Old 12-18-2019, 11:04 PM   #26
dmjlambert
dmjlambert's Avatar
Re: Fuel tank location options for long bed pickup
Originally Posted by Rufas View Post
The fill tank tubes are small and it's very tight getting your hand inside the panel to take the gas cap off. Filling is just a royal PITA.
Those piano hinge fuel door are just plain butt ugly, they rust and the paint peels off the hinges.
One more thing the tanks rust on the inside too.
Well if that's all the problem is, it won't be a problem for me. I'm going to just weld the fill necks shut and not use them. I would like them to have a round hole in top with the 5 bolt holes surrounding it for one of those universal 90 ohm sending units. And another similar hole to mount a round disk fitted with a pickup tube with filter sock and vent tube. If I get used or steel ones that may rust I can clean them up and put some of that RED-KOTE or something like that in there.
Old 12-19-2019, 12:22 PM   #27
Happy_dan
Happy_dan's Avatar
Originally Posted by dmjlambert View Post
That is interesting and informative, thanks. I wonder if that is a longhorn-only size, or if those would fit on a long bed pickup. I also wonder how the bolts go through the tank. I suppose maybe there is a tube that goes through the tank and is welded, do you think that's right? Do the mount bolts go through he floor of the bed?
I have that exact same setup in my C-20 Longbed. There are plastic covers over the gas caps to keep the crud out but the rest is all the same. I don't use them but I assume they are still good since everything else in the truck has been good.
1968 C-20 CST Vermillion
http://imageevent.com/happy_dan/dantoys/68c20
2019 Silverado
2012 Camaro ZL1
Happy_dan is offline   Reply With Quote
Old 12-20-2019, 10:10 PM   #28
BigBird05
Has anybody tried to use a 73 style tank (the ones that mount in front of the tires) on a 72? So many other parts from newer trucks seem to work on the 67 to 72's with a little modifying.
BigBird05 is offline   Reply With Quote
Old 04-29-2020, 11:27 PM   #29
dmjlambert
dmjlambert's Avatar
BigBird05 I would also like to know if anybody has tried that.
Old 04-30-2020, 01:24 AM   #30
toolboxchev
GM came under major scrutiny after 73 on those tanks. Nader and all his buddies in high places were blaming GM for deaths after tanks exploded in T-Bone crashes.
I dunno about doing that???
toolboxchev is offline   Reply With Quote
fuel tank
