Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-15-2019, 01:26 PM   #101
stangtjk
Re: Crossbreed
Originally Posted by chewychevy67 View Post
So is the gate electric now? I Didn't see anyone opening it. What vehicle is the set up from? Gm truck?
Not electric. I was just holding the tailgate at the corner and let go. The damper came from the 14-19 gm trucks however they are not installed in the tailgate as I have done.
On the new trucks the damper in the bedside under the tail light and the shaft goes through the hinge. Wouldn't work that way on the 67-72 trucks because the damper would hit the twilight housing. I had to modify the 67-72 hinge by welding a socket in the center. Then cut down the shaft that came from the 14-19 hinge and ground a hex on it to fit in the socket.
stangtjk is offline   Reply With Quote
Old 08-16-2019, 12:05 AM   #102
chewychevy67
Re: Crossbreed
Wow I love that. I may look into doing that. Did you do it on both trunions or just 1 side?
chewychevy67 is offline   Reply With Quote
Old 08-16-2019, 12:48 AM   #103
stangtjk
Re: Crossbreed
Passenger side only. The damper only provides resistance in one direction so it won't work on the driver's side. I'm also installing the lift assist torsion spring inside the tailgate which will interface with a modified trunion on the driver's side.
Old 08-16-2019, 12:50 AM   #104
chewychevy67
Re: Crossbreed
I was researching this tonight. Can't find much on the easy lift part. Post pictures when you get to it. I am interested in these mods.
Old 08-17-2019, 06:05 PM   #105
stangtjk
Re: Crossbreed
This is the lift assist torsion rod setup. I believe it came from the 07-14 gm trucks. I drilled a hole in the tailgate for it to slide into but should probably place a bushing in there. Also modified the trunnion. I still need to fabricate a block to hold the opposite end inside the tailgate. I'll probably make it so it slides into the pocket I cut out for the damper then plug weld it in place from the bottom of the tailgate.
Old 02-10-2020, 03:44 PM   #106
stangtjk
Re: Crossbreed
Been a while but I finally got around to putting the torsion spring in the tailgate. Made the tailgate open softer and took a little load off closing it up. For the block that holds the end of the torsion spring I just took a thick chunk of metal and cut it to shape with a portable band saw. Made the half moon hole by cutting the block in half and filing a notch in one side then welding it back together. See it in action here link
I still need to adjust the hinges and strikers but it worked pretty good.
Old 02-10-2020, 08:22 PM   #107
litebulblsc
litebulblsc's Avatar
Re: Crossbreed
That is pretty slick
litebulblsc is online now   Reply With Quote
Old 02-10-2020, 09:19 PM   #108
Thealien
Thealien's Avatar
Re: Crossbreed
If you could come up with a "kit" I bet it would sell?
Old 02-11-2020, 12:35 AM   #109
stangtjk
Re: Crossbreed
A kit would be doable but with all the parts and modifications it would probably cost more than most would be willing to spend. Probably close to $200 in parts, couple hours to modify and it's not a direct bolt on so whoever buys it would have to be willing to cut into their tailgate.
Old 02-27-2020, 11:17 AM   #110
chewychevy67
Re: Crossbreed
Ive been looking for the torsion rod parts new but I can't seem to find them. I am definitely going to do that to mod to my gate as well. I'll have to go to the wrecker in spring. I'll bet I'll have to buy a full tailgate thougb
Old 02-28-2020, 04:18 PM   #111
stangtjk
Re: Crossbreed
All parts are available new. Below are the parts I used.
GM part #s
25889654 (torsion rod)
23115812 (damper)
23439650 (right side hinge)
15192282 (left side hinge)
Old 03-01-2020, 10:04 AM   #112
chewychevy67
Re: Crossbreed
I will look those up. Thanks for that
Old 03-29-2020, 08:52 AM   #113
cornerstone
cornerstone's Avatar
Re: Crossbreed
Now that's using yer noggin. Hard work but super cool upgrade. I remember anytime someone other than myself would open my tailgate and I'd hear that slam it'd make me cringe. I know it can handle it but why be so hard on it?
Very cool!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-05-2020, 12:21 PM   #114
kehstr
kehstr's Avatar
Re: Crossbreed
Did you have to wind the torsion bar or dampener up so it would work properly?
And did you end up using a bushing? If so what style?
Definetely doing this!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 04-06-2020, 04:55 PM   #115
Last_Paladin
Re: Crossbreed
Thanks for the tail gate idea.
Last_Paladin is offline   Reply With Quote
Old 10-28-2020, 11:09 PM   #116
chewychevy67
Re: Crossbreed
Anything new lately?
Old 02-07-2022, 11:51 AM   #117
ochre 72
Re: Crossbreed
Originally Posted by stangtjk View Post
Fixed the double wall top.... Cut out each of the 6 sagging sections on top, glued in some rigid foam insulation and glasses over it all... It also got a coat of epoxy primer followed by raptor liner. As much of this stuff that I've used they should be sponsoring this build lol.
Turned out great! what glass did you use ? You made new top sections?
ochre 72 is offline   Reply With Quote
Old 02-07-2022, 02:18 PM   #118
stangtjk
Re: Crossbreed
I used woven fiberglass cloth with total boat epoxy resin. I don't remember the weight of the cloth but it wasn't real thick.. probably somewhere around 6oz and I used 4 layers.
Old 02-07-2022, 02:25 PM   #119
ochre 72
Re: Crossbreed
Thank you. Looks great. Maybe that was 1708. did you do piece per section or 1 large sheet to cover the whole top? Sorry, trying to learn as i go
Old 02-07-2022, 02:44 PM   #120
stangtjk
Re: Crossbreed
Im not a fiberglass expert... this is really the only big fiberglass project I've tackled. I Googled 1708 and that is not what I but I'm sure any cloth or mat you want to use would be fine. I chose normal cloth over mat so it wasn't necessary to sand flat before applying the raptor liner.
In the pictures I posted I did two sections together to test out the method.... I was satisfied with how it turned out so I ordered enough cloth to cover the whole top in one sheet.
