02-08-2020, 03:45 PM | #51 |
Proprietor of Dale's Corner
Re: DG4 Below eyeline mirrors, replacement elbows and mirror heads
Are the measurements the same on the passenger door?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
02-08-2020, 04:19 PM | #52 |
Equal opportunity joke ofender
Sometimes looking in the assembly manual will make you not want to look in the assembly manual. There is NO rhyme or reason to the layout of the book that I can see. It is like they sent an intern to the copier room to make a copy of it and the intern tripped on the way sending papers flying. Being in a hurry to get back to the binding dept, he just grabbed all the papers up however, and the binding dept did not look either
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-08-2020, 04:22 PM | #53 |
Dale
I found references to every mirror used except the 72 DG4 and every drawing is only of the drivers door which would lead me to believe they are the same, but that is just my guess
02-08-2020, 04:25 PM | #54 |
McMaster also has stainless studs as well, just be sure to use anti seize
https://www.mcmaster.com/threaded-rods .
02-08-2020, 05:54 PM | #55 |
Great thread ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-20-2020, 04:47 PM | #56 |
The Older Generation
I thought I would bump this back to the top. There was a question asked about measurements a couple of days ago. I am in the process of freshening mine up and installing them on the '72 C30. I didn't see a reference on this in the thread but I noticed on mine the studs on the ends of the elbows were different lengths. Mirror ends were shorter than the bracket ends. This is a work truck so I am not rebuilding with new parts but just cleaning up what is there..... LockDoc
07-20-2020, 05:05 PM | #57 | |
Jim Last edited by FirstOwner69; 07-20-2020 at 05:19 PM. |
07-20-2020, 05:17 PM | #58 | |
My thoughts exactly. LockDoc
07-20-2020, 11:31 PM | #59 |
All about them K’s
Sub’d for later use. Nice work guys, thanks for sharing!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
07-21-2020, 07:36 AM | #60 |
Has anyone checked into the Colony Machine chrome peaked acorn nuts? I put their engine kit on my Harley. Where Harley used a bolt, Colony provided a stud and peaked acorn nut, as Stocker suggested
07-21-2020, 08:29 AM | #61 | |
Great information. Thanks
01-17-2021, 12:14 AM | #62 |
After finding a set of DG4's and associated hardware many many months ago I'm finally ready to install my mirrors but have a few questions to clarify before dropping off at the body shop.
A little background, my SPID has the DG4's listed as an option, but during a prior repaint the owner changed to the Sport Mirrors. I LOVE the DG4's and more importantly I want my truck the way it should be. The Sport mirrors / backing plates are now with Cliff (72 Jimmy Power) in South SF so there's no turning back on this project. When I disassembled the doors and looked inside I can see where the body guy used bondo/fiberglass to fill the holes. On the outside of the doors and in the right light I can see faint signs of where the holes used to be. Anyway, onto my questions. When I measure from the leading door edge to the top hole it is 7.25" (7-1/4") on Drivers side, but on the Passenger side I come up with 8.25" (8-1/4") - arrow on green piece of tape in picture, a 1" difference. I confirmed those are the old holes by using my paint gauge as it reads 0 when I put it on the hole. Anyone else out there with these measurements? Or is the 8.25" right for both sides? I was originally going to use the factory sheet metal bolts, but then the body shop guy starting talking about "Rivnuts" / "Nutserts" and when I looked at some videos these seem to be a much better method to secure the mirrors, has anyone done this? Any horror stories I should know? Observations, 1. the leading edge of where the inner & outer door skins meet just so happens to be 8.25" as well, coincidence? 2. was the drivers side mounted closer to the front of the truck because a person in the drivers seat would want the mirror further away to have a larger side / rear view and on the passenger side the mounting would be back further from the front so the vent window frame did not obstruct your view? All holes will be welded closed, no bondo this go around. I'm tying in this post as it also contains a lot of good stuff tied to these mirrors https://67-72chevytrucks.com/vboard/...d.php?t=795168
Ron 1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White |
01-17-2021, 03:49 PM | #63 |
Found lots of pictures showing how the mirror mounts to the arm, but really good pic of the tripod bracket. So here's my question, what is the sequence of nylon / metal washers that are to be used? # 1 , # 2 or # 3 ?
1. L arm,metal washer, nylon washer, bracket, nylon washer, bracket, nylon washer, metal washer, bullet acorn nut 2. L arm,metal washer, nylon washer, bracket (NO nylon washer) bracket, nylon washer, metal washer, bullet acorn nut 3. "Other" please describe and/or attach picture. 1972 DG4's if that matters.
01-17-2021, 05:39 PM | #64 |
Like this. #2
Jim |
01-17-2021, 05:42 PM | #65 |
Carpe manana
My recollection is it’s like #2 but there were additional fiber washers that need to be accounted for in terms of spacing.
01-17-2021, 05:48 PM | #66 |
Here is another pic for verification
I don’t think these have ever been apart |
01-17-2021, 05:52 PM | #67 |
Old member
If my memory serves me right it's because of the vent window being in the line of sight if you use the drivers side measurement on the passenger side. They move the passenger side further back so the view is clear.
I know these are not the mirrors you are using but just thought I would add this. The shop manuals I have have no measurements for adding them even though they show them. The written part doesn't even say what they are. That one paragraph is all it states on them. I checked all 3 of my manuals for this.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-17-2021, 09:37 PM | #68 |
Interesting and informative thread on the DG4 mirrors. I'm just not sure how many different types were made, but I think GM got them from a few various suppliers and just called them all DG4.
Here's one I found on ebay, supposedly original and I don't doubt it, but it's not what I was after. What's left of my original 1971 Drivers Door DG4. And the one I found, but it's not what I was after . . . |
01-18-2021, 11:05 AM | #69 |
Good stuff guys, appreciate the clarification.
Next question, using the 1972 mirror installation instructions as reference, the drawing shows a "gasket" between the mounting arms and the door skin, what is this "gasket"? Is it simply a nylon washer or ?
01-18-2021, 11:33 AM | #70 |
Carpe manana
Fwiw i thought these were little rubber O gaskets. At least thats what i used. Once installed they cant be seen. Camper mirrors came w a rubber strip for use as a gasket across the top attachment to the door.
01-18-2021, 02:40 PM | #71 |
Since I wasnt going for originality I used nylon washers .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
01-18-2021, 02:48 PM | #72 |
I can't give a definitive answer for the 1972 version, but I am 100% sure that, at least my '69, never had anything between the mirror brackets and the paint.. In other words they were mounted metal leg to painted door metal. I always thought it was odd but not surprising.
Jim Last edited by FirstOwner69; 01-24-2021 at 12:20 AM. |
01-24-2021, 12:15 AM | #73 |
I've been searching for a while and I have what I think are the closest to the original High Crown Acorn nut: 3/8" - 16. I have yet to obtain a stainless steel version that is even close to the original.
Left to Right in picture: Original, Grainger, Midwest Original: Steel, .779" height Grainger: Steel, .782 height, part # 6XEG7 Midwest Fastener: Chromed Steel, .826 height, part # 87036
01-24-2021, 07:41 AM | #74 |
01-24-2021, 10:42 AM | #75 |
I found them in Stainless a while back. They were pricey at about $3 each plus shipping
