04-08-2020, 10:32 AM | #1 |
Oil filler tube question
How does the oil filler tube connect into the manifold? Is it something that is threaded in? I have oil leaking from where it meets the manifold and want to stop that. I did not want to force it without knowing how it goes in.
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
04-08-2020, 11:14 AM | #2 |
Re: Oil filler tube question
It's just an interference press fit. It will pull straight out.
I've never removed one, though. Might be able to take a small piece of wood to use as a barrier, tap on the wood/pipe. See if if will free itself. Get everything cleaned up, and some good RTV will seal it. I use Permatex Ultra black... |
04-08-2020, 11:52 AM | #3 |
Make sure the PCV system is working. You may be building up pressure causing oil to leak in an uncommon place like that.
I'm curious. Were does that hose in the top of the water pump go. George |
04-08-2020, 12:33 PM | #4 |
Shaking the PCV valve, it rattles so I think that is free. I am going to replace it anyway. I agree and wondering why there would be any pressure there for oil to leak out.
That hose goes under the radiator hose and then back into manifold it seems. Hope this pictures can show it. Any thoughts about that?
04-08-2020, 02:19 PM | #5 | |
Who Changed This?
04-08-2020, 05:58 PM | #6 |
I'd like to see a better pic of where that heater attaches to the intake...?
Small block engines come with a bypass made in. Now..medium and heavy duty versions of the small block, use a heater hose bypass into the intake or thermostat housing. Never seen the HD version of the bypass on a light duty pickup (light duty is 10, 20, and 30 series...) Those oil fill tubes usually only leak, like yours, if the have been removed and re-installed... |
04-08-2020, 08:37 PM | #7 |
Who Changed This?
Some of the '60-'66 trucks had the same bypass that one would see on the MD and HD trucks. I was surprised to see that. Here's one example-
https://67-72chevytrucks.com/vboard/...%2C+thermostat
04-08-2020, 08:54 PM | #8 |
I am not an expert on the old PCV system but my 283 drew air in through the fill tube and had a vent in the back of the block by the distributer.
On the newer system I have seen the vent cover on the inside of the valve cover sludged up to the point it didn't breath and would pressurize the block. Might check that you have air pulling through the hoses. I have seen that intake to water pump before on early small blocks on 4v intakes. Never a 2v. Most I saw were in cars. |
04-09-2020, 07:16 AM | #9 | |
04-09-2020, 02:41 PM | #10 |
I have a 67 327 with the older PCV system. I think 67 was the last year for that type.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
04-09-2020, 06:57 PM | #11 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
