Old 12-10-2019, 09:55 AM   #1251
99 to Life
99 to Life's Avatar
Re: "Project Orangepeel" 52 A.D
Very well done. So what did you glue the I'm assuming vinyl down with? I like the magnet idea. You must have thousands of hours in this thing!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-10-2019, 09:59 AM   #1252
8man
Very nice!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 12-10-2019, 08:15 PM   #1253
reaper71
reaper71's Avatar
Thank You Henry!
The Vinyl is glued with Weldwood Landau top cement,holds way better than regular contact cement.
As far as the HRS.....I have no clue where its at
Thanks Robert!
Mark
reaper71 is offline   Reply With Quote
Old 12-10-2019, 10:55 PM   #1254
joedoh
joedoh's Avatar
beauty!
Old 12-10-2019, 11:02 PM   #1255
reaper71
reaper71's Avatar
Thank You again Russ!
Old 12-18-2019, 08:42 AM   #1256
reaper71
reaper71's Avatar
Hey Guys, Not alot of work on the truck recently.
I have been busy building a 2x72 belt grinder for the shop that I really need.
If you want to see the building of the grinder let me know and Ill post up pics.
Mark
Old 12-18-2019, 09:06 AM   #1257
mongocanfly
mongocanfly's Avatar
Homemade grinder?....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-18-2019, 09:11 AM   #1258
Kevin Mac
Kevin Mac's Avatar
Heck yeah, I like shop built tools and pictures!
Kevin Mac is offline   Reply With Quote
Old 12-18-2019, 09:25 AM   #1259
OutlawDrifter
That has been a big topic on garagejournal as of late.... I've been considering it as well.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 12-18-2019, 01:47 PM   #1260
reaper71
reaper71's Avatar
Here a 2 shots of the basic chassis and stand.
I'm using 2 1/2" square tube 3/16th wall ( wanted 1/4) but they didn't have it available.
These grinders need to be heavy duty to help with vibration.
The tooling arms that will slide inside the chassis will be 2" and 1/4" wall.
The tube at the top will be the tensioner assembly and it will have a lock on it to hold it down to remove belt easily.
The stand will have adjustable feet with rubber to level it.
It will also have wheels on the rear to make it easier to move around the shop
Mark
Old 12-18-2019, 04:17 PM   #1261
mongocanfly
Gonna be nice I'm sure.....are you making so you can change idler dia sizes to do diff size radius?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-18-2019, 04:49 PM   #1262
joedoh
joedoh's Avatar
looks super stout!
Old 12-19-2019, 09:15 AM   #1263
reaper71
reaper71's Avatar
Greg, The platen assembly can be removed and then use the other attachment to do different radius. I wont do that right away,but maybe down the road.
Old 12-19-2019, 09:17 AM   #1264
reaper71
reaper71's Avatar
Thanks Russ.
It's already getting some weight to it!
Old 12-20-2019, 11:32 AM   #1265
Rickysnickers
Just getting caught up on this. For the kick panels, what type of base material are they made from and how thick is it? Also, how did you stick the magnets to them? Thanks, and of course, excellent work!!!
Rickysnickers is online now   Reply With Quote
Old 12-20-2019, 08:49 PM   #1266
reaper71
reaper71's Avatar
The kick panels are made from 2 layers of the plastic sheets, glued together.
The magnets get sanded with 36 grit and then epoxy is used to glue them in place on the interior panel of the truck.
Then a 2nd magnet is glued to the plastic panel so they attract to one another. The panel is only 1/4" thick.
Mark
Old 12-20-2019, 08:56 PM   #1267
reaper71
reaper71's Avatar
Its a polycarbonate sign grade plastic 1/8" thick.
I found it at Regal plastic.
Old 12-20-2019, 09:03 PM   #1268
reaper71
reaper71's Avatar
Here are the polyurethane wheels I'll be using, 4" with bearing's.
I made some plates to mount the wheels to the stand.
The last pic is of the tracking wheel adjuster.
Works on a pivot using the knob.
Mark
Old 12-23-2019, 08:37 AM   #1269
reaper71
reaper71's Avatar
pic 1. The platen assembly is from ameribrade.
Pic 2. The grinder basically all mocked up.
The motor is from grizzly 1hp 3450 rpm
Mark
Old 12-23-2019, 09:17 AM   #1270
joedoh
joedoh's Avatar
super nice!
at 3450 does the belt want to walk off? i dont have any experience here so just asking
Old 12-23-2019, 10:00 AM   #1271
8man
That is a good looking sander. You should post the plans you used to build it. Very nice.
8man-aka Robert
Old 12-23-2019, 08:55 PM   #1272
reaper71
reaper71's Avatar
Russ, Thank You.
the belt will move no matter what RPM, that is solved by the tracking knob on the upper wheel.
Old 12-23-2019, 08:57 PM   #1273
reaper71
reaper71's Avatar
Thank you Robert.
I didnt use any plans,just alot of searching on youtube to come up with a design.
If you like I can draw something up with some measurements.
Mark
Old 12-23-2019, 10:31 PM   #1274
mongocanfly
Turned out great Mark..now its time to create a sanding dust storm in the shop..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-24-2019, 08:44 AM   #1275
reaper71
reaper71's Avatar
Thanks Greg!
Yes it eats steel like M&Ms
