Old 11-14-2019, 06:58 PM   #1
HazelsHoney
HazelsHoney's Avatar
Restoration Decision Help!!
Hi All,
1972 Chevy K-20 4wd, Complete build, Frame Off, looking for some input as we progress.
1. Convert to electric fan or keep OEM?
2. Convert to Hydraulic brakes or keep orig OEM master cylinder with vacuum booster? I am using the original OE set up, disc front and drum rear.
3. Convert steering column and steering wheel or keep orig OEM? If conversion any input on year, make and model that is popular to retrofit with?
4. Originally a NON-A/C truck but thinking of converting using Vintage Air or LMC Trucks brand. Input appreciated.
Thanks in advance for your input.
HazelsHoney is offline   Reply With Quote
Old 11-14-2019, 07:16 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Restoration Decision Help!!
Originally Posted by HazelsHoney View Post
Hi All,
I would keep the OEM fan
If you are talking about the HydroBoost brake and PS setup There are a few threads on here about the swap. Here is one:
http://67-72chevytrucks.com/vboard/s...d.php?t=523502
I would use the Vintage air setup.
By the way, I love the color.....
LockDoc
Leon
Old 11-14-2019, 09:23 PM   #3
HazelsHoney
Thanks LockDoc! I went round and round with keeping it the original color or changing it but In all honesty I couldn’t find any other color that I liked better than the original “mustard” color. It really pops when it’s fresh and new paint.
Old 11-14-2019, 10:39 PM   #4
HO455
HO455's Avatar
How about some more information on how you plan on using the truck? Some modifications may make more sense under certain conditions.
Great color and Welcome Aboard!
RIP Bob Parks.
Old 11-14-2019, 10:44 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
1-3: keep it simple and stick w OEM (OEM tilt)
4: Vintage Air
Old 11-14-2019, 11:26 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: Restoration Decision Help!!
Nice truck. Looks great so far.
If going ac use the clutch fan with a electric fan up inside the shroud when the AC is on. It will pull more air though the radiator and keep the head temperature down in the ac.
If your motor allows your brakes to work good then stay with vacuum.
Several members here rebuild tilt column's are will sell you one out right. Stay factory.
I like classic air group for ac stuff. You keep your trucks heat and just add the AC.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-15-2019, 03:49 AM   #7
Curtb1971
Curtb1971's Avatar
Awesome Colorado rig you're building there and ochre to boot
I've been happy with the installs of vintage air on mine and my old man's truck. With his we are going to put in a booster electric fan in addition to the mechanical fan clutch to just keep the head pressure down as Andy mentioned. Both trucks originally weren't AC trucks but nothing a few cuts in the dash with the buzz saw can't take care of. We cut in the vents in my dash after paint and just had to take extra care.
Can't go wrong with an oe column. If you dont have a wild cam a vaccum brake booster should work fine and save a ton of build time.
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 11-15-2019, 03:46 PM   #8
bs46488
can't comment on all your items, but...
2) I would vote for hydroboost. I did the conversion and always have consistent pedal
4) Yes on vintage air
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 11-15-2019, 11:15 PM   #9
weim55
I can only comment with personal experience with one item you requested. I’ve lived in Colorado all my life and built all stripes of small block Chevys. Because of our higher altitude any camshaft hotter than stock Can produce low vacuum issues for power brake systems. If your engine is anything other than a stock rebuild I would just go straight to the hydro boost and never look back. That system is particularly good in a heavier truck such as your K 20. Looks like a fun build, enjoy!
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 11-16-2019, 04:14 PM   #10
67swb72klb
67swb72klb's Avatar
I really like the feel of the hydro boost brakes..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 11-17-2019, 02:02 AM   #11
siggyfreud
siggyfreud's Avatar
I just did a hydroboost conversion too and am a big fan. It gets my vote too.
siggyfreud is offline   Reply With Quote
Old 11-17-2019, 12:45 PM   #12
fourspeedwagon
fourspeedwagon's Avatar
Doesn't look like you're doing a perfectly stock "restoration". So, I'd say hydroboost and vintage air for excellent upgrades. Not sure your be able to find a column better than a good rebuilt factory, especially tilt.
1951 GMC 250 Open Express Pickup
1968 Suburban C10
1971 C20 Olive
“People are shocked when they find out I’m not a good electrician”
Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it”
fourspeedwagon is offline   Reply With Quote
a/c, brakes, fan, restoration help, steering column
