Old 10-11-2019, 07:44 AM   #26
Re: Led frount turn signals/park lights for GMC?
I better hurry up and send these. I can't wait to see them done. Clear lenses? My originals are getting pretty close to that!
Old 10-14-2019, 07:14 PM   #27
71gmcC15
71gmcC15's Avatar
Got all the other leds Installed a couple of days ago. Figured I'd post a vid up here. Oilve is now put away for the winter. Other wise I would just show some pictures. https://youtu.be/nmTLkR-0obk
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 12-03-2019, 09:48 PM   #28
Robznob11
Robznob11's Avatar
Here they are boys! I ain't gonna lie it was a bit of a challenge...they have to have mounting tabs to install and be secure. But they look awesome! Check out the video
Watch "67-72 GMC front LEDs custom made to order!" on YouTube
https://youtu.be/CY7xWsYr-Sk
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 12-03-2019, 09:50 PM   #29
Robznob11
Robznob11's Avatar
Couple more!
LED TAILS
Old 12-03-2019, 10:00 PM   #30
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Led frount turn signals/park lights for GMC?
Just saw the video good job sir!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-03-2019, 10:02 PM   #31
Robznob11
Robznob11's Avatar
Thanks Andy!
LED TAILS
Old 12-03-2019, 10:12 PM   #32
Way to go brudda! You da man. In all seriousness, Rob, you've done a fantastic job.
Old 12-03-2019, 10:55 PM   #33
Robznob11
Robznob11's Avatar
Thanks sir!
LED TAILS
Old 12-03-2019, 11:03 PM   #34
Andy4639
Old member
Andy4639's Avatar
Talking Re: Led frount turn signals/park lights for GMC?
You know I'm going to want some 68 Tail lights and front parking lights for the step side right!
Old 12-03-2019, 11:12 PM   #35
Robznob11
Robznob11's Avatar
Lol, hit me up when you get ready, im fixen to have to reorder supplies...i been busy the last month 😁
LED TAILS
Old 12-03-2019, 11:54 PM   #36
68 P.O.S.
Those look fantastic Rob! I almost wish I had a GMC to match the tail & reverse light I bought from you lol.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-04-2019, 12:12 AM   #37
Robznob11
Robznob11's Avatar
👊👊👊👊 thanks bro!
LED TAILS
Old 12-04-2019, 12:26 PM   #38
71gmcC15
71gmcC15's Avatar
They look so good. I'm pumped now. Asome jon as usual rob.
Old 12-04-2019, 04:46 PM   #39
BlueBoy72
Active Member
Front lights are looking good!!!!
I sent you a PM about front and
rear lights for my GMC.
Thanks.
BlueBoy72 is offline   Reply With Quote
Old 12-04-2019, 07:20 PM   #40
BlueBoy72
Active Member
Front and rear assemblies ordered !!!
Old 12-09-2019, 10:01 PM   #41
71gmcC15
71gmcC15's Avatar
Got the first set in the mail today. Can't wait till spring when I can put them in. I did some bench testing and they are much briter then led replacement bulbs. The plugs a real tight fit. But does fit.
Old 12-09-2019, 10:28 PM   #42
71gmcC15
71gmcC15's Avatar
Great now I need a new plug and from what I'm told you can't get them new.
Old 12-09-2019, 10:43 PM   #43
Robznob11
Robznob11's Avatar
I figured it would be tight because of the way the socket fits in. Glad you like them!
LED TAILS
Old 12-10-2019, 08:27 AM   #44
Tight is good. The little harnesses need to be found used. Check the parts board. The aftermarket treats GMCs like their red headed step child. Thanks to Rob they're being well treated in the L.E.D. lighting area. Now who can make these light harnesses? I never checked, is the plug the same as Chevys, just different length harness?
Old 12-10-2019, 11:54 AM   #45
Andy4639
Old member
Andy4639's Avatar
You should be able to use a genric 2 wire hook up in it if you take care taking it a part.
Yes it says Ford, but it also says:
Double Contact Socket Assembly.
Fits 11/16" (17.5mm) Hole.
Replaces GM #88860428.
Replaces AC/Delco #LS126.
Uses bulb #198, 1016, 1034, 1154, 1157.
https://www.wiringdepot.com/store/p/...BoCJQ4QAvD_BwE
Old 12-10-2019, 02:21 PM   #46
71gmcC15
71gmcC15's Avatar
That probly would work but not shure how it comes apart. I now whare I can another plug so I'm not to worried about it. Can't drive it till spring anway.
Old 01-08-2020, 09:05 PM   #47
Robznob11
Robznob11's Avatar
These bad boys are ready to go!
LED TAILS
Old 01-08-2020, 10:36 PM   #48
Andy4639
Old member
Andy4639's Avatar
Somebody gonna be a happy GMC owner with those!
Old 01-08-2020, 10:54 PM   #49
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Those are UNBELIEVABLE!!!
I badly want a set, but we have a law in SC against a "signal light" emanating a "glaring or dazzling light".
I must check to see if these are considered as such before purchasing any. Hard to believe something that makes a vehicle easier to see could have a law against it.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 01-08-2020, 10:55 PM   #50
Robznob11
Robznob11's Avatar
Just fyi...I don't claim DOT certified...Lol
LED TAILS
