Old 11-05-2019, 10:09 PM   #1251
f.monroe
f.monroe's Avatar
Re: off it goes
Originally Posted by Hammered 77 View Post
Thanks for the reply. All that I've ever come across, including mine, have had pull straps.
Rick
If I remember correctly Cheyenne trim level would have trim rings without door pulls. Silverado trim level added the door pull straps.
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 11-06-2019, 07:03 PM   #1252
CHROMAHOLIC
CHROMAHOLIC's Avatar
Re: off it goes
yeh, I thing you're right
CHROMAHOLIC is offline   Reply With Quote
Old 11-16-2019, 06:03 AM   #1253
CHROMAHOLIC
Re: off it goes
^^^^think
Old 12-08-2019, 08:01 AM   #1254
CHROMAHOLIC
Re: off it goes
So I have been holding off on posting pics of the motor in my truck just in case I had made it to Sema. But seeing as that never happened this year thought I'd let you see what we have been working on...
Old 12-08-2019, 08:04 AM   #1255
CHROMAHOLIC
Re: off it goes
inner fender install, getting lower parts of headers wrapped to keep heat away from paint...better safe than sorry
Old 12-08-2019, 08:06 AM   #1256
CHROMAHOLIC
Re: off it goes
Wilwood install, along with steering shaft cover
Old 12-08-2019, 08:38 AM   #1257
kipps
Re: off it goes
I was definitely taken aback by the white and black engine! But I really like it!
Do you plan to remove the "wilwood" name from the master cylinder? It seems kind of glaring. Possibly paint the master cylinder lid in white?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 12-08-2019, 09:49 AM   #1258
CHROMAHOLIC
Re: off it goes
Thanks man...we talked about Chevy Orange but it wasn’t period correct for this year of truck. From factory motor would of been blue which was definitely out with my colors. Then we talked brown to match interior which would of been cool but I didn’t want a ton of polished items in the motor so the brown with all black wouldn’t of had the wow factor...which by process of elimination brings us to White. I’m a neat and tidy detail freak so will have no issues keeping it clean, the motor has been fired and there’s not a drip anywhere.😃
Old 12-08-2019, 09:32 PM   #1259
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: off it goes
Absolutely stunning.
Keith
Convert to disc brakes.
Old 12-08-2019, 10:20 PM   #1260
trixter99
I have no time for this
trixter99's Avatar
Re: off it goes
I saw this on Kens IG page the other day but didnt think it was your truck because I didn’t see the cowl vent screens. I just noticed the bolt holes for them now. Your truck is bloody amazing.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 12-09-2019, 05:07 AM   #1261
CHROMAHOLIC
Re: off it goes
thank you so much guys
Old 12-10-2019, 03:39 PM   #1262
daddyjeep
daddyjeep's Avatar
Re: off it goes
Good call on the white. It is certainly outside the norm and fits the truck well.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 12-10-2019, 08:49 PM   #1263
Sabaka454
Sabaka454's Avatar
Re: off it goes
The white looks badass. Beautiful
Sabaka454 is offline   Reply With Quote
Old 12-10-2019, 09:39 PM   #1264
CHROMAHOLIC
Re: off it goes
thanks
Old 12-10-2019, 10:09 PM   #1265
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: off it goes
Sorta surprised the master cylinder didn't go in the dash or floor.
KQQL IT is online now   Reply With Quote
Old 12-10-2019, 10:35 PM   #1266
CHROMAHOLIC
Re: off it goes
no, still trying to keep it somewhat stock looking but in a much cleaner simpler way. I think sometimes the firewall can be to plain and bare looking if it has nothing on it
Old 12-12-2019, 11:27 AM   #1267
SCOTI
SCOTI's Avatar
Re: off it goes
Agreed. Same with tailgates using aftermarket flat panels....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-12-2019, 12:09 PM   #1268
CHROMAHOLIC
Re: off it goes
Exactly, some can look to plain...and then some guys can get to crazy with a bead roller and make stuff look to overdone. Just trying to stay somewhat in the middle
Old 12-13-2019, 10:17 AM   #1269
SCOTI
SCOTI's Avatar
Re: off it goes
Make it look like nothing has been done when a bunch has. You're too focused on the fact of how/why everything seems so tight & well fit that it takes someone telling you or several inspections to NOTICE the changes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-13-2019, 11:18 AM   #1270
CHROMAHOLIC
Re: off it goes
Exactly
Old 12-14-2019, 11:40 PM   #1271
CHROMAHOLIC
Re: off it goes
Luckily my buddy owns a Hot Rod Upholstery Shop and he is just finishing up my seat and that will conclude all the interior, I kept it clean and classy...I think less is more on interior, just did a dark brown Relicate Leather with a tooled insert to match the door panels. Also decided to do something with the interior handles, a little sand and a quick polish brought them to life
Old 12-14-2019, 11:45 PM   #1272
jocko
jocko's Avatar
Re: off it goes
Beautiful work! And just think how easy it will be to narrow down where the oil leaks come from! Would never have even thought of a white engine - it looks gorgeous.
Old 12-15-2019, 07:10 AM   #1273
CHROMAHOLIC
Re: off it goes
lol,
motor has been fired....not a drop or leak
Old 12-18-2019, 09:59 PM   #1274
CHROMAHOLIC
Re: off it goes
seat is all finished up
Old 12-18-2019, 10:45 PM   #1275
lolife99
lolife99's Avatar
Re: off it goes
That seat is amazing.
Keith
