Old 10-23-2019, 08:32 PM   #801
Killer Bee
Killer Bee's Avatar
Re: Suburban and panel finds
from truck find thread
Old 10-26-2019, 12:26 AM   #802
HO455
HO455's Avatar
68 503 green V8 four speed $7900! Sweet! Some assembly required. How much? I don't know its not my Burban.
https://seattle.craigslist.org/sno/c...007116580.html
I have a 1968 2WD Chevy suburban Four-speed bought a brand new motor out of the crate Blue printed balance boarded out to a 383 stroker I have all the build sheets I have all records and receipts Electric feel pump Bought a bigger radiator for the electric fans has Racing cam has high rise Manifold racing headers have a whole bunch of extra parts to finish off Have extra exhaust also Have all racing parts in Motor Hasn’t been started needs a few more parts Assembled call for more information
RIP Bob Parks.
Old 11-07-2019, 12:13 PM   #803
HO455
HO455's Avatar
72 K model BBC 4speed $7000. Not much in the way of photos. If it was mine there would have been more. It would be nice to see the SPID on this one.
https://salem.craigslist.org/for/d/s...013352000.html
1972 Chevy suburban been in my family since 1971. 454. 30 over motor. 2.5 Edelbrock Manifold. 205 transfer case rebuild. Four-speed manual. No carpet. Front bench seat and original back bench seats. New front fenders and doors. Everything straight except for the rockers. No cracks in the glass. Email me for more photographs and information.
RIP Bob Parks.
Old 11-09-2019, 01:04 AM   #804
HO455
HO455's Avatar
Found this beauty on the truck side of the board and I had to repost it. I wish I owned this one.
https://spokane.craigslist.org/cto/d...999069670.html
This is a verifyable low mileage Suburban.
This is a real survivor all the way from 1972.
It is a very smooth driving 4X4 Suburban.
The first and only other owner was the City of Long Beach, Washington.
It was used as an ambulance and a small scale Firetruck.
It was decommisioned by them in 2003 and eventually sold to the only other owner.
It has only 47239 original miles and a clear title.
It has the original factory installed 350 V8 engine
and the Three-speed Turbo Hydra-matic automatic transmission.
It also has a factory installed posi trac/limited slip rear end.
A Dealer sales brochure is also included.
Everything works.
If you have any questions, please call 509-two37-one8six7 Ask for Mike
RIP Bob Parks.
Old 11-09-2019, 01:06 AM   #805
mrtoni
It’s a beaut. Been for sale At least 6 months
mrtoni is offline   Reply With Quote
Old 11-09-2019, 11:32 AM   #806
CG
BlahBlahBlah
Sure looks good in the pictures. But Longbeach is on the ocean, I wonder if this thing has any rust issues you cant see in the pics?
Old 11-23-2019, 03:01 PM   #807
HO455
HO455's Avatar
67 panel $11000. Not mine! Lots of purchase options!
https://portland.craigslist.org/mlt/...011411022.html
1967 Chevrolet C-10 panel. Fresh 400 small block with Edelbrock aluminum heads, intake, and AVS-2 carb, solid lifter cam ,roller rockers. Saginaw car 4 speed, new clutch , 16 inch rally wheels, new truck tires. Includes delux CPP front disc brake conversion kit with dropped spindles and master cylinder and booster not installed. This a very rare C-10 panel. body is good with some rust, all doors are in very good shape. Has custom interior and a tilt column. This a very good value for a very rare truck. No text please. Call or e-mail only. It is also for sale less motor for $8,500.00, or less motor and trans for $7,500, or less motor and trans with stock tires & wheels with poverty hub caps $6,50000.00
RIP Bob Parks.
Old 12-01-2019, 08:46 PM   #808
HO455
HO455's Avatar
72 350 four speed K model with a nice rack! $9000. Not mine. It was definitely a working mans truck, just look at the drivers arm rest.
https://seattle.craigslist.org/est/c...028406694.html
1972 Suburban 4x4
Manual 4 speed transmission rebuilt 1 year ago
New master cylinder
New wheels and tires
New performance distributor
New Holley off-road carburetor
New suspension lift and tires and wheels from les Schwab
New duel exhaust from Midas
RIP Bob Parks.
Old 12-06-2019, 11:17 PM   #809
HO455
HO455's Avatar
Big Orange 71 $13000. Not my truck.
https://seattle.craigslist.org/tac/c...032890244.html
Up for grabs is a super rare 1971 GMC Suburban 3/4 ton 8-lug "2500 Super Custom" "3-door". This is 1 of 374 built for this year and model from the Van Nuys build plant.
