10-17-2019, 05:38 PM | #176 |
Re: It's my turn, 47 S10 build
The guy I bought them from said they were from a police car. I would believe it, they aren't light. 15x7, 5on5.
Fast, Cheap, Reliable. You may pick two My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723 |
10-17-2019, 05:59 PM | #177 |
I have used a similar shaped part from a muffler clamp before for the stab bar mount, less work. sometimes gotta tack a piece of flat bar onto it for extra width though.
nice progress, keep the pics coming. |
10-17-2019, 06:36 PM | #178 |
That's the main reason I like looking at build threads and car shows. There is usually multiple ways to get the same result.
10-17-2019, 07:10 PM | #179 |
Cautrell05, thanks for the pics...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
10-17-2019, 07:12 PM | #180 |
No problem
10-18-2019, 01:37 PM | #181 |
Started working on the mounts for the fenders and radiator support. Seeing a couple different ways to do them from looking at other builds and mounting off of the side of the radiator support to the top of the S10 frame seem to be the easiest. I wanted to stick with an OE style bushing and mounting on the sides would eliminate the need for the braces under the hood. I looked around and found these on summit website made by resto parts. on their website they show them discontinued but there's a factory application so that helps if I ever need a replacement or want to buy another set. There's two bolts side by side near the bottom of the radiator support and one farther up that I used. I used 1/8x3 all the way around. Drilled a 1 inch hole in the bottom piece for the bushing and on the three holes for the side I welded the spacer on the back to clear the ridges in the inner fender. A couple gussets up two sides to keep it from folding and that was about it. Pretty simple. Nothing too elaborate.
10-18-2019, 04:20 PM | #183 |
Thank you.
10-21-2019, 07:55 AM | #184 |
Small amount of progress. Have the upper mount bolted in and started cutting out the piece for the lower amount. I don't have a bender that will gracefully bend 3 in by 1/8" So I cheated and cut a notch on one side, been it where I need and I'll just weld a gap shut. Need to trim it down a little bit so it fits better on the frame and then move over to the other side.
Fast, Cheap, Reliable. You may pick two My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723 Last edited by Cautrell05; 10-21-2019 at 01:26 PM. |
11-22-2019, 11:54 PM | #185 |
I had been looking into options for the wipers for a while. They make kits but I didn't really want to spend that much. Also, I wanted to use the GM wiper switch on the column. All the conversations say they won't work with the GM switch. I took it as a personal challenge.
This is the motor I used. Wexco 4R Wiper Motor-4R2.12.R110D... https://www.amazon.com/dp/B00G1G1FXI...p_mob_ap_share It's a semi universal 2 speed self parking motor that looks identical to what all the conversion kits come with. I used a piece of 3/4" tubing welded to some 1/8"x1 inch strap but you could use angle iron also. The rubber grommets are optional, none of the kits I saw came with them but I wanted to try and help keep noise down. I still need to make a small bracket to hold the other end of the motor steady but that's an easy one. I bought a 1/2" collar from Menards for about $2.50. It measures .505 inside. The splines on the motor are about. 550. Ran a 17/32" drill bit through it and then took a small triangle file and cut splines on the side opposite of the set screw. After that I took a Dremel and a grinding Stone and opened the rest up until it was just big enough to for over the splines of the motor. I reused the wiper arm of the original vacuum motor. Just ground the end of the shaft where it was staked and then pulled it off. Centered it on the collar and welded it on. That's really about it too mounting the motor. It can point down and hang between the column brace and cowl vent bracket or point to the left above the column brace. Still clears the defroster ducts and the cowl vent linkage. Just watch when you make the mount. Try and keep the wiper arm the same distance from the mounting holes as the original motor and the same height when you look from the end. That should help keep the wiper linkage from hitting stuff. The wiring wasn't that bad to get worked out. The factory GM system uses constant power and switches the ground for high and low speed. The conversion motors are grounded all the time and switch the power between the park circuit, low speed and high. Wiring them backwards isn't a good option. Tends to let the smoke out. For the two speed GM switch without delay there is three wires going to the motor. Low speed, high speed and park. You need power to one of the three. There might be a fourth wire if it doesn't ground through the case. What I did was use two 5 pin relays and use the ground signal from the GM switch to control them. One relay switches between low and park. The other relay switches between high and the first relay. Hopefully the diagram makes sense.
11-22-2019, 11:56 PM | #186 |
Some more pics of the conversion. More to come
11-23-2019, 12:17 AM | #187 |
Anybody ever thought about using a wiper set up from industrial equipment that runs on the roadway? They need wipers and are set up really basic, like a rubber tires backhoe. It's what I used on a rail buggy years back. Easy to find, mount and wire. Swap a lever on the end of the shaft instead of the single wiper arm they usually have.
11-23-2019, 01:26 AM | #188 |
That was some of the applications for the motor I used. It crossed to several John Deere numbers and I think bobcat also.
