Old 11-08-2019, 09:27 PM   #101
Gregski
Gregski's Avatar
Re: A '54 named Busty
cut out the previous fuel tank crossmembers and used sum 2x4s to moc things up
Gregski is offline   Reply With Quote
Old 11-10-2019, 03:47 AM   #102
Gregski
Gregski's Avatar
went shopping for some leaf spring plates with shock brackets on 'em and scored these beauties off of a 2002 Dodge Durango, this eliminates the need to weld shock brackets to the axle itself
Old 11-10-2019, 07:10 PM   #103
dsraven
chevy s10 blazer has the same brackets. got a set collecting dust right now.
dsraven is online now   Reply With Quote
Old 11-10-2019, 07:17 PM   #104
Gregski
Gregski's Avatar
What year kind sir? and are they the rear mounted, I'm sorry but I'm a total ignoramous and don't know all the configurations.
Old 11-10-2019, 07:31 PM   #105
Gregski
Gregski's Avatar
I'm kinda liking what I'm seeing in this Hot Rod Relocating an In-Cab Fuel Tank – No More Fumes mounting wise, though I realize it's a different tank on a different gen truck, ha ha
Old 11-11-2019, 03:02 AM   #106
jocww
looks good
My build a 49 5 window ls1 4l60e on a TCI chassis
http://67-72chevytrucks.com/vboard/s...d.php?t=754926
My travel blog
The Wong Winding Road-Adventures of The Chinese Cowboy
https://thewongwindingroad.blogspot.com/
jocww is offline   Reply With Quote
Old 11-11-2019, 07:07 PM   #107
Gregski
Gregski's Avatar
Originally Posted by jocww View Post
looks good
thanks, getting there, slowly
Old 11-11-2019, 07:09 PM   #108
Gregski
Gregski's Avatar
got them 2002 Dodge Durango leaf spring plates bolted up, fit perfectly, so happy, gonna moc 'em up and weld in a 2x2" square tubin as a crossmember to mount them up to
Old 11-11-2019, 07:11 PM   #109
Gregski
Gregski's Avatar
hit S&K Steel here in Sacramento California for sum remnants, $80 bucks for everything I need to mount the fuel tank and the rear shocks
Old 11-13-2019, 11:15 AM   #110
dsraven
sorry gregski, busy doing a reno and working shift. here is a link to what the s10 brackets look like.not that you will need them since you have a set already. maybe help somebody else though.
https://www.ebay.com/itm/Up-Rated-Re...-/121910067221
Old 11-13-2019, 11:18 AM   #111
Gregski
Gregski's Avatar
appreciate it, thank you
Old 11-13-2019, 11:20 AM   #112
Gregski
Gregski's Avatar
yup its pretty much like that, I'm sure some of youz can relate
Old 11-14-2019, 10:22 AM   #113
8man
My answer for "what year is your Cherokee Chief?" "Which part!"
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 11-15-2019, 12:15 AM   #114
nvrdone
I get the same look when they ask me what vehicle im working on.
My reply: '49 chevy 3100 pickup, built 327, m21 4 speed, 12 bolt with 3:55's and a pine sentened air freshener.
nvrdone is offline   Reply With Quote
Old 11-15-2019, 10:45 AM   #115
Gregski
Gregski's Avatar
Ha, ha, luv it, in my case the AutoZoner would follow up, is that Ponderosa Pine? hee hee
Old 11-19-2019, 11:50 AM   #116
Gregski
Gregski's Avatar
pretty disappointed in this rollpan I got off of Amazon, it looked all stamped and such, but it aint, looks like it's half a dozen pieces tacked together every two to three inches or so and crooked at that
Old 11-19-2019, 04:58 PM   #117
dsraven
seems like you couldda built that yourself and made it look better. you try to save some time.....
Old 12-06-2019, 06:31 PM   #118
65Robb
looking good my friend!!
65Robb is offline   Reply With Quote
Old 12-06-2019, 07:00 PM   #119
Gregski
Gregski's Avatar
thanks appreciate that, it's a tough build
Old 12-06-2019, 07:04 PM   #120
Gregski
Gregski's Avatar
so my tires finally showed up, it was kinda wierd for a few months Amazon would not ship them to my house, nor would they allow me to ship them to a store like Sears of Pep Boys, anyway got sum Cooper Cobras 245/60-R15s [pronounced: "meats"] in a nod to the 70s
I wanted to go bigger rims but couldn't find the proper offset, also had to go with this size to keep the emergency cables from rubbin' on the rear tires like they was on the wheels that came with the truck
Old 12-06-2019, 07:05 PM   #121
Gregski
Gregski's Avatar
can't wait to do a one wheel peel on these beauties
FYI got a less beat to sheet front fender in the shed waiting to be put on there come summer time
Old 12-06-2019, 07:09 PM   #122
Gregski
Gregski's Avatar
also replaced the 12" Grant like wheel with this 14" Grant(ish) wheel since I don't recon this is the stock '54 steering column so my stock steering wheel can't mount up to it (kinda sucks)
gonna use an acorn center nut eventually and three hex head bolts to make it look nicer, hewk may even throw a horn button on it some day
Old 12-12-2019, 10:02 AM   #123
Gregski
Gregski's Avatar
happy with the way the tank mounts turned out, I was able to make use of the stock crossmember
I did eventually cut off the over the axle exhaust pipes and will have to redo them to clear everything again - but that's all part of the Hot Roddin' game, two steps forward one step back (on a good day)
Old 12-12-2019, 10:05 AM   #124
Gregski
Gregski's Avatar
removed the stock outward facing upper rear shock mounts by grinding some rivets and plan on making a full length upper shock mount crossmember
noticed something interesting, wish I snapped a pic before removing them, but notice how the little bracket has four holes in it, but only three went through the frame, hmmm?
Fun Level = 0
Old 12-13-2019, 05:14 AM   #125
vintovka
vintovka's Avatar
I did eventually cut off the over the axle exhaust pipes and will just make them exit out before the axle, not a huge fan of that but just trying to make my life easier and not blow myself up
If you mean down before axle you may really regret it. I tried it and produced a drone that gave migraines. Even shooting out to side would be better
vintovka is offline   Reply With Quote
