Old 02-07-2019, 03:28 PM   #51
Baime
Re: Anti-theft devices ideas and suggestions
Originally Posted by jeh View Post
I keep mine in a locked garage at home, and I also have 2 big dogs outside that don't like nonsense. As far as the truck itself I have my electric fuel pump on a switch that's pretty hard to find, with the ole BB427 it won't make it very far on the fuel in the carb.
(The one on the pillow weighs 235 pounds)
Jason,
I was feeling tired while I was reading this thread. Your dogs are big, but they look like good old dogs to me. Something tells me they would let me crawl right into that big pillow/bed, and then join me for an afternoon nap.
I'm heading for the couch right now.
Best theft protection I've heard about so far.
Take care, JP
Baime is offline   Reply With Quote
Old 02-07-2019, 04:31 PM   #52
OregonNed
OregonNed's Avatar
This guy!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 02-11-2019, 06:37 AM   #53
tino0217
A battery kill switch is what I'm using and my female German shepherd "Nikki"
tino0217 is offline   Reply With Quote
Old 02-11-2019, 07:57 AM   #54
mygmctruck1
I look at this from this perspective , I do not believe you are going to stop anyone who really wants your truck. So that being the case , have a hidden GPS locator on it. at least you could track it down.
mygmctruck1 is offline   Reply With Quote
Old 02-11-2019, 08:35 PM   #55
tino0217
True that. If they want it they'll take it. Gpa is probably best for recovery.
Old 02-11-2019, 08:44 PM   #56
jeffahart
jeffahart's Avatar
Originally Posted by OregonNed View Post
This guy!
If you just took a "Selfie"... nobody's going to steal your truck!
j
White K20
jeffahart is offline   Reply With Quote
Old 02-11-2019, 08:58 PM   #57
mygmctruck1
Dam auto correct GPS , not. GPA
Old 02-11-2019, 11:27 PM   #58
burnin oil
Originally Posted by 87Skier View Post
Now that's an idea I haven't seen before. I also like the BrakeLock idea. I've seen some generic ones on summit before but I don't know how long it would hold pressure, it may bleed back through eventually.
The stuff I've done to mine I know will slow someone down. I would bet any of us could look at another member's truck that has a secret and have a least a little trouble getting it going.
You can't use those. They are only designed for racing and the solenoid will melt after a short period of time. You need the actual Micro-Lock that has a lever on it. These are 100% mechanical and activate by pushing the brake pedal down and then flipping the arm. Acts just like having your foot on the pedal. I got one out of a junk yard that I want to look into hooking into my front brakes for winching operations since I have a manual trans.
Micro-Locks are still available new but are around $400 now since they had to add a bunch of stupid safety things to them. They are also no longer legal for instalation as an emergency brake since a hydraulic failure would render it useless. You used to see them alot on medium duty trucks like the power companies bucket trucks.
burnin oil is offline   Reply With Quote
Old 02-11-2019, 11:48 PM   #59
CastIron
CastIron's Avatar
I don't have any anti-theft devices currently (except the 3 speed trans) but I have thought about adding a relay that must me turned on manually to send power to the starter. And have it direct power to an extra loud horn if somebody tries to hotwire it without turning on the relay.
CastIron is offline   Reply With Quote
Old 02-12-2019, 05:20 AM   #60
kolle_hond
I don't have the stock bolt for the 3ott shifter, so I can just put the truck in gear, take out the bolt and take the shifter with me.
There are also some bolts/screws for the steering wheel alignment that the previous owner replaced with ones that can screw out by hand, from the outside of the steering wheel (instead of being tightened inside, on the column). Remove these, and the thief won't be able to turn the wheels.
Also, for anyone who didn't know, if you leave your windows open by just a tiny bit, they are much more difficult to break.
If I had the pedal e-brake, I would probably make the release lever removable and carry it with me.
I have remote central locking, but I have not installed the immobilizer or the siren yet, as I only recently got door jamb switches.
