Old 11-08-2019, 07:13 PM   #376
harrisoncole4
harrisoncole4's Avatar
Re: 1969 K10 CST Full Restoration
Originally Posted by IronCanine View Post
Thanks.
I would think it should be a word, but spellcheck doesn't like it.
Thanks Mike. I would like to have one of those steamers I see the upholsterers on TV use, but where we live these days it's not necessary. We just put it in the truck and let it sit. 100+ degree days make everything lay down...even the carpet. Really loving the latest iteration of your build btw.
...couldn't resist popping the caps on yesterday. Love me some P03s on white steel.
Where did you source the red hub dials from?
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
Old 11-08-2019, 07:29 PM   #377
IronCanine
I'm trying....
IronCanine's Avatar
A picture is worth a thousand words as they say...check out post #10. They are NOS and my brother found them either on Craigslist or eBay....I'm not 100% sure which now. They weren't red...(NOS red dials are another set of hen's teeth that we couldn't come up with). They were yellow, but only a mean person with a knife would know that now...or someone with an internet connection...and eyes to see post #10.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 11-08-2019, 08:38 PM   #378
jaros44sr
jaros44sr's Avatar
as of now, a set is on our for sale section
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-09-2019, 07:05 PM   #379
harrisoncole4
oops... I should have looked further back in the thread. Thanks for info! I might try cleaning up my faded red dials and trying the same. Was SEM Flame Red #15373 used?
Old 11-09-2019, 09:44 PM   #380
IronCanine
I'm trying....
IronCanine's Avatar
Don't sweat it. Definitely 15373 Flame Red. I took an original dial in to match it. It's a pretty solid match.
Old 11-10-2019, 11:27 PM   #381
IronCanine
I'm trying....
IronCanine's Avatar
Several things accomplished this weekend...still a longer check off list than I'd like. I'll try and post more pics tomorrow, but this was the highlight of the weekend (see link below). Started on the first try. These are her first spins. Started filming a few seconds after she caught and I was confident she was holding her water so to speak. Sounded pretty good for no carb or timing tweaks.
https://vimeo.com/372279353
Old 11-11-2019, 12:53 AM   #382
cornerstone
cornerstone's Avatar
Amazing... looks and sounds smooth for a first start!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-11-2019, 10:41 AM   #383
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice!!! It's alive!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is online now   Reply With Quote
Old 11-12-2019, 08:47 AM   #384
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Take a victory cruise beer run to celebrate back at the shop!
Old 11-12-2019, 11:18 PM   #385
IronCanine
I'm trying....
IronCanine's Avatar
Thanks. It was amazing actually. But I'll take a win where I can get it.
Originally Posted by Ol Blue K20 View Post
Nice!!! It's alive!
Got a pulse and breathing...just got to get her on her feet!
If I can ever master a double flare we will my friend.
Old 11-12-2019, 11:36 PM   #386
IronCanine
I'm trying....
IronCanine's Avatar
As I'd previously noted we had a coolant leak associated with the top radiator hose. It is not a revelation that tower clamps are not ideal. I ordered fresh clamps (because they just really seem like a one shot deal). The first set were supposedly Wittek clamps. I picked up a set of date coded ones this time around, also labeled Wittek (they were not marketed as NOS and I am under no illusion that they are) but they seemed more substantial than the first set. I lightly lubricated the inner surface of the clamps and positioned them right behind the bead on the metal radiator pipe and similarly on the thermostat housing and radiator outlet. We ran her for a fair bit last night and topped off the coolant. So far so good.
Old 11-12-2019, 11:53 PM   #387
IronCanine
I'm trying....
IronCanine's Avatar
We got the cowl, antenna and wipers on over the weekend. The transmission was painted black and installed, and the antenna wire got routed. We didn't get the distributor 180 degrees off this time...but we did get the the wiper transmission 180 off. Luckily we checked it before the wipers went on...but unfortunately we didn't check it until the cowl with the hood to cowl seal was fully installed. Practice makes perfect as they say. Another thing I'll get to do over is the AC vacuum reservoir canister. I didn't notice it until I watched the first start video, but we dinged it fitting the hood. Of course I blame Classic Auto Air...we sent a box/bracket/canister that came off this cab. Not sure what I got back-but it didn't quite clear. Fortunately I think Roger Koop is going to be able to hook me up with a replacement. We had a bit of a weep at the oil line connection to the gauge. Tonight I trimmed the line and replaced the nut and ferrule-hopefully that sorts it...and Eric got the splash guards installed. The goal is to be on the road this weekend.
Old 11-15-2019, 11:08 PM   #388
69cam
I started reading this thread from page one about a month ago, love everything about this truck. Keep it up, and best of luck with the final tidbits. Gorgeous truck!
