01-24-2020, 11:44 PM | #226 |
Re: slammed 57
OOooOoOOooooo pretty
01-25-2020, 12:34 AM | #227 |
Re: slammed 57
Nice choice...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
01-25-2020, 03:52 PM | #228 |
Re: slammed 57
That sounds like something my wife would say, she doesn't get it either...
01-27-2020, 03:50 PM | #229 |
Re: slammed 57
Had to pull the rear axles to put the rears on, not a big deal,
01-27-2020, 03:59 PM | #230 |
Re: slammed 57
Still gotta plumb the brake lines now, should be a crime to hide them behind the wheels!
01-27-2020, 04:00 PM | #231 |
Re: slammed 57
Looks good...Jim
01-27-2020, 05:03 PM | #232 |
Re: slammed 57
That's a interesting wheel....never seen them with the tig weld like that...
01-27-2020, 05:13 PM | #233 |
Re: slammed 57
its not tig welded, just a pattern done by a cnc machine that gives it a tig look. just an option that billet specilties wheels offer.
01-27-2020, 06:27 PM | #234 |
Re: slammed 57
Ahhhh...ok...
01-28-2020, 02:01 AM | #235 |
Re: slammed 57
that rear wheel looks like a dryer tub!
01-28-2020, 11:37 AM | #236 |
Re: slammed 57
Nice selection of parts on the calipers. The build overall is looking great!
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
01-31-2020, 12:23 AM | #237 |
Re: slammed 57
my friend, you do great work. sure is looking good. Can you hear the engine roar yet? soon though soon.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
02-02-2020, 05:34 PM | #238 |
Re: slammed 57
thank you sir!
02-02-2020, 05:35 PM | #239 |
Re: slammed 57
let me know if you need and cloths dried, we'll throw"em in
02-02-2020, 05:38 PM | #240 |
Re: slammed 57
Thanks morrie, as for the motor, I havent tried it yet, I decided to go with a different cam and carb, probably do so around june or july I will address it
02-03-2020, 12:45 AM | #241 |
Re: slammed 57
A new Cam, with a larger lope maybe?? What about the Carb, why did you change that out?? what did you go with??
02-03-2020, 09:35 AM | #242 |
Re: slammed 57
02-03-2020, 02:57 PM | #243 | |
Re: slammed 57
current set up 454 .60 over 4.310 bore 2 main block 4.00" eagle crank 4340 egale 4340 rods trick flow rollers ( but going instead with morel rollers) 280 trickflow aluminum heads oval ports single plane intake oval (but goin to get a dual plane on it for better street manners) balancer ( i still need to get but not sure which to get) probe pistons right around 11:1 compression Last edited by slammed57; 02-03-2020 at 03:10 PM. |
02-13-2020, 10:37 AM | #244 | |
Re: slammed 57
02-15-2020, 09:20 AM | #245 |
Re: slammed 57
I thought the same, and still kinda thinking the same as you. those guys over at AED carbs said 850 is good, I asked wouldn't the 750 be more responsive, he said yes but I will be leaving some HP on the table if I went with the 750. But as I sit here and type I am thinking I rather have the better throttle response since Its only a street driven truck and will never see the track. It will probably still have plenty of HP for the street with the 750. What you think morrie?
03-08-2020, 12:15 PM | #246 | |
Re: slammed 57
03-09-2020, 12:02 AM | #247 |
Re: slammed 57
For drivability I’d stay with a 112 LSA cam. A 109 will be lopy but will idle poorly n will have low vacuum. 109 is boarder line street/strip. I’d investigate to make sure it’s what you want
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
03-09-2020, 10:31 AM | #248 | |
Re: slammed 57
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 Last edited by my56chevytruck; 03-09-2020 at 10:38 AM. |
03-09-2020, 01:06 PM | #249 |
Re: slammed 57
I agree with you mark. thanks bud
03-09-2020, 01:08 PM | #250 |
Re: slammed 57
the cam in it now is a 112lsa. Iam still goin with the 109lsa just because I love the way it sounds.... If I get tired of it I can always throw the 112 back in. I do appreciate bud
