Old 12-02-2018, 01:50 PM   #126
LH Lead-Foot
Re: power window regulators on the cheap
I would like to ask what was used on the center pivot? For this to work, 1 arm needs changed.
I would guess there is a special rivet, one with a shoulder has to be used. This way, it can be peened to hold the arms pivot point in place tightly, yet allowing for proper movement.
If a stepped rivet was used, where did you find it? A bolt with the right size may work but requires a unlock nut installed. I would prefer the rivet approach.
On the farm, rivets where used to hold the blades on the cutting bar of a hay cutter or combine. Maybe, a farm and home would have this hardware.
What say you? Oh great inventor of power windows on the cheap.
Removed
LH Lead-Foot is offline   Reply With Quote
Old 12-02-2018, 11:31 PM   #127
bonnieclyde100
Originally Posted by highwinger View Post
You have to reinstall the spring? I don't recall seeing that in the steps. Any tips?
it was a while ago but im sure I put the spring on and turned the mount to tighten and when I got it tight I installed motor while holding mount to make sure it doesn't unwind. if you let it go before motor is installed it will unwind fast so be careful.
bonnieclyde100 is offline   Reply With Quote
Old 12-02-2018, 11:38 PM   #128
bonnieclyde100
not completely sure what you are talking about but if you talking about the long pieces with the wheels that run in the tracks on them I didn't change them I never even took them apart there were 3 rivets on the end that the big gear attached I grinded off 2 and pivoted it and welded to keep it from turning anymore
Old 12-03-2018, 03:07 AM   #129
LH Lead-Foot
Got it.
Just was not sure what was change on the arms, or roller for the window track. The plastic rollers & rivets for the window lift arm are on LMC and elsewhere.
Thanks.
Happy Holidays.
Removed
Old 12-03-2018, 09:44 AM   #130
highwinger
highwinger's Avatar
thanks...sounds like fun
On another note...these do not come with mating connectors:
Part # : 42-131
Part # : 42-130
and I couldn't find the mating connectors, so ended up buying the following because they come with a set of mating adapters:
Dorman 742-142
Dorman 742-143
highwinger is offline   Reply With Quote
Old 12-23-2018, 01:59 PM   #131
highwinger
highwinger's Avatar
Anyone know if I should mount the gear centered as the thread suggests or rotate it 90deg from how it was previously mounted? This is a 69 suburban 3rd door not a pickup btw. You can see the gear is aligned 90deg with the holes and the gear isn't centered.
Thx & Merry Christmas
Old 01-28-2019, 09:57 AM   #132
carwasher
Has anyone done this to a 1966 c10 ? just found the you tube video on the 65. Nice job
carwasher is offline   Reply With Quote
Old 02-07-2019, 11:03 PM   #133
999Tinman
Could someone by any chance pm me pics of each side? With my luck I will weld it backwards and I dont really want to to that. Great thread! Love a good diy
999Tinman is offline   Reply With Quote
Old 02-08-2019, 09:49 AM   #134
highwinger
highwinger's Avatar
Disclaimer: not an expert and I have a suburban
Looking on LMC, they show the same regulator for the Burb and trucks. When I did my 3rd door (passenger side) it was back from the pictures shown. Here’s my comparison vs the pictures. See the chicken scratches on the printed page. So it’s my opinion the pics are swapped. Also, when I installed with Brothers felts, the motor still isn’t enough to move the window.
Old 02-08-2019, 08:33 PM   #135
999Tinman
Thanks for the pics and the info. I watched your video. How long have they been un your truck? Still happy with them?
Old 02-09-2019, 01:06 AM   #136
highwinger
highwinger's Avatar
I don’t think I did a video. I only did one and it still doesn’t move the window up & down so I’m not very happy. It may be the window felts tho. I’ve bought other runners from Brothers and then triplanes them so that may be the problem.
Old 02-09-2019, 01:10 AM   #137
999Tinman
Sorry wrong fellow.
Old 02-09-2019, 10:56 AM   #138
70STOVEBOLT
70STOVEBOLT's Avatar
Mine bound up too with the old weatherstripping about 3/4 of the way up so I will have to adjust the tracks a little bit and revisit it later because I got discouraged
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-21-2019, 10:03 AM   #139
mygmctruck1
I have been researching all this out and I like it . I did find a complete setup for a Chevy truck from a 94-05 . Ebay
Less than $80.00 for the pr. Has anyone tried these or will they even fit our trucks . Just curious , if they fit , this is a good way to go.
mygmctruck1 is offline   Reply With Quote
Old 02-21-2019, 09:11 PM   #140
elf w/capital T
Thats so cool! Thanks for the inspiration! One day ill do it and use your ideas! Thanks!
elf w/capital T is offline   Reply With Quote
Old 02-10-2020, 11:37 AM   #141
Deer_hunter_088
Deer_hunter_088's Avatar
I dont know if anyone watches this thread, but it almost looks like a s10 motor would work (mine are all metal, i may build one and see if they are interchangeable!
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 02-11-2020, 07:17 AM   #142
Metaldoc
Metaldoc's Avatar
My regulators and 95 chev truck motors 9 tooth
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 02-12-2020, 12:26 AM   #143
Deer_hunter_088
any suggestions to someone thinking on making them?
1998 S10ZR2
Old 02-12-2020, 05:24 AM   #144
Metaldoc
Metaldoc's Avatar
I'm sure for most people with a couple of basic tools and a welder this can be done very easily. I did mine 2 yrs ago and no issues. I used micro switches that control relays that control the windows. I love having P/W now
Old 03-03-2020, 09:10 AM   #145
Thealien
Thealien's Avatar
Nice!
Old 03-05-2020, 01:09 AM   #146
gmc684x4
I have several of the 88-98 parts trucks to donar window motors great work
gmc684x4 is offline   Reply With Quote
Old 08-17-2020, 05:34 PM   #147
ccautoupholstery
Can someone that has done this conversion please help...i am for some reason going full stupid at the moment lol. When finished and mounted in the truck does the power motor sit up towards the top of the door or the bottom? I feel like the gear gets rotated down 90 degrees and the motor would sit near the bottom but when I look at pics and the video I feel like it is opposite
ccautoupholstery is offline   Reply With Quote
Old 08-17-2020, 09:29 PM   #148
70STOVEBOLT
Should be at the bottom
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-18-2020, 08:07 AM   #149
70STOVEBOLT
If your motor is at the top you may have the RH side in the LH door or vice versa.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 09-01-2020, 03:06 PM   #150
Metaldoc
Metaldoc's Avatar
I tried to clear it up
