Old 03-22-2020, 09:05 AM   #101
reaper71
reaper71's Avatar
Re: My 56 build
Nice work
Mark
reaper71 is offline   Reply With Quote
Old 03-22-2020, 11:31 AM   #102
LOW A D
Re: My 56 build
I just read through your whole build. You are doing a great job! That's some serious rust repair you did but it turned out great! How do you install your tailgate with the bung mounted to both box sides? I'm planning to get those same tailgate latches. Keep posting, I'll be following your build
LOW A D is offline   Reply With Quote
Old 03-22-2020, 07:39 PM   #103
Jason 56
Re: My 56 build
On the TF there is a rear sill panel that the box sides bolt to. I welded nuts to the sill because it’s tough to get to the inside now that I’ve rounded the bottom of the stake boxes. In hind sight I may go the other way and weld the sill to the box sides and go back to a bolt for the hinges. 1 bolt vs 3. I’m shooting for the cleanest look I can get. We’ll see
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 03-24-2020, 09:22 PM   #104
Jason 56
Re: My 56 build
Worked on the rear fenders today. I’m hoping this is going to be my last rust repair on the truck. Turned out well so far. I have to finish the left side yet. Probably this weekend.
Old 03-24-2020, 09:30 PM   #105
Jason 56
Re: My 56 build
I forgot to post these pictures earlier. I removed the drip rail in late December.
Old 03-25-2020, 10:13 AM   #106
Tempest67
Tempest67's Avatar
Re: My 56 build
looks really good,
thanks for sharing
Tempest67 is offline   Reply With Quote
Old 03-25-2020, 11:36 AM   #107
slammed57
slammed57's Avatar
Re: My 56 build
came out nice!!!!!!
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 03-26-2020, 09:26 AM   #108
my56chevytruck
my56chevytruck's Avatar
Re: My 56 build
Looks great. Nice work!!
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 03-28-2020, 07:33 PM   #109
Jason 56
Re: My 56 build
Thanks for the compliments everyone!
Spent some time in the garage today. Box is getting really close. Finished my rust repair. Frenched in my 50 Pontiac taillights. Thanks to barnfind62, that’s where I got the idea to use them! Have to fix the right side step, it tin cans because it got too hot welding. So I’ll cut 2 sides and try it again. Then onto front inner fenders, maybe tomorrow
Old 03-28-2020, 07:43 PM   #110
Jason 56
Re: My 56 build
Thanks to jesse49chevy for the idea to make a jig/tool for cutting perfect circles with a plasma cutter. I used a scrap piece of 1/8 and an old beat up center punch. All you have to do is drill a fender hole and cut away! Perfect circles!
Old 03-28-2020, 08:26 PM   #111
62 Barnfind
62 Barnfind's Avatar
Re: My 56 build
Nice job! They came out great.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 03-29-2020, 07:51 PM   #112
Jason 56
Re: My 56 build
Started on the inner fenders today. You can see my metal bending jig consisting of 4x4’s and my driveshaft works ok! I reused the top and front of the old inner fender.
Old 03-29-2020, 07:56 PM   #113
Jason 56
Re: My 56 build
Few more pictures. Still have some more bending to do to get it to fit right
Old 03-29-2020, 07:58 PM   #114
dsraven
Re: My 56 build
Make sure to run the suspension through a full stroke to make sure nothing hits.
Looks good. Use what you got for tools.
Old 04-01-2020, 12:14 AM   #115
Jason 56
Re: My 56 build
Spent a few more hours in the garage today. Made metal brackets that mount on the firewall to hold the inner fender. Finished the left side and started on the right. Think I must of installed and removed that fender 20 times to get it right!
Old 04-07-2020, 11:20 PM   #116
Jason 56
Re: My 56 build
Finished the right side inner fender today. Came out nice! Was more work than I expected, but most everything I do is like that lots of putting them on and taking them back off! Going to finish rounding the area of the cab where I rounded the doors. Then onto the hood. Haven’t had that out of the basement since I started. Plan on pancaking it. Taking about an inch out of the front. Also spent some time to make some tire blocking so I can work on the lower half! I saw them on a couple different motortrend shows.
Old 04-08-2020, 10:36 AM   #117
Tempest67
Tempest67's Avatar
Re: My 56 build
nice work.... it is amazing to see this done with 'old school' equipment.
Thanks for sharing
Old 04-11-2020, 10:20 PM   #118
Jason 56
Re: My 56 build
Thanks for sharing
Thanks, I just use what I have to work with! Normally comes out pretty nice!
Old 04-11-2020, 10:31 PM   #119
Jason 56
Re: My 56 build
Got the truck pushed outside for the first time since last fall. Supposed to get a big snowstorm tomorrow oh well. Got the hood stripped. First time I’ve had it out of the basement in nearly two years. Only one small rust repair to be done. And I thought I was done with that Hopefully I’ll get time tomorrow to start pancaking the hood!
Old 04-11-2020, 11:32 PM   #120
LOW A D
Re: My 56 build
The truck is looking good! I like the tail lights!!
My build- 51 Chevrolet
Old 04-12-2020, 05:35 PM   #121
washington blue
Re: My 56 build
Really nice work and nice stance too.
washington blue is offline   Reply With Quote
Old 04-12-2020, 09:49 PM   #122
sginphx
Re: My 56 build
Nice Build!! Getting closer and closer!!
sginphx is offline   Reply With Quote
Old 04-12-2020, 10:18 PM   #123
Jason 56
Re: My 56 build
Thanks everyone for the kind words.
Finished rounding the cab where I rounded the door. Also managed to get a good amount of the hood done today. I’m really happy how it’s coming out!
Old 04-12-2020, 10:24 PM   #124
Jason 56
Re: My 56 build
Few more pictures of the hood. It took 26 vertical cuts to maintain the shape up front. Last 2 pictures are before and after. I’m liking it
Old 04-12-2020, 11:30 PM   #125
oldman3
oldman3's Avatar
Re: My 56 build
nice job...Jim
oldman3 is offline   Reply With Quote