11-23-2019, 12:05 PM | #189 |
One of the better conversions I'v seen through the years. I did one on my 49' years ago and I'll have to dig up the part number, but the motor was less than $100, although different than yours. For $170 bucks you can get one from classic parts with a switch. (imported) The usa made motor is 230 which is a bit of a jump. The wiper swap cost was always a nail biter for me early on in my building experience. Though well worth the money, its still something most of us guys on here wanted to tackle or see whom else can do it on the cheap. I think with more sourcing on motor and your setup, it can catch on quick. Great job. Here is a pic of mine. I had shannonpanel (ya'll remember him on here!) make me the milled out adapter he designed.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
11-23-2019, 12:59 PM | #190 |
That's a nice looking bracket. I need to get some new arms and actual wiper blades and see how my travel is. The nice part about this motor is that the travel is adjustable internally. I have to pull the motor out of the truck to do it but it's a really easy process on the bench. This one was about $110 with tax.
Like I said earlier, I wanted to use the GM wiper switch so paying for the kit that came with a harness and switch I wasn't going to use didn't appeal to me. The big thing that I wanted was to have all the factory features of the gm switch work just like original. Wash, mist, low, high and delay. It took some wiring changes to make it happen but I managed to make it work. I just need to get the wiring diagram for the delay wiper switch on something shareable.
11-24-2019, 11:27 AM | #191 |
hello
nice work on the truck. your ideas to solve Problems are reallx grate. nice work on the steering system. so Long Arnd |
11-24-2019, 12:50 PM | #192 |
nice tech on the wipers, I wonder if its the same for 98+?
11-24-2019, 05:17 PM | #193 |
I'd have to look up a wiring diagram. What wiper switch were you thinking?
11-25-2019, 03:12 AM | #194 |
I use 98+ s10 on all my swaps. current one is a 2001, I like using the whole shebang, HVAC, distributed electrical system, drivetrain. every part of the buffalo.
11-26-2019, 12:56 AM | #195 |
Kinda bouncing around a little bit depending on my schedule. Took a little time this past week and got the front bumper mounted. I used 1 1/2x1/4" strap for all four. I don't have a heavy enough vice at home to bend it accurately so I cheated and cut 2/3 of the way through where I wanted the bends, shaped as needed and then added a couple heavy tack welds to hold it for now. I'll finish weld them when it's apart. Right now it's held on with 4 #12 self tapping screws. They worked well to hold it in place for mock-up and my pilot holes are already drilled this way.
I ended up with a white bumper from being cheap. Searching through Amazon and eBay they were all either chrome or black primer. The painted one from LMC was $6 cheaper so I ordered that one. Turns out the painted one from LMC is white. Thank God for spray paint.
12-04-2019, 11:34 AM | #196 |
ha, good tip on cutting the strap. I have built rear brackets from 11ga (vice limitation also) but they are mostly aesthetic, 1/4 is a better choice especially on the front. I think the oem brackets are 3/8!
nice work!
12-04-2019, 11:51 AM | #197 |
Thanks. I was really happy with how well they turned out.
12-04-2019, 11:59 AM | #198 |
With the radiator support mounts built and the front bumper on it was a good time to pull the front clip for the winter before I have to deal with snow outside. I normally use my engine hoist but it was buried in the back corner of the garage and I didn't feel like digging it out. I picked up a hoist for the tractor a while back that works great for this stuff. Got it put on my thrown together car and it fits well between the camper and the garage. It'll get snowed on but it's out of the wind and away from vehicles. With the front end accessable now the next step is finalizing the steering, then on to the pedals and the transmission linkage.
12-06-2019, 11:24 PM | #199 |
This week I started reworking the steering shaft. The first version was functional but it sat really close to the manifold and had the bottom of the column kicked out to the point it looked off. The first version used the ranger lower steering shaft adapted to the gm column. Problem is that the slip yoke and the U-joints are kinda fat. To do it right would need 3 joints and a support bearing. Before I spend the money on that I figured I'd try something cheaper. I cut the end off the ranger steering shaft, combined that with a piece of 1 inch 1/8" tubing and a short piece of double D shaft and made an extension for the input shaft of the rack. That combined with a different steering shaft pushed the lower joint out far enough to get decent steering shaft clearance with the column lined up better.
12-07-2019, 12:15 AM | #200 |
The steering shaft is a bit of a Frankenstein job. The main part of it is actually from a 2007 Mercedes SUV. One of the younger kids at work stripped out the pinch bolt so they put a new one on. There's nothing really special about it other than it was a free, low milage slip shaft. The lower half fit the smaller double D shaft with a little grinding. The other half was nowhere close to fitting the gm column as expected. Originally I was just going to cut the end off weld the other one on but then I started looking at the actual steering U-joints. The more I looked at them the more they looked pretty close in size. Half hour at the vice and I had the Mercedes and GM joints out. Both measure exactly 15mmx37mm. Reused the Mercedes joint because it was newer and it pressed in to the GM yoke just like it was made for it. I would have never guessed that would work. In the future if I ever need to replace the steering shaft I'll just buy two joints and a double D slip shaft but for now I have a total of 0 dollars in the upper shaft. Can't complain there.
