12-18-2019, 02:27 AM | #1 |
Always on the hunt...
F/S Several GM NOS 67-72 Truck Parts
Offering several GM NOS parts in one combined thread, the first "I'll Take It" gets the part and some of the below listings do have multiple quantities available where noted so please be clear in your reply. For figuring a parts total, confirm ship to Zip code and item/quantities wanted and then standby for a total, we will combine shipping on multiple purchases and offer savings when/where possible. If interested, funds can be sent via venmo, check or money order. Thanks, Mel
#1 - NOS RH saddle/tan defrost dash vent, 3-available. $65. ***Qty. 2 Sold/Shipped*** #2 - NOS 3 pc. windshield washer jar, lid and mounting bracket, 8-setups available. $125. per set ***Qty. 6 Setups Sold/Shipped*** #3 - NOS 4 pc. deluxe amber & red side marker lens set. $375. ***Sold/Shipped*** #4 - NOS GMC front park light/turn signal lens, fits either side. $65. #5 - NOS 4 pc. 4wd t/c side support bushing set of two uppers & two lowers, 8-sets available. $160. per set ***Qty. 7 Sets Sold/Shipped*** #6 - NOS 71-72 truck 1-1/2" fuel neck grommets, 4-available. $100. ea. ***Qty. 3 Sold/Shipped*** #7 - NOS 67-70 truck & 69-72 blazer 2" fuel neck grommets, 12-available. $85. ea. ***Qty. 10 Sold/Shipped*** #8 - NOS 70-72 A/C vacuum controlled heat/water valve, 2-available. $75. ea. ***Qty. 2 Sold/Shipped*** #9 - NOS 8 pc. four core upper/lower radiator mounts and rubber pad setup, 2-sets available. $175. ***Qty. 2 Sets Sold/Shipped*** #10 - NOS LH/RH suburban tailgate side support straps/links. $125. pair #11 - NOS LH truck/blazer tailgate side striker/strap links, 5-available. $95. ea. ***Qty. 4 Sold/Shipped*** #12 - NOS truck/blazer tailgate latches, 6-pairs available. $160. per pair ***Qty. 5 Pairs Sold/Shipped*** #13 - NOS suburban/panel rear barn door latch/lock relay control. $110. ***Sold/Shipped*** #14 - NOS instrument cluster printed circuit for gauge style dashes, 2-available. $175. ea. ***Qty. 1 Sold/Shipped*** #15 - NOS LH/RH 67-68 Chevy painted steel headlight bezel set, not avail in new repro, 2-sets avail. $200. per set ***Qty. 1 Set Sold/Shipped*** #16 - NOS T/S switch specific for tilt column w/auto trans, has grey wire & bulb socket for lighting shift lens, 3-avail. $175. ea. ***Qty. 2 Sold/Shipped*** #17 - NOS RH door side glass #782 inner-felt/#784 outer-rubber seal pair. $165. ***Sold/Shipped*** #18 - NOS LH/RH door glass upper felt channel run pair. $185. ***Sold/Shipped*** #19 - NOS LH/RH complete rear of vent wing division bar felt/steel channel run pair. $275. ***Sold/Shipped*** #20 - NOS LH vent wing rubber weatherstrip seal. $90. ***Sold/Shipped*** #21 - NOS *** N/A See Below Item #23*** #22 - NOS LH 67-68 truck/suburban bench seat adjuster track. $150. ***Sold/Shipped*** #23 - NOS LH/RH 71-72 front bumper guard set w/rubber pads. $550. ***Added 02/04/23*** Pics in thread post #137 . Last edited by Classic Bowties; 06-17-2024 at 07:33 PM. Reason: Updated availability |
12-18-2019, 02:29 AM | #2 |
Re: F/S Several GM NOS 67-72 Truck Parts
More pics...
12-18-2019, 02:31 AM | #3 |
Some more pics...
12-18-2019, 02:33 AM | #4 |
Last of the pics...
12-18-2019, 09:08 AM | #5 |
12-18-2019, 09:35 AM | #6 |
BlahBlahBlah
Ill take no.13 please. NOS suburban/panel rear barn door latch/lock relay control. $110. shipped
I only do PMO please send me your address … thanks.
12-18-2019, 10:06 AM | #7 |
Will knock $5. off for both of the 1-1/2" fuel neck grommets being combined and sent as one shipment, total $165. The payment options are listed in the top post, please confirm preferred method and we'll get that specific info returned back to you. Thanks
Our info for mailing the postal money order has been returned, please reply to that message with your shipping address and we'll get the burb/panel door latch control ready for shipment. Thanks, Mel |
12-18-2019, 11:01 AM | #8 |
I will take 3 of # 7
12-18-2019, 11:05 AM | #9 |
Can I get # 9 please and one of #14.
12-18-2019, 11:07 AM | #10 |
I will take both # 8 for 100.00 pkg with # 7 thanks
12-18-2019, 11:28 AM | #11 |
Will knock $15. off of the three fuel neck grommets and $10. off of one of the A/C vac heat/water valves if all items are combined and sent as one shipment, total $320. (breakdown listed below) The payment options are listed in the top post, please confirm preferred method and we'll get that specific info returned back to you. Thanks, Mel
Three - 2" fuel neck grommets (3 @ $60. = $180.) Two - A/C vac. heat/water valves (1 @ $75. & 1 @ $65. = $140.) |
12-18-2019, 12:05 PM | #12 |
Will offer you a $10. shipping discount on the four core radiator mount set and dash printed circuit if being combined and sent as one shipment, total $260. The payment options are listed in the top post, please confirm preferred method and we'll get that specific info returned back to you. Thanks, Mel
12-18-2019, 01:15 PM | #13 |
Interested in #14, what is meant by guages?
12-18-2019, 01:20 PM | #14 | |
12-18-2019, 01:38 PM | #15 |
I will PayPal later today and thank you for the shipping discount
Posted via Mobile Device |
12-18-2019, 03:21 PM | #16 | |
Thanks for the phone call to discuss, let me know after checking your dash cluster if you need the NOS circuit.
12-18-2019, 04:23 PM | #17 |
Sounds good pm me payment info thanks
12-18-2019, 04:49 PM | #18 | |
12-18-2019, 05:42 PM | #19 |
I'll take one of the #7. The 2" fuel neck grommet for a 1972 GMC Jimmy.
I'll use PayPal. Please send me the address for sending Paypal payment. Thanks, Pat |
12-18-2019, 05:57 PM | #20 |
PayPal sent
12-18-2019, 06:23 PM | #21 | |
http://67-72chevytrucks.com/vboard/s...71#post8642071 |
12-18-2019, 11:58 PM | #22 |
Your NOS fuel neck grommets are under way, the package went out via USPS first class on Wed. 12/18 and USPS has projected the delivery date to be this Sat. 12/21. Thanks again
The NOS rear barn door latch relay control has been shipped, your package was sent out via USPS priority on Wed. 12/18 and the expected delivery day is this Sat. 12/21. Thanks again and let me know if we can help with anything else, Mel |
12-19-2019, 01:21 PM | #23 |
12-19-2019, 11:33 PM | #24 |
Your NOS radiator mounting parts and the NOS printed circuit are under way, the package was shipped out via USPS priority on Thu. 12/19 and the projected delivery date is Mon. 12/23. Thanks again and let me know if we can help with any other parts needs, Mel
12-20-2019, 12:32 AM | #25 |
Active Member
Mel,
I’ll take the NOS amber and red side marker light set #3 if still available. Do you have a NOS windshield washer container and holder that would be stock for a 1971 Blazer? |
