Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 09-02-2019, 08:43 PM   #151
typerr
Re: '67-'72 Power Brake Booster Bracket With Hydraulic Clutch Conversion
Hello Captainfab
Looking for a kit for my 70 C10. Already have power brakes and don't want to redo my lines (again) so I'll take the flat bracket. Looking to use a Howe Racing Hydraulic Bearing which specs a 3/4" master. Thanks
typerr is offline   Reply With Quote
Old 09-03-2019, 12:02 AM   #152
Captainfab
60-66 Nut
I'll send you a PM with ordering and payment info.
Originally Posted by typerr View Post
Hello Captainfab
Old 02-11-2020, 03:30 PM   #153
effects66
effects66's Avatar
I am interested in purchasing just the clutch items as I have the clutch master already. (linkages, clutch mounting plates) I have a 1970 c10 with a t56 and hydroboost.
Matthew
My 1970 c10 (550hp LSX, 4l80e, full Ridetech)
http://67-72chevytrucks.com/vboard/s...d.php?t=556610
effects66 is offline   Reply With Quote
Old 02-11-2020, 10:55 PM   #154
Captainfab
60-66 Nut
I believe you sent me an email, correct?
Matthew
Old 02-22-2020, 08:33 PM   #155
Inverter
Inverter's Avatar
Just got mine today... I didnt think to ask and I dont think this will work with my particular DM... ☹️ Did a search, couldnt find any data on this matter.
Anyone...?
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 02-22-2020, 10:23 PM   #156
Captainfab
60-66 Nut
What is this DM you are referring to?
Old 02-23-2020, 07:47 PM   #157
Inverter
Inverter's Avatar
DropMember 😎
Ive been looking at that VanNatta Fab truck. They have the small master not so far over and slightly higher than the brake master.
Tryin to get some info from them. Did some measuring today, looks like a 1.25 stroke would work if mounted about 2” down from the pedal pivot and it could be a 1:1 link. Just a theory so far but could work in a higher position. Gotta think on it some more.
TROY
Old 04-15-2020, 01:07 PM   #158
C10agent
C10agent's Avatar
Interested in the kit, powder coated satin black. Just need payment info, amount and eta.
Thanks! Neil
Neil...............
1972 C10 SWB - Shop Truck in the Works
5.3 LS / Full Air Ride / Rear Notch
20" American Racing Daytonas
IG - neilioustx - pictures of build/progress
Born and Raised in the Promised Land....
TEXAS Y'ALL!!
C10agent is offline   Reply With Quote
Old 04-15-2020, 09:53 PM   #159
Captainfab
60-66 Nut
I'll send you a PM.
Thanks! Neil
Old 04-18-2020, 07:28 PM   #160
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Figured I would add some photos of the mock-up I just completed. For those considering this kit, I will say it makes life pretty simple..
I started first by simply installing the brackets to get an idea of how it will look, and to ensure I had nothing interfering both inside and outside the firewall.
Then I marked and drilled the two mounting holes and inserted hardware to just to make sure the hole saw would not move the bracket around while drilling the center hole.
Things look good at this point, now onto adding the master cylinder and linkage
[IMG]
While this was not the final assembly, its obvious how well this went together. Once I get a bit farther in my project, it will all go back in for the final time.
Now understanding no two of these trucks are identical, (and I am a bit anal), I shaved a few thousands off the standoff to provide perfect alignment.
Last step was to ensure the the rod was level, mark the clutch pedal and drill the mounting hole..
Thanks,
Drew
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 04-18-2020, 11:03 PM   #161
Captainfab
60-66 Nut
Thanks for posting these pics Drew
You must have had this for a little while. The pivot block has been updated a few months back. About how much did you trim off of the standoff? If I know about these things, I can make changes on future orders that are built and shipped out.
Old 04-19-2020, 12:02 AM   #162
HOTFUN
HOTFUN's Avatar
subscribed
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 04-19-2020, 05:22 PM   #163
Twisted78SS
Wide n'Low
Yeah, my poor project has been on the back burner for awhile. Like a couple years..
I ended up taking a 16th of an inch off which was not absolutely necessary but did bring it into perfect alignment.
Thanks again for a nice product.
Air Force Retired
Old 04-19-2020, 10:18 PM   #164
Captainfab
60-66 Nut
Thanks for the compliment and the feedback.
Old 05-05-2020, 12:46 AM   #165
Barba Negro
Interested in a complete setup for my 68 K10 with swapped front discs and power brakes. I'm swapping the 465 for a nv4500. I'm looking at the powder coated kit. Thanks
Barba Negro is offline   Reply With Quote
Old 05-05-2020, 10:05 PM   #166
Captainfab
60-66 Nut
I will send you a PM
Old 05-15-2020, 01:40 AM   #167
Dodge68charger
Interested In a Few of Your Brake Booster Brackets For My 68 and 69 C10s. Do You Have an Email I Can Reach You at? Thanks
Dodge68charger is offline   Reply With Quote
Old 05-15-2020, 10:06 PM   #168
Captainfab
60-66 Nut
Yes, the same email that is in post #1, captainfab454@hotmail.com
Old 06-14-2020, 11:00 PM   #169
jonesky2
jonesky2's Avatar
Interested in a complete set up for my 72 k10. wanting to put a square body hydroboost, nv4500, 5.3l
jonesky2 is offline   Reply With Quote
Old 06-15-2020, 09:03 PM   #170
Captainfab
60-66 Nut
I sent you a PM
Old 07-07-2020, 09:09 AM   #171
lil blue
lil blue's Avatar
I really wanna try this in my 78. Can somebody get me a measurement from where the linkage mounts to the pedal to the fire wall. If it’s the same length I will buy one and hopefully it will work
lil blue is offline   Reply With Quote
Old 07-07-2020, 09:54 PM   #172
Captainfab
60-66 Nut
I replied to your email.
Old 07-24-2020, 04:47 PM   #173
jjzepplin
jjzepplin's Avatar
How much for just the master bracket? I already have power brakes.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-25-2020, 12:24 AM   #174
Captainfab
60-66 Nut
The only other option other than the entire booster bracket, is for deleting the booster mounts from the base plate. That reduces the cost $25.00. I will need to know what you are using for a clutch slave cylinder or hydraulic release bearing as well whether you have a '67-'68 or a '69-'72. They are different.
Old 11-18-2020, 12:21 AM   #175
Barba Negro
What is everyone using for a slave on these swaps? Pulling the 465 for a nv4500.
