Old 01-08-2016, 10:06 PM   #1
elcaminodragster
12 bolt ring gear contact pattern help
Hey everyone looking for a little help setting up my ring and pinion.
65 c10
12 bolt
Richmond 3.42
All new timken bearings
Pics are of my starting point. I started with .030 under the pinion and .008 backlash.
Need to know where to go from here to get a good contact pattern. Thank you for any and all help.
I can only load one pic at a time for some reason I'll follow with the other side in just a moment
elcaminodragster is offline   Reply With Quote
Old 01-08-2016, 10:09 PM   #2
elcaminodragster
Re: 12 bolt right gear contact pattern help
Here is the other side
Old 01-08-2016, 11:06 PM   #3
Wrenchbender Ret
Re: 12 bolt ring gear contact pattern help
That looks really good to me. I would sew it up.
Wrenchbender Ret is offline   Reply With Quote
Old 01-08-2016, 11:24 PM   #4
truckdude239
truckdude239's Avatar
Looks pretty good to me also
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-09-2016, 01:09 AM   #5
Captainfab
60-66 Nut
I agree, that looks pretty good to me. However someone with more setup experience may have different input.
Old 01-09-2016, 03:58 AM   #6
elcaminodragster
I thought I'd looked good but I wasn't sure. This was the first setup to get a starting point. I guess I got lucky first try. Thank you guys!
Old 01-09-2016, 09:49 AM   #7
homemade87
That does look pretty good . I would remove .002 from the shim and see what you get . I see a hard straight line at the bottom of the pattern on both sides which may mean it may be a little to deep . And then play with the B/L .007 to .009 and see what it looks like . I would try this before I buttoned it up to see if it improves some .
Also you have a slight round moon shape at the top of the pattern . This also suggest its a little deep . It would run like you have it ok . But I like to get the best I can .
homemade87 is offline   Reply With Quote
Old 01-09-2016, 02:03 PM   #8
elcaminodragster
Ill pull .002 from the pinion shim and post pics in a couple hours. I'm in no hurry to put the axle together so if I spend some time getting it as perfect as possible I don't mind.
Thank you for your input!
Old 01-09-2016, 02:23 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Loos decent to me.
You can load more than one pic in a single post. Just load them one at a time in the same post.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-09-2016, 04:09 PM   #10
elcaminodragster
Still only letting me upload one pic at a time not sure why...
I pulled .002 from the pinion and backlash is not at .007. I liked the first pattern better but I'm still learning the contact patterns.
Old 01-09-2016, 04:10 PM   #11
elcaminodragster
Here's the other side
Old 01-09-2016, 05:02 PM   #12
homemade87
Looks as if the drive side is better . You lost that hard line at the bottom . It also looks like it has centered the pattern from heal to toe and top to root on the drive side . Has that soft pattern all around with out hard lines . The coast side looks pretty good as well . Your roll pattern is a little soft . Re roll and get some pressure on the ring gear so the pattern would be more pronounced and re post .
Old 01-09-2016, 07:13 PM   #13
elcaminodragster
Here are the pics you requested...
Old 01-09-2016, 07:14 PM   #14
elcaminodragster
And the other side...
Old 01-09-2016, 07:34 PM   #15
homemade87
In my opinion , that looks really good . I would run that . Good even pattern top to bottom , smooth lines , pattern center coast and drive side . I would run it .
Check your back lash 3 places . If you average .007 to .008 you should be good .
Some aftermarket gears can be a bear to set up . Unfortunately there are no oem gears out there for the 12 bolt . Gm quit making them years ago . AAM makes gm oem gears now and do not have 12 bolt gears . The Richmond orange box gears are not known for being quiet . It is a hit and miss . 3.42 gears are not as bad as the 4.11 and up .
Old 01-09-2016, 07:44 PM   #16
elcaminodragster
Thank you very much for your help! It's greatly appreciated!
Old 01-14-2020, 06:15 PM   #17
Stover93
What do you guys think about this pattern? More pinion shim?
Stover93 is offline   Reply With Quote
Old 01-14-2020, 10:07 PM   #18
Stover93
Still on setup bearings. Backlash at .008. I think I’m going with a pinion spacer instead of crush sleeve.
Old 01-14-2020, 10:13 PM   #19
mongocanfly
mongocanfly's Avatar
I was editing my post to show pics and somehow deleted it... the pattern looks good...id try it...but keep in mind things change when you swap out the setup bearings...crush sleeve eliminator is a good choice but will require more setup
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-14-2020, 10:19 PM   #20
Stover93
Thanks Mongo. Looked pretty close to me but this is my first attempt at a diff setup. Based on the pics above, a little adjustment makes a big difference.
Old 01-14-2020, 10:52 PM   #21
mongocanfly
yep...just swapping out the bearing can change it all..it did on mine
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-15-2020, 12:15 PM   #22
Stover93
Hopefully it won't change too much. I bought a new pinion bearing for setup. I bent the cage on the old one getting it pressed off.
I don't think anyone has been in this diff before. Looks pretty dang good for 50 years old. The backlash was loose and it wasn't posi so I decided to tear into it.
