Old 02-05-2017, 12:35 AM   #26
wilkin250r
wilkin250r's Avatar
Re: This Dummy Needs a Headlight Buzzer
Originally Posted by N2TRUX View Post
If your like me and love the look of park lights at dusk, its easy to leave them on.
I suppose it wouldn't be too difficult to design a little delay module that can turn your lights off automatically.
It would be slightly more difficult (though not impossible by any stretch) to design something like modern cars, that would leave the lights on for an additional 30 seconds or so if you turn them off after you turn off your ignition.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 02-05-2017, 12:45 AM   #27
68Timber
I know the pieces fit
68Timber's Avatar
Late 70's and early 80's Caddies had this feature plus they had a really cool headlight chime that sounded like something out of an elevator or hospital. Trouble is, they're a little GM box with multiple inputs that don't easily relegate them to retrofitting into alternate platforms
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-05-2017, 03:17 AM   #28
wilkin250r
wilkin250r's Avatar
Honestly, probably the largest cost would be prototype boards for a circuit like that, adding a small microprocessor and a chime wouldn't significantly increase the cost. You can get a simple 14-pin AVR for like $2.00
Old 02-05-2017, 04:49 AM   #29
hatzie
Moderator
hatzie's Avatar
GM integrated this function into the seatbelt warning buzzer along with the key in the ignition with driver door open buzzer.
The Headlamp warning option is RPO T63.
The "extra wire" in the RPO T63 equipped trucks is from the instrument panel lamps. I believe the ground is from the key inserted switch in the column.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-05-2017, 10:20 AM   #30
Gasasaur
Hello LDO,
Sent you a private message for a dummy buzzer!
Thanks,
Randy
Gasasaur is offline   Reply With Quote
Old 02-05-2017, 10:22 AM   #31
bhc41051
bhc41051's Avatar
I took this route, about 5 minutes start to finish.
bhc41051 is offline   Reply With Quote
Old 02-06-2017, 11:46 AM   #32
N2TRUX
Happy to be here
N2TRUX's Avatar
Details please.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-06-2017, 02:28 PM   #33
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by LDO View Post
over by the gas pedal. it's a panel with a flasher looking thing, this module and another larger module which may be the cruise control. I can take a pic when i get home tonight unless someone else beats me to it.
I found it, but didnt get any pics. It appears to be multi function with a connector for the "convenience reminder buzzer" and the cruise control module.
Articles-
"Refining Sierra"
Old 02-09-2017, 03:51 AM   #34
El Dorado Jim
cool, where did you get those, gm dealer?I got the one from napa, looks different...
El Dorado Jim is offline   Reply With Quote
Old 02-09-2017, 03:51 AM   #35
El Dorado Jim
No sorry, they never had headlight buzzers, not that I'm aware of anyway. Napa has an aftermarket buzzer for a few bucks, I've installed them on both my squares.
I installed one of those on my sons truck, works good...
Old 02-12-2017, 09:18 AM   #36
Gasasaur
Ok, hats off to LDO ! He sent me one of the units he gathered from the junk yard. I plugged it in and voila! The sweet sound of a headlight chime was mine. Yes, the same sweet sound that irritated us in our youth and caused so many of these units to be ripped out long ago. Thanks again LDO.
Old 02-13-2017, 09:00 AM   #37
LDO
LDO's Avatar
No problem. Glad I could help out.
LDO is offline   Reply With Quote
Old 11-18-2019, 11:39 PM   #38
Bob Q
Thanks again to LDO for the tip about the 7-prong buzzers. Got one at the junkyard this weekend for our ‘84 and it now has the headlight buzzer. No more neighbors stopping to tell us the headlights are still on!
Bob Q.
'83 K2500 6.2L
Bob Q is offline   Reply With Quote
Old 11-19-2019, 01:57 PM   #39
kipps
The linked item should work perfect for a 30 second delay of your headlights. It's a rather powerful little item. I used one in designing a 12v school bell system, but have not used it on a truck yet.
Even though it's labeled for 10 amps, I wouldn't run the headlights through it directly. Instead, wire it up to control a relay.
https://www.amazon.com/Timer-Delay-R.../dp/B01HNDOCKK
I realize this is an old post, but I thought someone may still be interested in this.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 11-19-2019, 07:52 PM   #40
ron350
ron350's Avatar
This is how I have a 22535998 chime module hooked up on my 75 C10 to let me know that my lights are still on.