1970 C10 250 3-speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=650480
kolle_hond is offline   Reply With Quote
Old 02-13-2019, 08:10 AM   #61
rpmerf
rpmerf's Avatar
I just remembered my truck had an alarm system when I got it. There was a large siren on the drivers side fender. Door jamb switches and a micro switch for the hood. Activated by a keyed switch in the fender.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 02-14-2019, 02:06 AM   #62
67sbw
Battery switch
Fuel pump switch
If you're bagged, lay the frame and add a compressor switch
Hidden GPS, just in case
1967 C10 Step Side,250,TH350,PS,PDB, AC,Tilt
67sbw is offline   Reply With Quote
Old 02-24-2019, 01:14 PM   #63
dave`12
dave`12's Avatar
Great thread. I have an electric fuel pump with the switch in plain site. I think I will fix that. Also, I saw a post about the removable grant - I had one on an RX-7 years ago and found the car broken into and rolled back into the street one morning. I'm assuming the grant saved me that day. Make sure to take the wheel inside!
Here is my current deterrent. Park another truck in front of the one you love the most!
1967 C-10 4-speed, 350v8
dave`12 is offline   Reply With Quote
Old 02-25-2019, 02:53 AM   #64
tino0217
Nize
Old 02-25-2019, 10:57 AM   #65
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
This is what I do. Park my newer cars behind my truck and set the alarms on them. Plus I have a club on the steering wheel, 4 dogs that go ballistic if someone comes around, and .357 reasons not to mess with my stuff.
Of course this only works at home. When I'm out, I just try to park it where I can see it, put the club on the wheel, and lock it. Not the greatest but I live in a very small town. People know me and my truck. If I didn't see someone trying something with it. Someone else probably would.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 02-26-2019, 12:42 AM   #66
89AKurt
89AKurt's Avatar
Originally Posted by palallin View Post
I figure the rust and paint problems probably are sufficient deterrent for my truck.
I was waiting for someone to say this. So I don't need to worry, 4 speed, choke. But I live in a town where this hardly happens.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 02-26-2019, 08:48 PM   #67
Sparky dave
This is how they roll in South Africa! Apparently they can legally install flamethrowers
Sparky dave is offline   Reply With Quote
Old 02-26-2019, 08:49 PM   #68
Sparky dave
And blades!
Old 02-26-2019, 09:53 PM   #69
kwmech
I had a customers blazer broken into years ago with the steering column busted out so they could jack it.. Funny thing was, the engine was inside the shop on a stand
Old 02-27-2019, 06:15 AM   #70
Sparky dave
They could have at least fixed the engine and mounted it back in before they try steal it. Bet you would have been impressed then ha
Old 04-09-2020, 11:33 PM   #71
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by LockDoc View Post
Funny, I was just thinking about this last night laying in bed when I couldn't sleep. I think the most secure thing as far as making it hard to steal would be a brake lock. To me it would have to be a hidden mechanical line lock type of thing with a lever you flip over to lock the brakes up. I would say fronts since that is where most of the weight is. That plus a hood lock. I have watched the guy that runs the salvage yard load vehicles on his rollback and I can tell you there isn't anything you can do to keep that from happening except park it where they can't get to it.
LockDoc
How about a heavy duty cable lock hooked up permanently to the frame. Then, always park next to something you can chain up to - like a street lamp?
(Super-duper bike chain)
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-10-2020, 09:54 AM   #72
jaros44sr
jaros44sr's Avatar
If you're running EFI, you could put a blank tune in it, then switch it when you want to start it up.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-10-2020, 10:07 AM   #73
LostMy65
LostMy65's Avatar
Yeah, I asked fitech to put a password or pin.
I really don't understand why the efi makers don't do this.
Old 04-10-2020, 11:00 AM   #74
Sheepdip
Sheepdip's Avatar
I quite sure if the thief has enough time he will get it. In this video supposedly he only needed 10 seconds. Nothing wrong with a obstacle course to navigate, but I still say a well hidden, well wired GPS tracker with a movement alert function gives you your best chance at getting your ride back. You may have to chase it down but at least you know where to look
Bottom line is if they want it bad enough they are going to get it, most thieves go for the easy stuff.
https://www.youtube.com/watch?v=WOoW2gsIIfk
Sheepdip is offline   Reply With Quote
Old 04-10-2020, 01:23 PM   #75
71gmcC15
71gmcC15's Avatar
Mine currently doesn't have a steering column. So if they want to take it they need to reinstall the column first.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