This is an original 4x4 model and is not a conversion.
Classic setup that is all original. 350 small block (4-bolt main) with a turbo 350. Truck starts right up without issue!!! Has a NP205 transfer. Running gear is all original except for the drive lines that had to be lengthened or rebuilt professionally by Drivelines Northwest in Tacoma to accommodate the 6-inch (all spring-no blocks) Skyjacker lift.
***Pics are from when the lift was being installed which explains the blocks behind the tires.***
Speaking of tires, they are Goodyear MTs commonly found on military Humvee's and are 37x 12.5 by 16.5. Tires have about 90% tread and are matched to era correct slotted mags. Have matching spare tire on steel rim that comes with it.
And the list goes on... stainless steel dual exhaust leading out to turbo mufflers. Under the hood is an Edelbrock 650cfm carb with aftermarket intake manifold.
Truck runs and drives great for almost being 50 years old. There are no issues to speak of except for the transfer case leaks a little. Truck runs, drives, and stops as it should.
This truck has barn doors in the rear and was built for the trails in mind and features bed liner from "Monstaliner" on the inside and out. This could be removed with a wire wheel and some elbow grease, but it would be a shame as a lot of work went into this and people really like the look of it. Also has replacement Mile Marker hubs as well. The running gear and the truck as a whole is built like a tank and is SOLID!
The truck is also RUST FREE. When The body work was being done all rust was removed and replaced with patch panels (quarter panels door seals etc.) Due to all the rain and the weather of the Northwest, and prior to the application of the bedliner, two coats of rust inhibitor was sprayed on the entire inside and out. I have pictures of the restoration process if wanted/needed.
The interior features aftermarket bucket seats that are REAL leather. The rear seat was refinished to match in vinyl. There is enough room to seat 6 along withseat belts.
A full sound system that was (wired correctly) is tucked out of veiw under the rear seat. It includes a Clarion CD player upfront along with Alpine speakers in the front and rear. Alpine amplifiers finish off the system. MTX 10.5 subs are enclosed in the rear storage boxes. The sound system alone was $1,000 and it sounds awesome!
The only thing that has not been done yet is the headliner that can be purchased for about $300 from Classic or LMC. I was going to do a custom headliner but now I'm selling it, and will forgo this step.
Okay so why am I selling... This was my dream truck for years and selling it will be bitter sweet. The truck has been in my family for about 12 years and I bought it from a guy out of Vancouver Washington with hopes of a full restoration. I got close but the truck no longer suits families needs, as I need to be able to pull a gooseneck trailer and need more reliable "trip type vehicle." Got a new diesel truck for this purpose and I don't need two rigs. This truck runs and drives out great but it's not really suited for long trips. It is better suited for shorter trips for hunting, camping, weekend activities and car get togethers.
The truck is paid off since I bought it and cost me what I put into it with gas and insurance. It will sit in my driveway until it is sold. The only issue it causes me is my wife yells at me to get it sold. It also has collector plates so I don't even have to pay tabs. Title is clean and in hand!
Please, serious inquiries only! Truck is well worth what I am asking so please do not lowball me as I will not even respond. Price is firm! No offers from Nigeria or mail order will be accepted. Person will have to be on-site in person and with financials squared away either with cash on hand or a reputable bank transaction. Tire kickers will be turned away. Test drives will be by appointment only during daylight hours.
Thanks for looking,
Josh
RIP Bob Parks.
Old 12-08-2019, 08:21 PM   #810
CG
BlahBlahBlah
Burly looking burb for sure. But the entire thing sprayed with bed liner is really (in my mind) going to shrink his audience.
Old 12-08-2019, 08:27 PM   #811
HO455
HO455's Avatar
I agree. I've seen too many Jeeps and Broncos using bed liner to replace rotted sheet metal.
RIP Bob Parks.
Old 12-14-2019, 09:19 PM   #812
HO455
HO455's Avatar
68 K model 50th anniversary edition! $10000. Not mine, but it sure looks interesting! I just wish there were more pictures.
https://eugene.craigslist.org/atq/d/...037140258.html
For sale one of 48 made gold 50th anniversary 1968 4X4 half ton Suburbans.
New 327 engine with aluminum heads newer NP205 transfer case and transmission removed the rockwell that have issues. 4.11 gearing. Original Chevy 15" X 8" black powder coasted steel rims off a military blazer, New Blisten shocks with new 4" lift kit BFG 31" with ok tread tires interior needs some loving but a pretty solid truck for being 51 years old. Asking $10,000 OBO not sure what street value on these is but i know hard to come by in good condition.
RIP Bob Parks.
