01-18-2020, 10:53 AM | #1 |
Motorhome Tilt Column
Sold to SoCo
**SoCoC10 is first in line as he expressed interest previously*** $250 local. Prefer not to ship at this time, I don't have a good box for it right now. Please respond in thread only per board rules, first "I'll take it" gets it. Selling a motorhome tilt column. From a mid 80s GM chassis I moved the NSS down so it's a bolt-in for your 67-72; I used my multi-meter to adjust it, you may need to fine tune it after install. Turn signal has no lever Turn signal switch is tight and cancels as it should Includes the cancel cam The gray illumination wire is original length Includes a long pigtail for the Neutral Safety/Reverse switch Tilt mechanism is tight and smooth. The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight. Tilt pivots were cleaned and lubed when removed to tighten the bolts. The bottom bearing was cleaned and greased The upper bearings were cleaned and greased The shift indicator bulb was replaced and tested OK, it has the green shade on it. Shifter lever end (inside column) is good, pivot is average Shift arm and adjuster lever have nice chrome, they shine up well. The finish on it is OK, great for a driver. Some scratches as pictured. It would probably buff out nicely. I will include a new GMC Paul's gear indicator You will need to add your dash and firewall gaskets, as well as the firewall plate.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 01-19-2020 at 03:46 PM. |
01-18-2020, 10:58 AM | #2 |
Re: Motorhome Tilt Column
More pics
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-18-2020, 10:59 AM | #3 |
If you want any other pics let me know.
01-19-2020, 02:12 PM | #4 |
PM sent. I’ll take it.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
01-19-2020, 03:45 PM | #5 |
Sold to SoCo
Tags |
column, tilt, tilt steering column |
