12-22-2019, 11:06 PM | #1 |
Old member
Cleanning up
My long time friend is cleaning out his shop of 40 years of auto-mechanic.
He has been selling things and giving stuff away. I have been working on my 68 step side in his shop and I fixed his old Mac Tool sand blast cabinet to use it on all my parts for the 68. I put new glass in it and gloves and bought 25lbs of sand for it. Cleaned out the vacuum system and resealed it. Saturday he gave it to me and said Merry Christmas! I'm going to get it all cleaned up and paint it back like new and try and make a little money with it doing parts for people. Here it is and some of the parts I did. It's gonna need a new moisture separator installed to.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-23-2019, 10:18 AM | #2 |
Re: Cleanning up
Wow, nice gift!!!
12-27-2019, 12:15 AM | #3 |
Re: Cleanning up
Cool that it has a new home where it will be used instead of winding up being sold for scrap.
01-20-2020, 01:53 AM | #4 |
Re: Cleanning up
That's a handy tool for sure!
01-24-2020, 11:26 AM | #5 |
Re: Cleanning up
Nice gift! I have a smaller unit and they are as handy as a pocket on a shirt. What are you using for media now? I have glass in mine as I was doing a ton of aluminum motorcycle parts but it's ready for a change and I was thinking about something more aggressive for all the steel parts I am doing now.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
01-26-2020, 09:13 PM | #6 |
Re: Cleanning up
I've been using glass bead in mine, but at $30+/bag it gets kind of expensive.
I recently switched to 80 grit glass, and it seems to do the job just fine for about $12 for a fifty pound bag. The surface finish is a little rough for aluminum, but it is fine for steel. |
01-26-2020, 09:19 PM | #7 |
Re: Cleanning up
Think about getting a light for the inside of the cabinet. I have just a regular incandescent light bulb and it has worked fine for over five years. It puts out a little heat too, and I think that helps keep the media dry and free of clumps.
The other thing you should think of is hooking up some sort of dust collector to the cabinet. I have a shop vac hooked to mine, but it clogs pretty quickly and I have to shake out the filter every couple of hours. Search for something called 'dust deputy' which is a simple cyclonic filter you can add to your cabinet to pull the dust out of the media |
