12-23-2019, 06:57 PM | #3201 |
Re: PO has me PO'd
In case someone does not realize, the last 2 "pictures" are actually videos. You have to click on them.
Cool to see it running. |
01-30-2020, 03:05 PM | #3202 |
Re: PO has me PO'd
[url=https://flic.kr/p/2in4NNi]20200130_132152
recieved new rotors from rock auto part #5020 had them pressed off and new pressed on, now to reinstall hub, only problem duplicate shipment, may put up on parts board
01-30-2020, 04:26 PM | #3203 |
Carpe manana
Re: PO has me PO'd
Nice! I have that same canvas tool bag - picked it up over 30 y ago.
01-31-2020, 11:53 AM | #3204 | |
Re: PO has me PO'd
I think my tool bag was first used by the medics in my MC days Congrats on your newest award, TOTY
01-31-2020, 03:45 PM | #3205 |
Re: PO has me PO'd
[url=https://flic.kr/p/2insGdy]20200131_141700
Front hub is disassembled. light rust removed, gave it a couple coats of grease and bees wax, the one you buy at the hardware store (toilet seal ring) I don't want to take it to far apart, but I don't want it to rust much more, so I use a coating of wax and grease PO was in here before me, screwed up the bearing races slightly
02-02-2020, 11:45 AM | #3206 |
Re: PO has me PO'd
[url=https://flic.kr/p/2iocEVN]20200202_103648
Not sure if you can see it, but the PO was in here grinding on the bearing seat. some people shouldn't have tools
02-04-2020, 08:11 PM | #3207 |
Re: PO has me PO'd
[url=https://flic.kr/p/2ipbQKQ]20200204_110121
This maybe my most useful tool yet, worked great for seeing inside hub to align locking rings and plate
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-04-2020 at 08:19 PM. |
02-04-2020, 08:16 PM | #3208 |
Re: PO has me PO'd
[url=https://flic.kr/p/2ipaLKM]20200204_104401
[url=https://flic.kr/p/2ipaLL8]20200204_104442 when you first take the hub apart, check to see if the threads are in good shape. Nothing worst then cross threading these retaining nuts As you can see, the PO didn't have the proper tool, so he just used a punch, damaging the outer locking nut Not shone, a plate that sits on the bearing, supports the spring for the locking hub
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-04-2020 at 08:25 PM. |
02-04-2020, 08:31 PM | #3209 |
Re: PO has me PO'd
[url=https://flic.kr/p/2ipaLSf]20200204_110149
If the slot is at 12 o'clock, then my pin is at 11:50 put a lttle grease on it so it won't fall off as you're trying to assemble
02-05-2020, 06:47 PM | #3210 |
Re: PO has me PO'd
[url=https://flic.kr/p/2ipxJQk]20200205_13011
caliper mounted, looked every where for new mounting bolts and used bolts, but all I could find were chinese knockoffs, any ideas would be helpful? [url=https://flic.kr/p/2ipvbiH]20200205_130217 not sure on these brake pad retaining clips, are they just for assembly or do they stay on? so, after talking to Wes, he has used the after market ones with success, just ordered from Rock Auto we'll see friday
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-05-2020 at 07:24 PM. |
02-07-2020, 02:20 PM | #3211 |
Re: PO has me PO'd
[url=https://flic.kr/p/2iqkSZE]20200207_124548
stub axle? wanted to move in about 3/8" making it difficult to get the snap ring seated, found a bolt with fine threads that would grab it, allowing me to pull out finished lock out, may send chrome cover out to get replated, only fugley piece of the whole system Deadhead Minn. seems to have a good source [url=https://flic.kr/p/2iqmcid]20200207_130214
02-07-2020, 02:48 PM | #3212 |
Re: PO has me PO'd
after thought, I think I read somewhere maybe Special K, that you should only use a light oil on this step of the reassembly, as grease is to heavy and sticky to allow proper function of the lock out
02-07-2020, 03:12 PM | #3213 |
Equal opportunity joke ofender
Re: PO has me PO'd
I think that is correct. I do remember 1st time I pulled hubs on the 69 I had at the time, I greased the lockouts when I put them back together and 1st time I needed them could not get them to lock in.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-07-2020, 08:20 PM | #3214 |
