03-30-2020, 10:41 AM | #26 |
Re: Is it timing, carburetor or something else?
post 3 pictures one of each side of the engine and one of the carb from the top , All with the air filter off and engine off.
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-30-2020, 11:37 AM | #27 | |
Who Changed This?
OP- Add a pic of the head where the plugs screw in, we can verify what plug type is proper.
03-30-2020, 12:15 PM | #28 |
It's a 292. Only one "side."
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
03-30-2020, 02:06 PM | #29 |
Well...
Actually 6 drivers side passengers side bottom side top side in side out side
03-30-2020, 02:10 PM | #30 |
From OP's video on post #17.
Blue paint and dimpling on block indicates possibly mid 80's Mexican block. No big deal. Plugs in head for A.I.R. smog tubes. No big deal other than '67 or newer 250 smog head. Again, no big deal. I think they started with taper plugs in 1970, but that's not written in stone as far as I know. Looks like two wires from coil to-distributor indicates some kind of non-points ignition module. Start with checking for the correct plugs and replace with new. Start engine and check for vacuum leaks. Then check out ignition system.
'67 GMC 2500, 292, 4spd, AC |
03-30-2020, 03:07 PM | #31 | |
The 80 psi on #4 is concerning. There is obviously an issue there. Rings and/or valves. Putting new plugs in won't fix that issue.
03-30-2020, 10:12 PM | #32 |
My Dad put anti-foulers on his 74 Chevy pickup and it worked for years after that. I wonder what would happen if you put anti-foulers and new plugs, and then check the plugs again after a few thousand miles.
03-31-2020, 11:01 AM | #33 | |
I figured I had a Mexican block since the casting number wasn't listed in any of the books I own or have looked up. I think they're supposed to be better anyway. As far as the age of the head I could pull the valve cover off and run the casting number and find out. |
03-31-2020, 02:33 PM | #34 |
Let's try one at a time.
03-31-2020, 02:34 PM | #35 |
The next one:
03-31-2020, 02:36 PM | #36 |
And the top.
03-31-2020, 02:39 PM | #37 |
I'm probably not going to be driving it until this acceleration problem gets solved. Kinda dangerous when you can't move any faster than 20mph until you clear 1500rpm.
04-02-2020, 08:33 PM | #38 |
I guess this thread is ready for a fork.
04-02-2020, 09:09 PM | #39 |
stick a fork in the road, it's done?
04-03-2020, 10:28 AM | #40 |
I guess. It was quiet for the last couple of days. Someone requested three pics of the engine and I posted them. I haven't heard anything since.
04-03-2020, 10:38 AM | #41 |
Yeah, I'm not quite sure why that was requested. In my humble opinion (aka means nothing) I think the head needs to come off. That is what I would do, but, again, I'm sure there will be others that will disagree, given some of the advice already posted.
04-03-2020, 11:08 AM | #42 |
A couple of things to check. Has the Harmonic Balancer slipped? It not uncommon for the outer ring to move in relation to the inner hub. Find TDC of #1 piston and verify that the mark on the balancer lines up with the pointer correctly.
From the video you posted you have some definite valve train noise. I would adjust the valves. Actually first since it is a I-6 you can remove the side covers and inspect the camshaft for bad lobes and if everything looks good then go ahead and adjust the valves
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-03-2020, 11:45 AM | #43 | |
I'm definitely wanting to pull the head but I have no place to put it. With rain coming I don't want to store it on my kitchen table. With that much crud on the plugs it's been suggested that my rings are bad. With the compression readings I've gotten that could certainly be the case. I'll take a peek at the lifters and if possible see what the cam looks like. |
04-03-2020, 11:47 AM | #44 |
I'll ramble a bit...
I would attempt a leak down test before pulling the head to narrow down the location of the compression leak. I think you can at least narrow it down to rings / valves. Do a compression test, oil the cylinders, and test again. If the number is higher, that points to rings. If the results are about the same, valves or head gasket. Given how wet #3 and #4 looks, rings or head gasket are more likely. However, it is still possible the oil is from valve seals. A puff of blueish white smoke at startup usually points to valve seals. Just try to figure out as much as you can before you rip it apart. Don't know what is a normal compression test result for these engines. I thought 120psi was typically the minimum, and closer to 150 psi was normal. I don't think I would be worried about carb, exhaust, or ignition at this point.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
04-03-2020, 11:50 AM | #45 | |
04-03-2020, 12:36 PM | #46 | |
https://www.youtube.com/watch?v=O1KM_J6zDYs https://www.youtube.com/watch?v=agAWXnT4-EQ
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 04-03-2020 at 12:42 PM. |
04-03-2020, 12:47 PM | #47 |
A leak down is useful in this case. Another test you can do to narrow the possibilities is to blow compressed air into the cylinder(s) and listen for any escaping. You'll need some type of air inlet that screws into a spark plug hole. I made one from a compression tester.
To test a cylinder first make sure the cylinder you're going to test is at TDC on the compression stroke (so the valves are closed) Next, make sure you use a low pressure air source as the air can blow the piston back down into the hole, causing the engine to rotate. Make sure this doesn't happen. Put it in gear, e-brake, breaker bar on harmonic balancer...You get the idea. Disconnect the PCV line Blow a steady stream if low pressure air into the cylinder, 10 or 15 lbs should be enough. Listen for air escaping. If air comes out the exhaust pipe, it's getting past the exhaust valve If air comes out the carb, it's getting past the intake valve If air comes out the valve cover, it's getting past the rings While you're at it, remove the cap from the radiator and look for bubbles |
04-03-2020, 01:00 PM | #48 |
I've played with 250's and 292's before How many do you have ? A leak down test isn't going to give much info if the cylinders/heads are full of carbon .
04-03-2020, 01:07 PM | #49 |
Jesus Christ, WTF is wrong with some of you and your thin skin? I simply said I'm not sure why. Good lord, some of you need to step away from the computer and get some perspective. You're the second guy to get their panties in a wad because I was trying to gather some info or be helpful.
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side Last edited by LockDoc; 04-03-2020 at 02:58 PM. |
04-03-2020, 01:11 PM | #50 | |
Edit: I just checked the dipstick and it doesn't smell like gas anymore than usual. It is pretty dark though not due for a change for a little while. Last edited by strummin67; 04-03-2020 at 02:27 PM. Reason: Update to answer a question |