69cam is offline   Reply With Quote
Old 11-16-2019, 05:35 PM   #389
IronCanine
I'm trying....
IronCanine's Avatar
Thank you very much. It's been mostly fun. Inching toward the end.
Old 11-16-2019, 05:47 PM   #390
IronCanine
I'm trying....
IronCanine's Avatar
Nicest guy ever hooked us up with some NOS bullseye back up lenses. Got the rear brake lines re-bent. I just had too much downward bend in my first set at the spring bolts. My batting average on those double flares definitely went up as I went along. But it's still pretty low. Went through a bit of line to get those two done. Added the black center to the front caps at Pete's rightful urging. I believe they came both ways...but this makes them more symmetrical with the rears.
Old 11-16-2019, 05:56 PM   #391
IronCanine
I'm trying....
IronCanine's Avatar
Eric got the inner fenders in and detailed, and went through final panel tweaks. We spent the majority of yesterday evening working a to-do list that weirdly seem to shrink and grow at the same time. The big accomplishment before bed time was getting the brakes bled.
Old 11-16-2019, 06:11 PM   #392
IronCanine
I'm trying....
IronCanine's Avatar
It was too wet to try and get her out this morning, and there was still a lot left to do...so we made use of the time. We don't have every single i dotted or t crossed (and also the Dawgs kickoff was at 3:30) so we didn't push it to put her on the road today. But after lunch we were able put her in gear and drive her outside under her own power. It was nice to see her in sunshine. Maybe we can log some miles tomorrow.
Old 11-16-2019, 06:53 PM   #393
chewychevy67
I'm excited for you. It's quite something to realize all the work into a project when it's sitting in the sun waiting for a ride. Congrats.
chewychevy67 is online now   Reply With Quote
Old 11-16-2019, 07:20 PM   #394
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Amazing! Great work guys. Happy for you. Let us know how the maiden voyage goes and may there be many enjoyable miles.
Anticipation is already building for your return the ring with the k20 after a well earned break.
Old 11-16-2019, 08:14 PM   #395
LakeAnna
LakeAnna's Avatar
Great looking truck!
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 11-16-2019, 08:30 PM   #396
IronCanine
I'm trying....
IronCanine's Avatar
Thanks...looking forward to your masterpiece rolling out.
Thanks.
Old 11-16-2019, 08:33 PM   #397
IronCanine
I'm trying....
IronCanine's Avatar
Thanks Pete. And thanks for all your help. It'll be a while yet before we start the K20. I'm mailing this back to you...I think it's your turn now. I see you still collecting parts.
Old 11-16-2019, 08:55 PM   #398
IronCanine
I'm trying....
IronCanine's Avatar
Speaking of thanks....the resource that this board is to us cannot be overstated. The generosity of spirit, support and collective knowledge is extraordinary. Learning is one of the best parts of this kind of thing and we learned a lot on this build. Of course we're not completely finished and I'll keep posting here, but I do feel like it's time to say thanks to all of you that helped will parts, info, or a kind word. Thanks OLDYELLOW for putting up with me and for your maniacal commitment to slick paint. And thanks to the mythical Hay Man 17 for finding us a real deal 69 KE SWB to work on.
If I've missed someone I apologize...but thanks to you all:
DeadheadNM
Dirt’s72
FirstOwner69
southern parts
Chipflyer
LockDoc
Roger Koop
uncle
Jaros44sr
Austinjay
2014sierraAT
Ol Blue K20
1rippen6
smbrouss70
1972 Jimmy
72 tigger
CTENTA1
AASmedic
Chulisohombre
JJH Jimmy
4x41971SWB
lks dcvn
rowdy11
tristan
rustytruck50
Sand Wrench
davischevy
72K5CSTDarkOlive
68Gold/white
cebra
chewychevy67
4burbon
Madkidd007
argonaut
Yerboogieman
weim55
1971Stepside
70STOVEBOLT
notsolo
Medina
MDPotter
69CST4x4SWB
1956cameo
402Bowtie
Martyt
68bowtie
70LonghornCST
RCbowtie69
cornerstone
regan wilson
Kronald_70GMC
harrisoncole4
69cam
And thanks to Molly (non-member) for being the best shop dog ever.
Old 11-16-2019, 09:07 PM   #399
Madkidd007
Madkidd007's Avatar
Only wish I had more proper parts to give you, maybe on the next one I’ll have some stuff laying around
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 11-16-2019, 10:41 PM   #400
72 tigger
72 tigger's Avatar
Smile Re: 1969 K10 CST Full Restoration
Another high quality build! You guys are impressive in your level of detail and the speed of the build. I enjoy seeing a truck that looks like it just rolled off the assembly line. Hope you’re able to spend some time riding in it, does your shop dog like going on rides?
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
1969, 4x4, cst, k10, swb
