67-72 Gen V LT engine swap mounts
METALTEK MANUFACTURING ENGINE MOUNTS
I would like to share our new Gen V LT engine mounts for the 67-72 c10 trucks Our engine mounts do require a swap oil pan and use the high hump transmission tunnel. These are item #17050K and the transmission crossmember is #19050A Thank you, Jaime |
![]() ![]() Join Date: May 2015
Re: 67-72 Gen V LT engine swap mounts
welcome....
nice brackets! why does the pan need changed? and which pan do you need?
Thanks for the reply, I appreciate it.
The L83/L86 truck pan hits the frame crossmember. For some reason the factory oil pan has a larger than normal front sump area. I would recommend the Holley 302-20 hands down. It maintains the factory cast rigidity of the OEM pan. |
Those mounts are the way to go!
I started on my L83 / 72 C10 swap before these were available and realized the problem of the stock truck oilpan hitting the front crossmeber. I cut pretty deep into my crossmember until it did fit, then spent way too much time welding in more steel and boxing it back together to keep it strong. I used the dirty dingo L83 adapters to work with the sbc motor mounts. They wouldn't allow space for the vacuum pump. Plus, The factory oil pan fit, but it still hung down too low for my liking. Then, frustrated with a pieced together set up, I happened to see the weld in style Metaltek L83 mounts on eBay. These gave me a much cleaner look. I also changed over to the Holley pan and got all the ground clearance I needed. The point is, save your time and money and buy the new Metaltek motor mounts and transmission crossmember DESIGNED for our trucks. Plus, the other guys making them are nearly 200. bucks more. Good job Jaime at Metaltek!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
Thank you Cornerstone for your review, I appreciate it.
Can you give more description on the adjustability if ther is any? Is the drop on the trans cross member lower than the bottom frame rail?
Hello Daaanz67,
The plates that bolt to the engine are slider style. They give you just over an inch of front to back movement. The frame mounting portion of the mounts bolt in to the factory mounting holes.The transmission crossmember is even with the bottom of the frame rail. These mounts with the crossmember are set to the proper driveline angle. These do allow the use either stock manifolds or the Speed Engineering c10 lt headers. Thank you for your interest, Jaime |
Metaltekman do the speed engineering headers hang below the frame with your mounts?
I used tia set up with the headers and they clear just fine. I cupped my lower control arms as well
Looks good! Does the factory AC and/or Alternator clear?
Can you post some more pics? |
Tags |
c10 swap, gen v swap, lt engine swap |