Re: PO has me PO'd
[url=https://flic.kr/p/2iqsVRH]20200207_191431
As Wes said, these caliper bolts are a direct replacement, except bolt head size Thanks Richard for confirming that, still have that piece for the heater shroud, just been to busy to ship
02-25-2020, 01:12 PM | #3215 |
Re: PO has me PO'd
Attempting to bench bleed my M/C, bought some metal pre flared tubing from NAPA (7/16 and !/2") just bent by hand to circle back into m/c chambers
never tried this method before, so we'll see how it goes. Videos on line show it just leaking out of the ports. as long as the tubes are below the fluid level in the chambers I think this will work still have to build a bracket to keep the plunger from moving [url=https://flic.kr/p/2ixAC1R]20200225_112606
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-25-2020 at 01:37 PM. |
02-26-2020, 11:51 AM | #3216 |
Re: PO has me PO'd
[url=https://flic.kr/p/2ixXmGx]20200226_103820
Seems like this method worked, just loosened up the three bolts, 1 for the M/C bolt and 2 for the prop valve, so I could start the fittings by hand, nothing worse than cross threading fittings at this point!! Now onto the bleeders Thinking of supporting the safety pin on the prop valve, so it doesn't slide open, but can't think of a way yet Forgot to mention that I pushed on the pedal when the recirculating pipes were in place, seemed to get the air out This old coating from eastwood seems to be impervious from brake fluid
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-26-2020 at 12:01 PM. |
02-28-2020, 05:36 PM | #3217 |
Re: PO has me PO'd
[url=https://flic.kr/p/2iyEDaq]20200228_102124
I've got brakes.... Not overly impressed with my chinese knockoff of a mighty vac. Zero setting was off by 4 inches of vacuum, fitting were a bit large to seal on the bleeder. I worked around them Pumped it up to 25 inches, opened up the bleeder, and sucked fluid into the container. CAREFUL, the back chamber on the M/C is very small. On first pull, you can empty it quickly, after that you can fill up the cannister 1/2 way, before the chamber needs fluid I bleed it down till I have about 10 inches then shut off bleeder Great method for a one man bleeder
03-02-2020, 08:19 AM | #3218 |
Re: PO has me PO'd
[url=https://flic.kr/p/2izHniz]20200302_070417
[url=https://flic.kr/p/2izMjEz]20200302_070442 Just B/C you can , doesn't mean you should, but I like it, and it's mine
03-02-2020, 10:44 AM | #3219 | |
Re: PO has me PO'd
I like it, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
03-04-2020, 09:52 AM | #3220 |
Re: PO has me PO'd
[url=https://flic.kr/p/2iAuDwb]20200304_082509
Yeah, Rg, I find it ironic that this is in my own PO has me PO'd thread, but I want people to know I am making a left hand turn
03-09-2020, 10:08 AM | #3221 |
Re: PO has me PO'd
I like the symmetry of it.
Rg
03-09-2020, 07:55 PM | #3222 |
Re: PO has me PO'd
Thanks Roger, that is the word I was looking for and it fits, plus it can easily be undone done the road if the post owner doesn't like it
03-11-2020, 11:49 AM | #3223 |
Re: PO has me PO'd
[url=https://flic.kr/p/2iDgNHK]20200311_104331
Trying to hook up my vacuum gauge, needed to find a coupling that would fit the adapter on the gauge. Home depot had this kit available
03-11-2020, 12:08 PM | #3224 |
Re: PO has me PO'd
my vacuum gauge on the pump is about 5 inches off
[url=https://flic.kr/p/2iDd3L8]20200311_110422 BTW, I want to thank Harlowhead for sending me the female electrical connecter for the harness coming off of my steering column free of charge, not even shipping, what a good member. Things like that make this the best board on the net Thank you Harlowhead!!!!!
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-11-2020 at 12:26 PM. |
04-22-2020, 09:07 AM | #3225 |
Re: PO has me PO'd
