Old 08-19-2019, 08:04 PM   #76
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Back to the fifties with a 59 project
Have to order the rest of,the front suspension before i continue there . So i decided to take the bed off and at least start cleaning it up. Got to find me a rearend to use also.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 04-22-2020, 07:25 PM   #77
Hubscrub
Cruzin
Hubscrub's Avatar
Been working on patch panels on the wife's 67 but had to wait on parts. So I decided to take the rear end out and do some wire wheeling.
Proverbs 3:5,6
Old 04-23-2020, 10:32 AM   #78
jjzepplin
jjzepplin's Avatar
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-23-2020, 12:36 PM   #79
Hubscrub
Cruzin
Hubscrub's Avatar
Originally Posted by jjzepplin View Post
Lol
Proverbs 3:5,6
Old 04-29-2020, 08:58 AM   #80
mikebte
Nice! That wire Wheeling can make a heck of a mess.
mikebte is offline   Reply With Quote
Old 05-01-2020, 09:52 PM   #81
72 tigger
72 tigger's Avatar
Looks like a nice project- following along. I was in AZ on a mission trip this past February and snapped a couple of pics of this 59?
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 08-26-2021, 06:13 AM   #82
Hubscrub
Cruzin
Hubscrub's Avatar
I'm still here I don't have to tell you the mess the world's been in last year or so, but I've been working 6,7 days a week for most of the last year or so. I think some relief is on the way so hopefully I can get some family and garage time in. I did manage to order me a Mustang 2 front end kit.
Proverbs 3:5,6
Old 09-03-2021, 10:18 AM   #83
Hubscrub
Cruzin
Hubscrub's Avatar
Got the lower a arm braces, spacers welded on.
Proverbs 3:5,6
Old 09-04-2021, 03:15 AM   #84
72 tigger
72 tigger's Avatar
Good to see your progress!
71 C10
72 K20
72 K10 Super
Kirk
Old 09-06-2021, 11:35 AM   #85
jjzepplin
jjzepplin's Avatar
That looks nice!
Old 09-07-2021, 07:55 PM   #86
Hubscrub
Cruzin
Hubscrub's Avatar
Got the cross member and upper hats lightly tacked in.
Proverbs 3:5,6
Old 11-01-2021, 07:13 PM   #87
Hubscrub
Cruzin
Hubscrub's Avatar
Almost fully welded in except bottom, got to figure out the c notch for the steering rack next.
Proverbs 3:5,6
Old 12-06-2021, 07:47 PM   #88
Hubscrub
Cruzin
Hubscrub's Avatar
Been working on other stuff and trying to clean and organize the shop. But I have started the c notch for the steering rack .
Proverbs 3:5,6
Old 12-14-2021, 07:55 PM   #89
Hubscrub
Cruzin
Hubscrub's Avatar
Got the clearance for the rack. More grinding to clean up and I will weld some plates over the holes and got to fill the c notch.
Proverbs 3:5,6
Old 12-16-2021, 02:11 PM   #90
daveshilling
daveshilling's Avatar
Looks like you're on your way! Removing that whole front crossmember is an option now, you can tie the fronts together using the holes left over from removing the front leaf mounts
daveshilling is offline   Reply With Quote
Old 02-22-2022, 09:38 PM   #91
Hubscrub
Cruzin
Hubscrub's Avatar
Since the front crossmember is mostly done, I was going to remove the cab to make it easy to flip the frame around to weld the bottom and clean it etc. But I decided to attack the major parts of the cab that need rust repair, while it's still mounted on the frame and at a decent height.So I've been working on the driver step and got it removed. The inner cab corner need some work as well as the outer.
Proverbs 3:5,6
Old 02-22-2022, 10:31 PM   #92
Hubscrub
Cruzin
Hubscrub's Avatar
Thanks for looking in, that has crossed my mind.
Proverbs 3:5,6
Old 02-23-2022, 01:08 AM   #93
dsraven
I really suggest you hang your door, adjust it to fit the opening in the cab, not considering the fender just the cab, then weld in an X brace inside across the door opening. That will make sure the door still fits after all the parts are cut out and new stuff is welded in.
Old 02-23-2022, 01:09 AM   #94
dsraven
Forgot to say the door can be taken off after the X brace is in place.
Old 08-25-2022, 08:04 PM   #95
Hubscrub
Cruzin
Hubscrub's Avatar
Got the driver side done (except minor things). Just a quick prime job and cut out my temporary bracing cleaned up,on to the other side.
Proverbs 3:5,6
Old 08-25-2022, 08:11 PM   #96
Hubscrub
Cruzin
Hubscrub's Avatar
Also picked me up a camaro rearend few weeks ago been cleaning on it to.
Proverbs 3:5,6
Old 08-25-2022, 08:17 PM   #97
Hubscrub
Cruzin
Hubscrub's Avatar
Well the passenger side begins. Same as other inner and outer cab corner, rocker and step and some misc. patches. The corner was stuffed with junk and and a bunch of nails.
Proverbs 3:5,6
Old 08-25-2022, 08:27 PM   #98
Hubscrub
Cruzin
Hubscrub's Avatar
Found this Armstrong vinyl flooring sample behind the gas tank. Far out!
Proverbs 3:5,6
Old 08-25-2022, 10:34 PM   #99
joedoh
joedoh's Avatar
outstanding!
Old 09-06-2022, 09:09 AM   #100
Hubscrub
Cruzin
Hubscrub's Avatar
Got passenger side fitted and tacked.
Proverbs 3:5,6
