Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-13-2020, 07:38 AM   #1
rustycars63
how to wire 12 volt ignition with stomp starter 1953 chevy truck
Is resistor needed for 12 volt system with points and using the stomp starter ?
rustycars63 is offline   Reply With Quote
Old 02-13-2020, 12:53 PM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: how to wire 12 volt ignition with stomp starter 1953 chevy truck
I'm not real sure but I would say yes. The resistor wire wasn't stopped being used until the GM HEI was put in vehicles.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-18-2020, 05:21 PM   #3
Wrenchbender Ret
Yes. A resister is needed. You can use the switch that goes on top of the for 55-59 models. It has a term. on the side that bypasses the resister while the starter is cranking.
George
Wrenchbender Ret is offline   Reply With Quote
Old 02-24-2020, 09:57 AM   #4
rustycars63
Thanks for the info.
