03-30-2020, 11:35 PM | #1 |
Hood
Can anyone recomend the best way to fix where the bolt screws into the hood. As you can see looks like it was ripped out
03-31-2020, 12:29 AM | #2 |
Re: Hood
will be a tuff fix with no access to the back side..removing the complete brace and repair would be the best fix..check out how MP&C did on this truck hood...http://67-72chevytrucks.com/vboard/s...d.php?t=802924
03-31-2020, 06:36 PM | #3 |
Re: Hood
make a piece of flat bar with the nuts welded on in the right places
cut a piece of the panel out slip the flat bar in weld the hole shut some work required but maybe less than removing the panel, repairing and installing again. R&R of the panel would allow you to fix any rust associated with the hidden area but that's up to you. either way a piece of flat bar with the nuts welded on is a good repair. a piece of thicker flat bar with threaded holes, and no welded on nuts, may also be an option and require less of a slot to slip it in. |
03-31-2020, 08:48 PM | #4 |
Re: Hood
I like that plan
03-31-2020, 08:59 PM | #5 |
Re: Hood
Just be aware that if you start welding thick metal to thin, your likely to create area for stress cracking to start..especially in the hinge area where there is already a stress point..
04-01-2020, 12:14 PM | #6 |
Re: Hood
which type of welding do you think would be best? I have a friend who has been doing all the welding for me so far and he has every type of welder possible...
04-01-2020, 08:20 PM | #7 |
Re: Hood
If hes got every welder made he'll know...but I use mig...tig is also good
04-02-2020, 11:50 AM | #8 |
Re: Hood
ok thanks...great help
