Old 01-13-2020, 05:37 PM   #26
SCOTI
SCOTI's Avatar
Re: Anyone can buy an SWB...
Outstanding stuff going on w/that clutch linkage re-work vs. going to a hydraulic set-up. I've been staring @ a box full of G-body linkage & facing a similar dilemma... Gusset it & use some red ends for an old-school 3rd pedal set-up? Or, buy-in for the 'upgrade' aftermarket set-up that's all hydraulic (and more expensive).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-13-2020, 05:41 PM   #27
Inverter
Inverter's Avatar
Inverter is offline   Reply With Quote
Old 01-13-2020, 05:58 PM   #28
Inverter
Inverter's Avatar
Thanks much.
I like the simplicity of a mechanical linkage. If you have the time n patience you can create a one-off setup that has good throw n smoothness no matter the vehicle. Im sectioning the arms and reclocking the pedal pads on my 68. Theres nothing that cant be made better with patience and focus.
Old 01-13-2020, 06:54 PM   #29
SCOTI
SCOTI's Avatar
Originally Posted by Inverter View Post
Thanks much.
Truth.
Years ago I bought a 4spd g-body ElCamino just because it had all the parts needed. I swapped an auto set-up from a Malibu over to the Camino & the manual trans set-up over to the Malibu. Fast forward a 'few' years & now all the rage is an aftermarket hydraulic set-up. Sure tempted to stick w/the old school mechanical linkage & just make refinements where needed. After all, mechanical set-ups worked for a looooong time before the OE's switched to strictly hydraulics.
Again, glad I came across your build. I like your style. I'm pretty sure I've seen your truck before in person as well @ a meet or show somewhere.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-14-2020, 02:36 PM   #30
Inverter
Inverter's Avatar
Cool. Glad to have you. Recognize your avatar. I Used to be on the forums a lot around 07-10.. Dino and Nathan were my truck building heroes.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Old 01-14-2020, 03:32 PM   #31
raggedjim
raggedjim's Avatar
MTP... I like it and I'm about 6 weeks away from my own MTP moment.
Great work and good luck in all you do, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 01-14-2020, 08:43 PM   #32
Inverter
Inverter's Avatar
T-6 dom driveshaft
[ATTACH]1974146[/ATTAC
TROY
Old 01-14-2020, 09:00 PM   #33
Inverter
Inverter's Avatar
Drew up plans for this. BW did an excellent job
TROY
Old 01-14-2020, 09:50 PM   #34
boonedogs72
boonedogs72's Avatar
Killer work! Love the build!
boonedogs72 is offline   Reply With Quote
Old 01-14-2020, 11:47 PM   #35
Trucknut57
Trucknut57's Avatar
I applaud your skills, awesome build. Wish I had a 1/3rd of your skills.
Definitely sub'd.
Somehow, the idiots survive despite their best efforts to kill themselves.
- dcozzi
Trucknut57 is offline   Reply With Quote
Old 01-15-2020, 12:38 AM   #36
Getter-Done
Getter-Done's Avatar
I am Watching.
That is some Nice work.
84 Chevy K-20
Old 01-15-2020, 02:25 PM   #37
KMC3420
KMC3420's Avatar
Excellent work going into this build. Nice fix on the bed body lines.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-15-2020, 04:29 PM   #38
Inverter
Inverter's Avatar
Definitely sub'd.
Originally Posted by Getter-Done View Post
I am Watching.
Thanks yall, I do what i can.
TROY
Old 01-19-2020, 04:08 PM   #39
gringoloco
A guy with a truck
gringoloco's Avatar
Very nice work here. I like where you’re headed AND how you’re getting there
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-19-2020, 05:06 PM   #40
SRU1436
Awesome build. If you don’t mind can you let me know the size of the tires and rim on the truck in your first post picture. Thank you.
SRU1436 is offline   Reply With Quote
Old 01-19-2020, 09:05 PM   #41
Inverter
Inverter's Avatar
Thanks. I noticed in yur thread where you and I have the same philosophy,, Stance Is Everything.
Thanks.
Fronts: 15x6 - 235/70
Rears: 15x8 - 275/60
Both are 28” tall.
TROY
Old 01-19-2020, 11:49 PM   #42
SRU1436
[/QUOTE]
Both are 28” tall.[/QUOTE]
Thanks.
Old 01-26-2020, 10:41 PM   #43
Big H
Big H's Avatar
It's refreshing to see some custom framework getting done. There are so many parts available nowadays that we just don't see too many one-off fabricated pieces being created.
Cleverly disguised as a responsible adult...
Big H is offline   Reply With Quote
Old 01-27-2020, 06:08 PM   #44
rsavage
rsavage's Avatar
Superb skills and build.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-04-2020, 09:57 PM   #45
Inverter
Inverter's Avatar
Appreciate the kind words.
Wiring, plumbing wrapped up.
I reroute and rearrange the wiring so its more eye pleasing.I like things to be linear and minimal where possible.
[ATTACH]1980068[/ATTACH
[ATTACH]1980071[/ATTACH
[ATTACH]1980072[/ATTACH
[ATTACH]1980075[/ATTACH
[ATTACH]1980076[/ATTACH
TROY
Old 02-04-2020, 10:14 PM   #46
Inverter
Inverter's Avatar
Bypass delete, using a fancy drilled thermostat.
[attach]1980077[/attach
[attach]1980078[/attack
[attach]1980079[/attach
[attach]1980080[/attach
[attach]1980081[/attach
TROY
Old 02-04-2020, 10:26 PM   #47
Inverter
Inverter's Avatar
[attach]1980089[/attach
[attach]1980090[/attach
[attach]1980091[/attach
TROY
Old 02-04-2020, 10:30 PM   #48
Inverter
Inverter's Avatar
posting pics is frustrating.... I must be doing something wrong. I just want to pull a lever and have it happen.
TROY
Old 02-05-2020, 09:43 AM   #49
mcm1209
mcm1209's Avatar
Man this is great! Just in time for my build.. hope you don't mind me taking some of your ideas. Especially the entire front end build. I'm just starting and starting with a frame my self.
Where about in east Texas are you?
mcm1209 is offline   Reply With Quote
Old 02-05-2020, 10:59 AM   #50
Rickysnickers
Looking at your fuel tank, there's the tall vent. What is the fitting to the right of that? Impressive work BTW!!!!
