Old 01-31-2020, 02:14 AM   #951
Ptjsk
Re: What did you do to your Blazer/Jimmy today?
Originally Posted by 3757chevy View Post
Looks good .
Amazing what wheels and tires can do!
Pat
Ptjsk is offline   Reply With Quote
Old 02-01-2020, 06:05 PM   #952
BIG BLOCK JIMMY
BIG BLOCK JIMMY's Avatar
Removed old gas tank as step one for installing the EFI kit and new tank. I also figured out why the Jimmy rained gas when I filled it up! I guess the PO thought JB Weld was a good idea?
Photo of my dog, just because he's mad that I have ignored him today.
72' JIMMY 454
Last edited by BIG BLOCK JIMMY; 02-01-2020 at 06:08 PM. Reason: Photos didn't show up
BIG BLOCK JIMMY is offline   Reply With Quote
Old 02-02-2020, 09:51 AM   #953
jaros44sr
jaros44sr's Avatar
always amazes me what the PO's do, you found a new one
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-03-2020, 12:38 PM   #954
mister.freeze
mister.freeze's Avatar
Originally Posted by 72 Jimmy Power View Post
Took it out of the garage.
Well I drove mine to work. Again.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 02-05-2020, 08:37 PM   #955
3757chevy
3757chevy's Avatar
I drove mine to work Today . It was melting and refreezing . Made for some crazy ground effects. (sorry for poor picture quality)
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 02-22-2020, 02:39 PM   #956
CamTra
CamTra's Avatar
Bought mine!! Looking for a rear seat now.
CamTra is offline   Reply With Quote
Old 02-22-2020, 09:46 PM   #957
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Welcome to the K5 club!
Old 02-25-2020, 10:13 AM   #958
SoCoC10
SoCoC10's Avatar
First test drive between snow squalls. Finished a few upgrades and repairs including installing a rebuilt TH350.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 02-26-2020, 11:08 PM   #959
SoCoC10
SoCoC10's Avatar
Bath time. “0000” steel wool and CLR followed by a coat of wax.
Old 02-26-2020, 11:17 PM   #960
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Pics please...
Old 03-07-2020, 12:53 PM   #961
litebulblsc
litebulblsc's Avatar
Replaced a busted headlight retainer. The screws from LMC are incorrect, so reused the originals. Also replacing the gauge cluster. Going to order a connector so it won't be done today
litebulblsc is offline   Reply With Quote
Old 03-07-2020, 11:38 PM   #962
mortoyz
Active Member
Put the new LT Motor/8l90 transmission in the Jimmy today. Not sure why the pictures are upside down and sideways?Name:  Jimmy1.jpg
mortoyz is offline   Reply With Quote
Old 03-08-2020, 01:20 PM   #963
jaros44sr
jaros44sr's Avatar
I agree with the screws, no where else are they used, the pointed end helps to align. I alays keep extras around
for the life of me, can't figure out your backgroud, is it a truck part?
SAFETY FIRST
AS usual, off topic
Jim
Old 03-08-2020, 02:25 PM   #964
Ryanz
Originally Posted by DeadheadNM View Post
Did you find this a difficult project? The install of the tach and vac guages?
I'd like to do the same.
Ryanz is offline   Reply With Quote
Old 03-08-2020, 04:33 PM   #965
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Cluster swap/upgrade isn't too hard. It's a half day project. If your K5 wasn't equipped with a tach originally you need to plan where to route the tach harness - I've drilled the 0.75" firewall hole in the correct spot, it's easy and there are a few threads dedicated to this. Use a line wrench to loosen the oil pressure line if so equipped in order to avoid stripping the brass. Good time to swap steering column too if that's on the menu. If you need a tach/vac cluster check with Tbone Tom as he provides a good service.
Old 03-08-2020, 07:11 PM   #966
PDXk5
PDXk5's Avatar
I decided to tackle refurbishing a spare hatch I have. I separated the two sides and am starting to remove hardware that refused to come off. (One of the latches had the welded nuts break from the spot welds and I couldn’t get it off until the hatch interior was exposed.)
I can’t get the struts to come loose. Been spraying it with PB Blaster. Started drilling out one sides screws (those things are tough! Still haven’t made it through them yet).
Sorta following this thread but with more miss steps...
http://67-72chevytrucks.com/vboard/s...d.php?t=403730
Anyone know what these are? They were only on one side and I haven’t seen them on other hatches with the latches removed.
PDXk5 is offline   Reply With Quote
Old 03-09-2020, 04:52 AM   #967
litebulblsc
Tire, Super Swamper Bogger
Old 03-09-2020, 11:13 PM   #968
Jeff1971
The circle is around what looks like an anti rattle bumper. Mine had foam blocks stuffed inside the lower area where the latch rods are. That looks like it could be a stock piece.
Jeff1971 is offline   Reply With Quote
Old 03-10-2020, 09:43 PM   #969
1rippen6
Yes, I have a few rods with the same boot on them. I wouldn't drill the strut bolts out if you have access to a welder. Weld a nut to the head and then try to turn it out. The corner window seal bolts are the same, I have more if you need them. How or what did you use to split the hatch in half.
1rippen6 is offline   Reply With Quote
Old 03-12-2020, 01:13 AM   #970
PDXk5
PDXk5's Avatar
I used a thin putty knife and hammer to tap the putty knife into the seam between the two halves. I went slow and it worked pretty well.
That’s a great idea for the strut bolts. I don’t have access to a welder but maybe I can have a local guy that does welding do it for me. I’ll make some calls.
Old 03-25-2020, 07:25 PM   #971
litebulblsc
Second day of stay home order, I got my new cluster wired up and installed. Still have to install the huge oil pressure sensor, which I am not looking forward to. But other then that, everything is hooked up.
Old 03-26-2020, 04:46 AM   #972
CamTra
CamTra's Avatar
Had the wife and daughter sew up a makeshift seat cover so we can ride and enjoy as I wait for my ordered seat cover to come and finish getting restored.
Old 03-26-2020, 11:33 AM   #973
72 Jimmy Power
Hi, Changing rear end fluid Today. Then this weekend going to start undercoating the entire frame. Probably going to take awhile.
72 Jimmy Power is offline   Reply With Quote
Old 04-01-2020, 09:08 PM   #974
SoCoC10
SoCoC10's Avatar
Cleaning and painting/dyeing the Ochre K5s Parchment interior pieces.
Old 04-02-2020, 06:29 PM   #975
SoCoC10
SoCoC10's Avatar
Trim clean polish and paint.