Old 12-15-2019, 12:42 PM   #813
CG
BlahBlahBlah
I think that is Mt Man Chads burb. I saw where he is getting out of the 67-72's
Old 12-20-2019, 10:19 PM   #814
Average Joe
Average Joe's Avatar
Yep
MtManChads.
Beautiful Burb. He either had a build thread on here or some detailed posts on it before he lost interest. Wish I had the coin for it. Quality work
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 12-21-2019, 03:39 PM   #815
HO455
HO455's Avatar
Not much left going by the photos and no prices either. It's not mine so I have no idea if it is a good deal or not.
https://seattle.craigslist.org/kit/p...042251974.html
1970 Suburban floor, frame, rear end, seats.
RIP Bob Parks.
Old 12-22-2019, 09:48 PM   #816
LockDoc
The Older Generation
LockDoc's Avatar
Very unusual for Iowa. About 40 miles North of me.
https://desmoines.craigslist.org/cto...031725956.html
LockDoc
Leon
Old 12-23-2019, 12:58 AM   #817
3757chevy
3757chevy's Avatar
Here's a nice 69 listed in Denver. https://denver.craigslist.org/bar/d/...036571995.html No price listed
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 12-24-2019, 07:03 PM   #818
BAD1916
LockDoc
For 15k you would think it could be washed prior to posting pics...
BAD1916 is offline   Reply With Quote
Old 12-24-2019, 10:02 PM   #819
LockDoc
LockDoc's Avatar
Yeah, sometimes people just blow my mind. I don't think he will ever get that being a project, but I have never seen a cleaner one as far as rust. If he still has it after the holidays I will go look at it to see what all of the extra pieces look like.
LockDoc
Leon
Old 12-24-2019, 10:42 PM   #820
HO455
HO455's Avatar
Especially since you could buy MtnManChad's Burban and have an extra 5000 to drive it home with.
RIP Bob Parks.
Old 12-24-2019, 11:02 PM   #821
BAD1916
I agree. That thing is awesome and 4 wheel drive.
Old 01-04-2020, 10:27 PM   #822
HO455
HO455's Avatar
68 in what was a 503 green custom, but no SPID photo to confirm. Says V8 but no displacement listed. $4800. It could be worth the money but having never seen the truck I have no idea as to the extent of the rust mentioned.
https://seattle.craigslist.org/skc/c...048121335.html
I have 7500 into it over the last year and a half. New brakes, fuel system, exhaust, HEI. Plus numerous other parts. Does have rust in the rockers and infront of and behind rear tires. Saying that though, it is not bad
RIP Bob Parks.
Old 01-10-2020, 06:42 PM   #823
HO455
HO455's Avatar
Says GMC 68 with 6 in a row and a four speed. $2900 No mention of rust so who knows not me for sure since it's not mine. I have to admit that the first line of the ad sure hits close to home.
https://portland.craigslist.org/clc/...053207339.html
I thought I needed this but turns out I dont,
It's a pretty strait 68
Two wheel drive
Very minimal rust for age
I think I have a rear seat for it
Still retains the rear seat heater
6 cylinder that runs good but may have a head gasket going
Manual 4 speed tranny
Nice headliner
Fairly original a with no modifications
Nice tires
Everything works as should except the gas tank,I have not ventured into that,could be fine
Barn doors
I have the protecto plate and owners manual
It's a truly awesome rig that's very restorable,better shape than most.
Gives me a smiling face every time I drive it.
Please email due to phone solicitation I rarely answer my phone anymore
And please be serious as I am, I am diligent with returning emails.
I'm looking to get 2900 out of it but willing to entertain offers but no lowball
I have covered space to store it if I need to keep it so I'm not in a pinch
I have recently aquired a 4x4 suburban so I've lost vision in this one
Thanks for the interest
RIP Bob Parks.
Old 01-11-2020, 10:54 AM   #824
HO455
HO455's Avatar
Bringing this gorgeous K over from the pickup side.. Bid well! Not mine because if it was it would be for sale.
https://bringatrailer.com/listing/19...et-suburban-2/
RIP Bob Parks.
Old 01-15-2020, 03:44 PM   #825
HO455
HO455's Avatar
68 GMC with a V8 and 3rd row seat for a reasonable price $2700. Some one should save this one. Not mine..
https://seattle.craigslist.org/tac/c...054809066.html
1968 GMC Suburban from AZ so not very rusty. 350 with 400 trans power steering power brake. Runs and drives pretty good! 2700 dollars.
I was going to build a 4-door truck so also have extra third door and door frame along with an extra b-pillar.
RIP Bob Parks.
