11-22-2019, 05:26 PM | #3176 |
Re: PO has me PO'd
Today was a rare exception, everything went right. Double flare on the rear axle worked first time, brakes are done, and clamped to the frame rail with totally stainless 3/16" clamps. I'll let them bleed them. 5th or 6th time on the power steering belt tensioned up today, both belts are now done. Just waiting on some parts I lost (u-bolts) for the drive shaft, and PTO cover plate gasket, both found locally. rear diff. cover sealed up, and both shocks are mounted
also mounted the remote tank for the hydro boost [url=https://flic.kr/p/2hNX7r6]20191121_121327 Now its time for some R&R, thanks giving then a florida trip for a week, hope the fish are biting, and not the bugs Balls in Dale's court
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-22-2019 at 05:32 PM. |
11-22-2019, 08:16 PM | #3177 |
Re: PO has me PO'd
11-22-2019, 09:22 PM | #3178 |
Re: PO has me PO'd
lookin good......
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-23-2019, 02:33 PM | #3179 |
Re: PO has me PO'd
Thanks Jesse, its so close I can feel it, but I hate to leave it for two weeks
11-23-2019, 02:48 PM | #3180 | |
I'm trying....
Re: PO has me PO'd
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
11-23-2019, 08:14 PM | #3181 | |
Re: PO has me PO'd
My last flare, I was laying on my creeper upside down and backwards, not seeing clearly as my bifocals were coming in and out of range, working in the dark with a little flashlight, afraid to unclamp the flaring tool. but to my surprise as I brought it down and looked, it was perfect, sometimes you just get lucky. This truck has fought me every step of the way for over twenty years. This the first day that I have not gone to a shop, or thought about it, in some fashion for that long of a time. I will never modify a project again! Yeah right, my mind is now drifting to installing a LS engine in a TR-6. That is where my roots started, early english sports cars But, thanks for stopping by and your kind words, whats up with you and your next project after your break
11-24-2019, 09:20 AM | #3182 | |
Re: PO has me PO'd
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
11-24-2019, 09:24 AM | #3183 |
Re: PO has me PO'd
Sorta like a Caroll Shelby knock off, using a frame from a kit car with corvette suspension
never liked the doors on an AC Cobra, plus my workshop is too small for trucks LOL Plus tr-6's have flat panels on the bonnet and rear deck to widen the body Yeah, I'm a glutton for punishment
11-25-2019, 02:28 PM | #3184 |
Re: PO has me PO'd
found some oem parts that I lost in my basement at my local 4X4 shop
[url=https://flic.kr/p/2hQPiZX]20191125_132123
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-25-2019 at 02:35 PM. |
12-09-2019, 04:20 PM | #3185 |
Re: PO has me PO'd
[url=https://flic.kr/p/2hXai2X]20191209_122114
[url=https://flic.kr/p/2hXahYa]20191209_121959 [url=https://flic.kr/p/2hXahX8]20191209_122025 [url=https://flic.kr/p/2hXai5T]20191209_122136
12-09-2019, 07:57 PM | #3186 |
Re: PO has me PO'd
When I returned from Florida (83 degrees and sunny all week) This what Dale had accomplished. I finished the work on the drive shaft and PTO cover. Now I have to build a bracket for the trans dip stick since it sits to close to the firewall
found out that 2 of the holes are blind, in the T/C so, had to come up with a 1/4" shorter bolts, they are the 2 bolts towards the drive shaft He doesn't like to mount the air temp. sensor in the plenum as it will see heat and throw off the readings, so, later on I will mount it in the air cleaner somehow
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-23-2019 at 06:20 PM. |
12-12-2019, 09:09 AM | #3187 |
Re: PO has me PO'd
Its alive
12-12-2019, 09:11 AM | #3188 |
Re: PO has me PO'd
Yay!!!
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
12-12-2019, 09:18 AM | #3189 |
Equal opportunity joke ofender
Re: PO has me PO'd
Congrats, it has to be a great feeling
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
12-12-2019, 11:40 AM | #3190 |
Re: PO has me PO'd
12-12-2019, 04:48 PM | #3191 |
Re: PO has me PO'd
12-15-2019, 12:57 PM | #3192 |
Re: PO has me PO'd
12-15-2019, 01:20 PM | #3193 |
Re: PO has me PO'd
Yea, X2 on that. How about a rip down the freeway!
12-15-2019, 08:10 PM | #3194 |
Too Dumb To Know Better
Re: PO has me PO'd
Excellent Jim.
12-15-2019, 09:46 PM | #3195 |
Re: PO has me PO'd
fantastic.......
12-23-2019, 05:44 PM | #3196 |
Re: PO has me PO'd
12-23-2019, 05:51 PM | #3197 |
Re: PO has me PO'd
12-23-2019, 06:08 PM | #3198 |
Re: PO has me PO'd
yeah, she leaks alittle, and has some wierd rattles, and shakes, but give me some time and she'll be on the road
Thanks everyone for following this epic build, and your input over the years, it's been real first video, touch the screen
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-23-2019 at 06:18 PM. |
12-23-2019, 06:23 PM | #3199 |
I'm trying....
Re: PO has me PO'd
That is awesome Jim. Congratulations!
12-23-2019, 06:51 PM | #3200 |
Re: PO has me PO'd
Thanks Bud, just have to figure out some metal to metal noises
