03-15-2020, 09:14 PM | #1 |
Fender Flares
Recently bought a 04 chevy 2500 hd and the bed had some damage from a tire blowout which bent up the bed behind rear wheel and knocked off the flare in the process, I was able to pull out the dent as good as i could and want to remount the flare, where do I get the stick tape to do so?
72 GMC Burb barn door 4X4 350/350 PS PB Tilt ( gone but not forgooten) 64 Chevy II V8 Loaded Wagon 2004 Chevy 2500 HD Sonoma County, Northern CA |
03-15-2020, 09:22 PM | #2 |
Re: Fender Flares
Any parts place should the tape. It’s 3m double sided molding tape. It comes in all kinds of widths.
03-16-2020, 10:26 AM | #3 |
Re: Fender Flares
03-16-2020, 03:41 PM | #4 |
Re: Fender Flares
OK so is there a trick to mounting them? My thought was fasten tape to flare 1st then fasten fastners to wheel well the pull tape off other side a little at a time and work your way around, Thoughts?
03-16-2020, 05:05 PM | #5 |
Re: Fender Flares
You mount one side of the double sided tape to the flare and leave the wax paper/plastic on the side that goes against the truck bed, with a little of the paper/plastic sticking out. You then mount the fender with the hardware at the arch and then pull the wax paper/plastic out so the adhesive contacts the fender and sticks.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