When I open the door with the head lights or parking lights still on the module will chime. I had to hook this up after coming out of stores to find a dead battery because I forgot to turn the lights off.
Run a wire from the door jamb ground switch to pin 3 and over to pin 6 on chime module.
Run another wire from the top plug on the head light switch to pin 7 on the chime module.
The top pin on the head light switch has 12 volts on it when the parking lights or headlights are on.
By using the door jamb switch as ground for pin 3 & 6 the module does not need 12 volts constant power to make a chime.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 11-19-2019, 08:59 PM   #41
VWNate1
VWNate1's Avatar
Post Headlight / Seatbelt / Key Chime
Good deal ! .
The fleet mechanics @ work used to ysnk these out without being asked, many of the drivers were pissed off because they'd forget....
I'm old now so what is there for us DEAF guys ? .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 11-19-2019, 10:06 PM   #42
kipps
Re: Headlight / Seatbelt / Key Chime
Originally Posted by VWNate1 View Post
Good deal ! .
Wire the headlight switch into a relay controlled by the accessory position of the ignition switch. Kill the ignition switch, and the lights go off. I really have no idea why all vehicles haven't done this years ago.
I'm doing this on a complete rewire job I'm doing, because I've never had reason to need headlights without the truck running.
Old 11-20-2019, 11:49 AM   #43
hatzie
Moderator
hatzie's Avatar
My 1984 Subaru GL Hardtop and 1985 GL Wagon killed all the lights and the dash mounted power socket when I turned off the ignition. There was a way to turn the parking lamps on without the key if you wanted to... but durn if I can remember how it was done.
The 70's & 80's Watercooled VW and Audi headlamps would go out but the parking lamps stayed on.
More recent vehicles have automatic headlights. I don't even think about the headlamps on my Impala or my Silverado.
Old 11-20-2019, 02:38 PM   #44
VWNate1
VWNate1's Avatar
Thumbs up Good Idea !
Thanx Kipps ! .
That's a good idea .
I'm a Tech Advisor to many vintage vehicle clubs, mostly oriented towards geezers like me, they're always wanting the buzzer for the headlights, I'll begin suggesting this relay idea instead .
-Nate
Geezer
Old 11-20-2019, 03:27 PM   #45
N2TRUX
Happy to be here
N2TRUX's Avatar
Good deal ! .
i would try one of the factory buzzer first. I installed one in a previous build and was able to hear it. I'm fairly deaf and had no problem hearing the buzzer.
Articles-
"Refining Sierra"
Old 11-20-2019, 04:21 PM   #46
VWNate1
VWNate1's Avatar
Post Stock Vs. Modified
I too would keep it stock if I still had my 1976 GMC 2500 heavy duty fleet rig .
I bought it foe one job, rebuilt it stem to stern, had a nice drive up to the border and back then let it go because it was TOO DARN BIG, I miss it still ~ a 292 CID powered i6 with Muncie SM465 gearbox, heavy duty springs from new, 9,000 GVW .
I was the third owner and when I rebuilt the mangled dashboard I used all the high end factory gauges from junked Suburbans, I even sourced an original Delco AM/FM radio for it .
If only it had been a short bed step side...
The dual fuel tanks were nice too, it didn't use much gasoline but on long trips they came in handy .
In general I prefer stock to modifeid / Hot Rodded because I'm a cruiser who likes basic work trucks .
-Nate
Geezer
Old 03-10-2020, 09:19 AM   #47
Hart_Rod
Hart_Rod's Avatar
Has anyone found a good source for this module? Thanks,
Rob
Hart_Rod is offline   Reply With Quote
Old 03-10-2020, 09:55 AM   #48
TKCR
TKCR's Avatar
Rob
Junk yards, you can get them from the 88 and up trucks
TKCR is online now   Reply With Quote
Old 03-10-2020, 12:03 PM   #49
Hart_Rod
Hart_Rod's Avatar
Thanks!
Old 03-10-2020, 03:21 PM   #50
TKCR
TKCR's Avatar
Thanks!
I’m usually in the yards once the weather warms up. Problem is, I’m after seats and interior parts, and I never get around or forget to grab these. I will try and remember these this year. They are super easy to remove.
