11-19-2019, 11:42 AM | #1 |
Upper rad support for wider rads?
65 C10. What are others doing for an upper rad support for wider aftermarket rads? Brothers sells a wider one that has been on back order forever. My truck was missing the stock one so I don’t even have one I can widen.
11-19-2019, 11:46 AM | #2 |
Re: Upper rad support for wider rads?
I'm not as familiar with the 65, but on my squarebody I am making mine out of two pieces of L shaped aluminum (L channel aluminum) and a flat piece of aluminum. Pretty simple. Stole the idea from another member here. Not sure if something like that might work for you.
11-19-2019, 12:43 PM | #3 |
I could probably make something but it’s pretty front and centre in the engine compartment so I want it to look nice.
11-19-2019, 05:12 PM | #4 |
This is from member Rich84's build... I believe also a squarebody. Its what convinced me to go this way - I think it looks really clean.
11-19-2019, 05:25 PM | #5 |
Moderator
Aspen in Arizona makes new units.
11-20-2019, 08:27 AM | #6 |
The issue you have with running a wider radiator is the way the inner fenders tie in. They get in the way. There are several bolt in options for the 65 that work just fine. No need to cut a bunch of stuff up.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
