![]() Join Date: Aug 2015
Jegs mini starter problem
Good Afternoon All
got a jegs mini starter part #555-10009, had one i orginally installed January 2018, lasted 6 months, started cranking slow , then not at all Jegs replaced with the same June of 2019, (no charge, good customer care to deal with every time ive dealt with them) Went out today , started slow, but its been cold and ive been on call for a week so have not driven truck, went to mall, came back out, no start, only clicks had a buddy stop and try to jump, no difference, finally got a metal rod and tapped starter, started right up got home and tried, it did start but slow crank does not have any binding or noise when regularly starting, sounds like a new vehicle, its usually that quiet 1972 C10, 350/4 bolt, 4 speed stick anyone used the corvette starter with out any issues,part # if possible, might try that or ill just go back through jegs to replace Thanks
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
Moderator
![]() Join Date: Jun 2017
Re: Jegs mini starter problem
Suggest you upgrade to the Tuff Stuff 3 HP starter unit....bit more expensive but much better in long run
https://www.jegs.com/i/Tuff-Stuff/908/6772B/10002/-1 The 555-10009 starter is 1.9 HP.... Just my ten cents worth... ![]() ![]() ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
At the body shop.
337-1022 ac delco $100 usually from Amazon.
678-107 Dorman x2 Been good to me on 3 of my junks
" That didnt make it any newer " " Dont antique the equipment " |
![]() Join Date: Feb 2009
I've heard good things about Delco 1022. At this point I can say it fits nicely, pending maiden voyage.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
talked to the good people at Jegs
Box it up and send it in, theyre going to replace the Starter 1 year warranty will start over when i get the new one Thanks for the replies
![]() Join Date: Jul 2015
I would look into making sure the proper distance in the starter gear to flywheel is followed.
Most after market starters come with a shim kit, instructions, and a small round gauge to measure the distance. |
was having the same probelm and i added grounds and still had it, so i added a slave solnoid and hav'nt had a probelm since
"Send in the clowns the goats are loose" |
ok, so the starter has not been an issue for a few days, was going to pull it next weekend, just went out to start truck, only clicked, so as i was walking away it started to try and engage the solenoid off and on,loud whine, key was off and out of truck, after running back in and out of garage, got battery cables unhooked
starter smelled and was hot, got my tools and removed, all wires looked ok, no melted or burnt wiring question i have is should i install the starter solenoid setup and would it have helped or eliminated this issue, might have been easier to unhook side note: starter is being sent back for replacement Thanks
Also check your positive and negative cables from the battery to the starter, I just upgraded to 1/0 gauge and got better connectors after I melted the lead connectors to the battery while cranking.
