01-31-2020, 11:45 PM | #1051 |
Re: What did you do to your truck today.The 3rd chapter
I had a leaky stamped steel valve cover, so used it as an opportunity to get some Chevy LT-1 7-rib cast aluminum ones. GM Performance P/Ns 474207 & 474208. Fel-Pro VS 12869 T gaskets. 1-1/2 x 20" stainless bolts cut down to 1-1/4" did the trick. Bolted on this evening. Fancy for a farm truck, but I should pick up a few HP with these valve covers, yes?
That's a Mr. Gasket fuel 1-6 psi regulator on the fuel line (P/N 9710). The Edelbrock 1405 can handle no more than 4-5 psi, otherwise I get a very strong gas smell.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
02-01-2020, 12:01 AM | #1052 |
Moved it out of storage and to the lift. Put the new 20” Torque Thrust’s on it and I dig the new ride height.... the rear bumper AAA sticker is RaD too.
02-01-2020, 12:08 AM | #1053 |
Who Changed This?
Drove to the storage yard and took the batteries out of the trailer to take back home to charge them. Some poor sap was backing his trailer into his spot and hit another vehicle...one of those tall Mercedes units. He only scraped the paint, but you know that that is going to cost a mint. He asked me to spot for him, and I did, so we got the trailer back into his parking space without further damaging the adjacent unit...or his.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 02-01-2020 at 11:44 AM. Reason: typo |
02-01-2020, 08:42 AM | #1054 |
Installed the restored tachometer cluster, tilt steering column and Comfort Grip Steering wheel in the K10 short bed.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
02-01-2020, 10:01 AM | #1055 |
Bought a new cluster, steering column, wiring harness, and radiator. And started tackling the rusted out inner cowl. Spot weld drilling in a bit.
72 C10 lwb fleetside aka Big Rhonda. Still plugging away. Build thread: http://67-72chevytrucks.com/vboard/s...42#post8247142 |
02-01-2020, 04:45 PM | #1056 |
Carpe manana
Had a local shop build a 4wd power steering hose using the OEM ends.
02-01-2020, 04:49 PM | #1057 |
Proprietor of Dale's Corner
That looks good.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
02-01-2020, 04:50 PM | #1058 |
Carpe manana
Thanks I was pleased - I’m going to use it on the k20 this spring when I update the power steering box. Turns out the guy who built it also has a 1972 Blazer he works on.
02-07-2020, 08:10 PM | #1059 |
Installed my NOS steering wheel that I got from atog (thanks Jeff). And the horn cap I sent to Curtb to have restored (thanks Curt).
02-07-2020, 08:26 PM | #1060 |
This
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
02-09-2020, 03:22 PM | #1061 |
Wired and tested gauge panel
Got it wired and bench tested. I was able to test all but the tach and oil pressure gauge. The oil pressure gauge did what it was supposed to with power on and grounding the sender terminal. I will have to wait for the final verdict when it's connected to the running motor.
02-09-2020, 04:40 PM | #1062 |
Prepping my bed for paint. I’m going to give the art of painting a shot. Just trying to match the front, old paint job look. If it goes well I might paint the whole thing myself in a couple years.
02-09-2020, 07:18 PM | #1063 |
Yanked the engine for oil leaks, clutch stuff, 3 speed OD tranny, clean and paint.
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
02-09-2020, 09:53 PM | #1064 |
Got the back end of mine all done except bump stops and brake lines. Replaced the last frame cross member as mine was bent up pretty bad. Buddy that I bought my truck from has an old 68 frame so I got it from him. Strppied, primer, painted and bolted it in.
Doing some scrubbing on the rust now and will start front end work soon.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra Last edited by 67C10Step; 02-10-2020 at 04:03 PM. Reason: Photo Flip |
02-10-2020, 11:11 AM | #1065 |
We had a dry day of opportunity, so the bench was removed to repair the beginnings of a small tear.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
02-17-2020, 08:31 PM | #1066 |
Just waiting for carpet.
Ps. Sorry my dudes... I can’t figure out how to get the pics oriented correctly.
1968 C10 |
02-17-2020, 10:29 PM | #1067 |
Who Changed This?
Drove it back from camping this weekend.
02-18-2020, 05:35 PM | #1068 |
Old member
I picked up the bed for mine Sunday! 7hr round trip was worth every mile. Thanks to member Flashed on here.
The bed should match up very well with the cab.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-20-2020, 07:40 PM | #1069 |
70+ ( Old Skool Club )
Actually did it night before last but close enough. Received my first bunch of parts for the small block 400 build that will be going in Ole Greenie so went to friends place that is doing the build and unboxed and checked the parts for damage and correctness.. Next up, the heads in month or 2 maybe 3..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-20-2020, 10:06 PM | #1070 |
At the body shop.
New 15 inch steering wheel from Ebay.
And an old lecarra horn button. Much improved over the 88-94 wheel that was in it.
" That didnt make it any newer " " Dont antique the equipment " |
02-20-2020, 10:09 PM | #1071 |
Carpe manana
Received my rebuilt power steering pump from Powersteering.com - Marty does good work
02-23-2020, 07:38 PM | #1072 |
With the weather in the 50s today, I decided to take the truck for a quick ride around the neighborhood. It reminded me that I really need to try and correct the wandering steering problem I have.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350 1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job 1953 Buick Special. GM 355. Just a good smooth engine. |
02-24-2020, 03:50 AM | #1073 |
Wood paneling project completed - need to get some good pics of the accessories mounted...
02-24-2020, 09:07 AM | #1074 |
OregonNed,
Holy smokes, I cannot even say how good that wood looks! Masterpiece. I've not gotten up the nerve to start pulling the front end from under mine just yet so I scrubbed her down and rubbed on the rust a bit. Had to do some repairs on my trailer so that was about it for the weekend.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra Last edited by 67C10Step; 02-24-2020 at 11:08 AM. Reason: Add update |
02-24-2020, 11:42 AM | #1075 |
Old member
I got these last week for the Ramp truck. Next day I left for 2 weeks. I hope to get them installed soon. Maybe even some flame throwers installed to!
