Old 08-31-2019, 11:46 AM   #606
bigblock73
yeller
bigblock73's Avatar
Your inbox I sent full, please clear it out and either send me a message, or text me at 612-558-1666
I was wrong on my opening sizes, I have 5-1/4" and 6" ( I was in DC for work and was going off memory)
I researched your speakers, the mounting diameter is right at 6", so you would need to buy the smaller 5.25" and enlarge to 5-9/16"
Again, PM or text so we can coordinate this.
Old 09-15-2019, 12:24 PM   #607
bigblock73
yeller
bigblock73's Avatar
Ttt
Old 09-16-2019, 12:29 AM   #608
Too Tall
Hi Jeff
Just wondering how much room there is between the shelf below the bracket,and the base of the bracket?
My dilemma is, I have the original cardboard tray and I'm trying to see from the pics if there's enough room for both.
The tray side is about 3" tall.
I may need to do some trimming?!
Thanks in advance
Conrad
1981 GMC
Too Tall is offline   Reply With Quote
Old 09-23-2019, 08:01 PM   #609
bigblock73
yeller
bigblock73's Avatar
Originally Posted by Too Tall View Post
Hi Jeff
Thanks in advance
Conrad
Hi Conrad, I’ll get you a measurement tonight. I do believe you will need to do some minor trimming to make the tray fit.
Old 11-08-2019, 12:42 AM   #610
bigblock73
yeller
bigblock73's Avatar
Ttt
Old 11-08-2019, 08:18 AM   #611
S10Fan
Old Heap Driver
I'm going to give a shout out every chance I get for these brackets! I no longer own my Square, but these brackets are first class and fit perfectly. Plus, you're supporting a board member/vendor!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod.
S10Fan is offline   Reply With Quote
Old 11-08-2019, 03:05 PM   #612
kidatheart
kidatheart's Avatar
I ordered a set. Thanks!
kidatheart is offline   Reply With Quote
Old 11-11-2019, 11:21 PM   #613
bigblock73
yeller
bigblock73's Avatar
Thanks Bryan!
Old 11-11-2019, 11:22 PM   #614
bigblock73
yeller
bigblock73's Avatar
Thank you, they are en route
Old 11-14-2019, 08:29 PM   #615
kidatheart
kidatheart's Avatar
Received my brackets-nice! Thank you.
Old 01-15-2020, 12:48 PM   #616
bigblock73
yeller
bigblock73's Avatar
2020 bump
Old 01-16-2020, 05:34 PM   #617
K25alive
Jeff, my 1977 C10 does have one of the seat belt retractors mounted to the pillar. The main retractor is mounted to the floor. You have said the early 3-point type seatbelts won't work with your brackets. Have you heard of a work-around for these speaker brackets to work with this seat belt set-up?
K25alive is offline   Reply With Quote
Old 01-18-2020, 07:38 PM   #618
bigblock73
yeller
bigblock73's Avatar
That mid mount retractor screws everything up. It’s actually a terrible design, and why GM ran them less than a full year. Ditch them for the 77/78 and up floor mount belts. They work much better, and will work with the brackets.
Old 02-14-2020, 10:28 PM   #619
bigblock73
yeller
bigblock73's Avatar
Valentine’s Day bump
Old 03-16-2020, 11:32 AM   #620
aggie91
I'm just glad to be here!
aggie91's Avatar
Just placed an order online on your Website. Thanks Jeff!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-17-2020, 03:18 PM   #621
bigblock73
yeller
bigblock73's Avatar
Thank you! Brackets will be in today's mail.
Old 03-22-2020, 11:13 AM   #622
aggie91
aggie91's Avatar
Received the brackets on Thursday. They look great and well made. I used to work in the sheet metal fabrication industry, so I know good work when I see it!
Karl
The LST Challenge:
Old 03-23-2020, 06:57 PM   #623
bigblock73
yeller
bigblock73's Avatar
Thanks for the feedback, much appreciated! Good luck on your install!
Old 04-18-2020, 04:31 PM   #624
bigblock73
yeller
bigblock73's Avatar
Bump
Old 06-26-2020, 08:47 AM   #625
bigblock73
yeller
bigblock73's Avatar
bump
