09-09-2019, 11:55 AM | #1 |
Selling My K20 4WD Projects
Chevy K20 60-62 frame - there are no cab mounts on it. Very straight and clean. As it sets on my trailer - $550.00.
I have a 61 GMC 4WD K20 long bed - it does not have a bed. The frame is very nice. It's a very solid truck. The only rust on it is around the top of the windshield. I have all the parts to fix it. It does not have a GMC motor. It has a SBC 350 with a fresh set of heads on it. It does run. The truck needs to be finished putting together. If you want more pictures PM me your cell and I will send you some. $1950.00 with a Kansas bill of sale. Serious inquiries only!! |
09-12-2019, 11:43 AM | #2 |
Re: Selling My K20 4WD Projects
PM sent
09-13-2019, 06:20 AM | #3 |
Not hijacking but maybe help the sale. I have a complete GMC 351 v-6 and 4-speed with pto. Still in the frame rails so all mounts and hardware included, 51,000 miles. $500
72 Cheyenne k/20, Custom Camper 72 Cheyenne k/20 71 blazer K/5 2WD 454, 6 sp. 67 Chevy Napco c30 Dump 56 GMC Napco 4x4 short step 66 Chevy K10 68 Chevy C/30 4x4 |
09-14-2019, 11:32 PM | #4 |
The truck is sold still have the frame for sale
09-19-2019, 09:01 PM | #5 |
Active Member
09-19-2019, 10:13 PM | #6 |
In response to the question if this frame will work on a 66; David (shortstep60) believes it will if you use a 60-62 front bumper and use a 60-62 radiator.
David currently is unable to respond on the forum, because his computer is currently down. Hopefully he will be back up soon. Les |
09-19-2019, 10:57 PM | #7 |
60-66 Nut
And the front cab mounts on the '60-'62's are farther apart side to side. It is as simple as drilling 2 new holes in the '63-'66 cabs.
09-20-2019, 12:30 PM | #8 | |
Active Member
10-05-2019, 11:59 AM | #9 |
I would like to thank bosephus and his family for driving 13 hours one way to pick up my 61 GMC. Thanks doo 142 for selling Les your 1966 GMC 351 mag motor and parts.
10-09-2019, 01:34 PM | #10 |
Dave(shortstep60) is a helluva good guy whom you can take at his word. The frame he has is really nice,I would have taken it and the truck if i could've gotten them both on one trailer.Anyway,dont be afraid to deal with Dave! Somebody needs to get that frame!
10-10-2019, 12:19 PM | #11 |
If anyone what to buy parts off frame let me no thanks
01-24-2020, 08:15 PM | #12 |
ttt
01-25-2020, 03:57 PM | #13 |
Text on the way
01-25-2020, 06:40 PM | #14 |
Active Member
Would you sell the handbrake assembly? I could use the brackets, rods, hardware, handle and brake band. Also, hate to cut the frame, but if you are willing, I could use the cross brace and triangle truss pieces between the two rear spring brackets. The easiest way to remove that piece would be to cut the left and right frame rails just ahead and aft of the spring perches and ship it like that. I’m I’m Connecticut...
Thank you, Joe P. |
01-31-2020, 12:51 AM | #15 |
Bell housing for a v8 or a 6 cylinder, lift blocks in rear have any cracks in them?
01-31-2020, 07:42 AM | #16 |
I sold the trans local I will check the rest and get back with you thanks
01-31-2020, 07:49 PM | #17 |
I hate to cut the frame up but if you want to give me some good money for the parts I would. Once I cut that frame I just have a pile of scrap iron. I will check on some transmission parts for you thanks
01-31-2020, 11:21 PM | #18 |
Dave I think you can remove that brace by blasting the rivets. Shame to cut a good 4WD frame, they're so rare.. I'd scoop it up if I was closer.
01-31-2020, 11:42 PM | #19 |
I no of a lot of 60-66 trucks around 120 parts trucks and there is no 4wd trucks. You would think living in Kansas there would be but there’s none. Parts are getting hard to find I been trying to find a nice rust free drivers side door for my 64 and I can’t find a nice one.
01-31-2020, 11:53 PM | #20 |
Will keep an eye out for a good door. Most of my trucks are 60-63. Btw some $ coming your way.
02-01-2020, 09:43 PM | #21 |
The rear lift block are nice no cracks $100.00 for the set plus shipping. I have two of the three drive shafts the one from the transmission to the transfer case $50.00 rear end to transfer case $75.00
02-02-2020, 09:46 PM | #22 |
Active Member
Dave, that rear cross-member brace and the triangle gussets are worth $100 to me plus shipping. I would also be hesitant to cut the frame. It should really be preserved. If you were closer I would buy the whole thing and build it as my next project. Thanks for your courtesy... Joe P.
02-03-2020, 06:17 PM | #23 |
Do you have any current pictures of the frame that you could upload to this thread. The reason for asking the pictures shows the trans but you have already sold that, not sure what else is missing verses what comes with it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-03-2020, 09:12 PM | #24 |
From what you see in the picture I pulled the transmission and front shock brackets. I have a guy that wants the rear braces off the back. I will grind the rivets off don’t want to cut up the frame.
02-23-2020, 07:55 PM | #25 |
A lot of nice parts.
Les |
