04-09-2020, 01:32 PM | #11 |
Re: How to: Ruin a perfectly good C10
Bottom the suspension out completely & make sure the d.shaft doesn't contact anything. If it does, trim things back until it doesn't. I usually build things w/a 1/8" thick (yard stick) spacer to pad my clearances.
