11-19-2019, 08:15 AM | #51 |
Re: Wheel Spacers - Good thing?
From Wheel Adapters USA
-Complete set of 2 with all parts needed for complete installation -Made of Aerospace grade 6061-T6 Aluminum -CNC Machined with 60 degree taper bulge seat lug nuts -Machine pressed high tensile, heat treated studs -Grade A lug nuts -MADE IN USA WITH USA MATERIALS!! Specifications: Thicknesses Available: 1.25" Inch 1.5" Inch 2" Inch Bolt Pattern: 6x5.5 ALSO KNOWN AS 6x139.7 Thread Size: 7/16" studs Center Bore: 108mm
72' JIMMY 454 |
11-19-2019, 06:03 PM | #52 |
I put 1/2" studs on mine. I couldn't find an adapter with 1/2-20 studs and that's one of the reasons I machined my own. I've only found 6 X 5.5 adapters with 7/16 or M14 studs.
