Old 11-22-2019, 11:32 AM   #51
lukeembry
Re: 85 C10 LT/6L80 Frame off build
Vibro Solutions 2MM damping material installed, they offer kits that work well with the C10. i had enough to cover firewall, floor, back of cab, roof and inside of the doors. Top layer is Vibro Solutions 6MM foam to finish it off.
lukeembry is offline   Reply With Quote
Old 11-22-2019, 11:39 AM   #52
lukeembry
Lee Power Steering box, I have installed 4 this year on other builds, highly recommend. Belltech sway bars, springs and shocks will be used on this build.
Old 11-25-2019, 06:21 AM   #53
BabyBlue
The Peacemaker
BabyBlue's Avatar
Originally Posted by lukeembry View Post
Budnik wheels are ready for tires, I'll be running 20x10.5 and 20x8.5 with Michelin tires. I really like the brushed centers with polished lips.
Can't to see these on the truck, the brushed centers look awesome. Truck is coming together nicely.
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 11-25-2019, 08:15 AM   #54
Mattchu60
Which Belltech drop springs did you use? And did they line up to the top and bottom pockets correctly?
Mattchu60 is offline   Reply With Quote
Old 11-25-2019, 09:23 AM   #55
lukeembry
Belltech 4702 2" i took a set out that were 10 years old and installed a new set both sets fit perfect.
Old 12-10-2019, 10:46 AM   #56
lukeembry
getting body panels fit one last time before paint, I have been using TAMCO products from the start for all primer and paint needs. awesome stuff that I highly recommend
Old 12-10-2019, 12:33 PM   #57
focusedontheprize
focusedontheprize's Avatar
The truck looks incredible in just primer. Looking forward to seeing it all painted.
focusedontheprize is offline   Reply With Quote
Old 12-10-2019, 07:26 PM   #58
MHarvey
Looks like it’s coming along great. I’m anxious to see it completed. Is that Coy’s vette in the background?
MHarvey is offline   Reply With Quote
Old 12-10-2019, 10:01 PM   #59
Roaddogg
Did you have to mod the trans tunnel to fit the transmission?
Roaddogg is offline   Reply With Quote
Old 12-10-2019, 10:23 PM   #60
MHarvey
Roaddog, he posted back in post #33 that he raised his trans tunnel to make it fit, but I’m not sure how much he raised it. I’m currently working on a 6.0/6L90 combo and had to do the same. I cut out the low section and raised it similar to what a “high hump” 4wd trans tunnel would be. I’m hoping this way I can run factory replacement high hump carpet.
Old 12-10-2019, 10:27 PM   #61
Roaddogg
Oh yeah I see it now haha. I read the whole build thread a few weeks ago when I started considering a 6l90 and have been going back and forth and was skimming today and reconsidering it again but not sure I want to cut it up. Beautiful build by the way
Old 12-12-2019, 09:15 AM   #62
lukeembry
Ha, no its not he's too picky get it out much.
Old 12-12-2019, 09:17 AM   #63
lukeembry
I did, you could probably get it to fit without doing so if you don't mind to sit the engine high and have 6 degrees or so in it. I prefer a low sitting engine and trans above the frame if possible.
Old 12-12-2019, 12:26 PM   #64
lukeembry
Dashes Direct seat foam and a new OE style seat cover complete, I'm really impressed with the seat foam.
Old 12-12-2019, 12:31 PM   #65
lukeembry
I went ahead a made a new fan shroud to go with the Dewitts radiator. I wanted use a certain style of Spal fans and also so I could mount the shroud to the factory top radiator plate.
Old 12-12-2019, 07:43 PM   #66
MHarvey
Great job on everything so far. LOL on the vette situation. I’ve known him for around 30 years now and you’re exactly right about him being picky. I’m sure it sees the inside of the garage much more than the outside, lol.
Old 01-17-2020, 11:53 PM   #67
lukeembry
Here’s a few pic of the modified OE cast manifolds
Old 01-17-2020, 11:57 PM   #68
lukeembry
And another
Old 01-18-2020, 08:12 AM   #69
MHarvey
Those look great. Mine’s not even running yet and I’ve almost decided I should’ve went with manifolds over the Super Comp long tubes. I had the stock truck manifolds but also looked at the Holley ones as well. I’m hoping I don’t have heat soak issues on the starter with the long tubes. Those manifolds make everything look nice and clean.
Old 01-18-2020, 10:43 AM   #70
moregrip
moregrip's Avatar
And another
looks factory clean! Nice work!
What backspacing did you select for your wheel choice? thank you
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 01-18-2020, 02:40 PM   #71
melks
melks's Avatar
Everything looks great! This all motivates me to have fun cleaning up my 84 one day.
melks is offline   Reply With Quote
Old 01-18-2020, 07:13 PM   #72
Schroedum
Holy crap. Awesome build!
1984 C10 with cammed vortec 350
Schroedum is offline   Reply With Quote
Old 01-19-2020, 02:35 AM   #73
lukeembry
I like the manifold look, I’m all about OE look and quieter exhaust these days.
Old 01-19-2020, 02:36 AM   #74
lukeembry
Thanks, keep in touch. I did 5” on front and rear. The rear is tight to the bedside with a 10.5” wheel.
Old 01-19-2020, 02:38 AM   #75
lukeembry
Thanks, I look forward to it being finished.
