Old 01-12-2020, 02:49 PM   #26
My72BB
Re: Parting out 250 6 cylinder w/Power Steering
Heat coil and damper work...The tiny pin that the spring activates on is very thin where it goes into the manifold.
My72BB is offline   Reply With Quote
Old 01-19-2020, 10:21 AM   #27
R Jackson
Junior Member
Do you have fuel pump to carb gas line?
R Jackson is offline   Reply With Quote
Old 01-19-2020, 08:58 PM   #28
GMCNUT
GMCNUT's Avatar
got a guy needing a set of these 230 250 brackets and pulleys if anyone reads this and has any
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 01-23-2020, 12:26 PM   #29
maverickmk
maverickmk's Avatar
Is the power steering stuff still available?
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 01-25-2020, 03:18 PM   #30
tx71smallblock
tx71smallblock's Avatar
On your original post, 5th pic down, it's a pic of the choke rod and bimetal spring... how does that rod stay in the linkage on the carb? Mine keeps falling out and I dont see how its held in
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 01-25-2020, 04:22 PM   #31
maverickmk
maverickmk's Avatar
Mine has a small hole in the rod with a small R clip in the hole.
Old 01-25-2020, 11:53 PM   #32
tx71smallblock
I'll have to look at mine closer, I dont remember seeing a hole or a grove for a c clip
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
