Old 12-16-2019, 11:40 PM   #11
1972_K20
Re: 1972 Chevy K20 Extended Cab Cummins Build
So after getting all of the measurements and making sure the placement is right, the floor pan has to be sent of to get sandblasted so we can weld to it. the plan is to have two inner rockers cut and bent so they are each about 6 feet long and fasten two sets of outer rockers on each side to "extend" the cab. the rockers in the back will be used to help mount the doors in the rear so they will act as the side panels. all of the seams in the rear will be filled with 3/16 rod and welded then ground flat. in the end it will be a two door extended cab.
1972_K20 is offline   Reply With Quote
1972, chevrolet, cummins, k20
