06-29-2017, 08:06 PM | #1 |
87-90 Jeep Wrangler gas tank
Going with a Jeer Wangler gas tank. Will the 1" fill hose work ok or should I solder in a larger neck?
67 c20 68 c10 72 c10 69 GMC 72 short step |
06-30-2017, 12:48 PM | #2 |
Re: 87-90 Jeep Wrangler gas tank
I used one. wasn't happy with routing options and the 1" neck concerned me. I ended up getting a bolt on fuel cell neck and cutting an access hole in the bed. Not my favorite mod to date.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
07-26-2017, 08:13 PM | #3 |
Making some head way on tank mounting jeep gas tank. Two 5/16 bolts hold the front of tank on cross member. 1 in angle bolted to back of tank & frame (4 more 5/16 bolts. I shaped the side of the angel to fit the tank, Probably not necessary. I just did it to get more iron around the bolt.
09-25-2017, 03:56 PM | #4 |
s10 blazer sending unit (Dorman 692004) with in tank gm fuel pump (Delco ep 381). Adaptors M14 x 1.5 & M16 x 1.5 to an-6 (summit 9894dbherl & 9894dbjerl)
09-27-2017, 07:44 PM | #5 |
Mounted fuel filter inter frame drivers side behind cab. I used the bracket off my doner truck 2000 chevy. Used 2 adaptors ( Russell 648060) -6AN to 16mm X 1.5 O-ring Seal
01-29-2018, 11:26 AM | #6 |
Did you complete this job? I am following along as I am in the process of relocating my tank. Any issues with the S10 sender? Also, what are the 4 adaptors for (fuel out and return and 2 vents?) Thanks.
06-09-2018, 01:17 PM | #7 |
How's this working for you?
'71 C-10 SWB Shop Truck Currently 350/350, soon to be LS'd. |
06-12-2018, 12:45 PM | #8 |
I did this setup as I will go LS down the road and add a drop in fuel pump. It is working well for me to feed the carb now and the fuel gauge works. You can see the pictures of mine in the build thread "Cheyenne Rooftop Build". The only issue I have is a lack of back pressure so you can overrun the tank out the vent holes when filling (too many vents in tank and sender assembly). I have not got around to plugging some off.
11-08-2019, 12:41 PM | #9 |
Great info!
11-08-2019, 08:48 PM | #10 |
Yes all works great. I have more post to add. Converting dash to autometer. Pcm mount. Milling a walnut bed floor.
11-23-2019, 04:17 PM | #11 |
In your thread, i see the supply side, filter etc. but is there a return? I see two AN fittings in the fuel tank. Is one of this the return? Where does this terminate on the engine? (Side question, what LS engine are you running?)
11-20-2021, 03:44 PM | #12 |
Anyone have more photos of the Wrangler tank installed ? I’ve made the brackets out of angle but the tank isn’t level. I must be missing something.
Thanks. |
01-09-2024, 04:05 PM | #13 |
Bringing this old thread back up...
How did you run the filler hose? I'm ready to mount my tank, but unsure how to set up the filler neck.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
